Suddenly and all at once. Not a Pocket issue per se. Hadn’t used it in a couple weeks, was doing apt upgrade, reading a book. I look over the screen is black. Hmm, not asleep, it powered off? OK…
Powered back on and rebooted, opened a terminal. Tried to run apt upgrade again and ‘lock’ complaints; it was running in the background. Hmmm OK. Did ps ax, saw reasonable processes unfold and complete, finally it was done. OK…
Ran my scripts that update project folders from main machine (rsync) to the Pocket, in the middle of a file, rsync unexpected closure. Can’t ping main machine, DNS error (it’s always DNS?)
sync sync reboot… boot fails, can’t mount home (the nvme). This is an A311D upgraded machine. / and /boot on the internal are fine. /dev/nvme* doesn’t exist except something called /dev/nvme-fabric (…web search…) looks like something in the NVME itself has died. Can’t fsck what does not exist.
This morning, took the cover off, all’s well, pulled the NVME out, reinstalled, no change.
Not expecting any solutions, just complaining to the universe. I’ve not had many M.2 NVME’s, and this is the first failure.
I’ll probably find a replacement tomorrow, if there are any knowledgeable hints or brands to select or avoid, please post! 1TB…
