the following problem has been occurring since today: after clicking on Circle, the OLED on my Reform Classic only shows a white bar. When I click on Circle+b, the battery indicator appears. The OLED won’t display anything else.
Hi, what version of the keyboard firmware? It could be an older one that had a bug that has been fixed in the meantime. You can check when pressing Circle and then S. Also, depending on the keyboard version, you can press Circle and then R to reboot the keyboard, which should get you out of this state.
