Hi, I ran a apt update && apt full-upgrade today but now my battery status is no longer visible; the reform2-lpc-dkms kernel module is no longer loaded. dkms reports a version for an older kernel version is installed. So not all is upgraded.
More information:
[remp 17:48 ~]$ sudo apt full-upgrade
Not upgrading:
linux-headers-mnt-reform-arm64
Summary:
Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 1
[remp 17:48 ~]$ sudo apt install linux-headers-mnt-reform-arm64
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Unsatisfied dependencies:
linux-headers-6.17.8-mnt-reform-arm64 : Depends: gcc-15-for-host but it is not installable
Error: Unable to correct problems, you have held broken packages.
Error: The following information from --solver 3.0 may provide additional context:
Unable to satisfy dependencies. Reached two conflicting decisions:
1. linux-headers-6.17.8-mnt-reform-arm64:arm64 is selected for install because:
1. linux-headers-mnt-reform-arm64:arm64=6.17.8-1+reform20251126T085426Z is selected as an upgrade
2. linux-headers-mnt-reform-arm64:arm64=6.17.8-1+reform20251126T085426Z Depends linux-headers-6.17.8-mnt-reform-arm64 (= 6.17.8-1+reform20251126T085426Z)
2. linux-headers-6.17.8-mnt-reform-arm64:arm64 Depends gcc-15-for-host
but none of the choices are installable:
[no choices]
[remp 17:48 ~]$ sudo dkms status
reform2_lpc/1.82, 6.16.7-mnt-reform-arm64, aarch64: installed
Anybody know how to fix or workaround this?
