Hi!
I have trouble booting almost all of the time. Usually the keyboard backlights turn on as well as the screen backlights but then nothing happens.
Generally the issue started after the laptop wasn’t turned on for several days. Having high load, the display went off after around 2 minutes.
And now, if it works, the screen will turn off after around 5-10 minutes. I tried removing batteries, LPCRST (and IMXRST), removing SSD, Wifi, disconnecting trackball and also removing the clock battery.
The latter is what made a difference at some point, the system would have an uptime of > 10 minutes (instead of < 5 minutes). The way the system crashed was interesting, Screen went off for a split second, again after a few seconds and then went off. I might be wrong, but subjectively this was in sync with Trackball movements. (When things still worked, the trackball tended to freeze after around 1-2 hours of high load and I had to connect a USB mouse)
FWIW I measured the power supply output (23.7V) and the clock battery (3.07V). On the Rescue system dmesg produced some messages:
How could this be solved? Firmware update?
Greetings, Philip
edit: another screenshot with the Wifi module connected: https://imgur.com/a/KcDgP0f
