Hi, I noticed that you had to perform an edit to the motherboard and tie spare refclk pins to the CPU module to get the SSD to work with the RK3588. Will we have to perform a similar mod to get this to work?
No. This will be solved on the adapter.
Cool, out of interest did you manage to get the internal wifi on the RK3588 working or were you relying on the external wifi card/ just ethernet?
There’s no internal WiFi/Bluetooth on the module. Currently the idea is to use a mPCIe WiFi card of your choice as was common practice with the original i.MX8MQ module.
Will the M.2 slot be able to be used to power the device instead of micro sd? I wanted to load a 2230 Sabrent Rocket Nano v2 on it whenever I get it.
