I had a serial console attached to my Reform and while doing so I apparently shorted something out or whatever… anyways I heard some zapping noise. I immediately turned off the device, removed the batteries, inspected the boards and everything looked OK.
Then went ahead and turned on without batteries. The device worked fine, so I went ahead and put in the batteries again. I noticed one battery shows 0V and was reported missing. I also have both LEDCHG1 and LEDCHG2 on. But no charge going to the batteries.
Inspected the board again and this time noticed R28 looks burned and indeed it measured 30 Ohms instead of the expected 4,7 Ohms. So I went ahead and replaced it.
Unfortunately, no avail, still the same.
I already tried:
- switching around the batteries. It is always the same slot reporting as 0V, no matter which battery is in it.
- checked connection from the battery holder to the mainboard, I have 100 Ohms to the respective LPC6803 input.
- measured R12, R20, C11 (all in circuit) - all seem fine.
- F2 seems fine.
Is there anything else I could check?
It seems most likely to me the LTC6803 has some kind of internal failure. Any idea how I could verify that before I try swapping it out?
Thanks and kind regards
