Hello @all ,
yesterday I received my MNT Reform.
After installing the NVMe SSD hardware, I tried to copy the OS from SDCard to the NVMe SSD like described in the manual.
But the NVMe is not detected by OS, no NVMe listed in /dev.
Do I need to do something in the setting.
Or could it be a problem on HW, possibly solder points issues on NVMe port?
Many thanks in advance.
Greetings,
Jens
nils
March 25, 2021, 8:54am
#2
Did you install the included NVMe from Transcend or another NVMe? Have once read on Twitter that not every manufacturer is supported.
Greetings,
Nils
Hi Nils,
I installed the Transcend NVMe from package.
Greetings,
Jens
hmm…I found two pins / solder points on the m.2 connector are bridged…
start to fix it…let’s go
mntmn
March 25, 2021, 11:55am
#5
Hey, I’m sorry to hear that! As you can see here, a bridge on pins 2+4 is normal (lower left on this screenshot). Were there any other bridges?
Hi Lukas,
many thanks.
This looks not as desired:
I sent you dmesg output and the same pics. Hope it helps.
Many thanks!
Greetings,
Jens
mntmn
March 25, 2021, 1:01pm
#7
As mentioned in direct message, the bridge on this picture is OK. These are pins 2 and 4.
Hello @all ,
The issue is fixed. Many thanks to Lukas for great and fast support!
By re-soldering of some solder points on the m.2 connector everything is fine. Many thanks to Lukas!
Greetings,
Jens
