I was messing around and ended up changing some system tray setting and now I’m not able to click on “NET” to access wifi settings in SWAY. Can’t remember exactly what I did or how to undo this. Anyone got an idea of what I did?
connman-gtk is the application that runs when you click NET. Is it possible the connman-gtk window appears in workspace 1 but you are currently viewing another workspace? This occasionally happens to me - for example, when i click NET while in workspace 2, the connman-gtk window will display in workspace 1. Hasn’t been cumbersome enough for me to dive into.
Thanks for the reply. I don’t see it in other workspaces and it doesn’t seem to open anywhere when I navigate to it. Is conman a custom build for mnt or can I simply remove and install again?
A brute method would be resetting all of ~/.config and ~/.local to defaults. I guess this is only an acceptable solution if you don’t mind a bunch of other stuff being reverted. You could also compare those directories to their defaults with diff to see what’s changed. The original contents can be found in /etc/skel
I also experience this problem
In my case I was not changing tray settings, but rather editing network interfaces to disable wifi being enabled by boot. Unfortunately, I was not able to restore functionality but have not tried to debug in an exhuastive way, yet.
The menu (waybar) is configured with ~/.config/waybar/config and is controlled by the network widget. There should be a parameter called “on-click” which launches the script “reform-connman-gtk.sh” which in turn opens up connman for you.
Check that you haven’t done anything to the waybar config that’d stop that line from working, such as a missing , at the end of the line before it, or if you deleted it.
The other thing if you’ve messed with /usr/bin/reform-connman-gtk.sh you can test it by simply running reform-connman-gtk.sh
at the command line, all the file does is pkill any existing connman-gtk instance then start a new one.
This is how mine is currently setp
"network": {
// "interface": "wlp2*", // (Optional) To force the use of this interface
"format-wifi": "📶 {essid} {signalStrength}%",
"format-ethernet": "🔗 {ifname}: {ipaddr}/{cidr}",
"format-linked": "🔗 {ifname} NO IP",
"format-disconnected": "NET ×",
//"format-alt": "NET {ifname}: {ipaddr}/{cidr}"
"on-click": "reform-connman-gtk.sh"
The config and bin files look fine. To be clear, I think this was some setting in the connman GUI. The bonehead over here(me) checked the wrong box. Or maybe it was something else I did.
This is the message I get when trying to run connman-gtk.
(connman-gtk:2628): Gtk-CRITICAL **: 20:37:43.621: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
I’m not getting any error messages like that while running connman so I’d look into that as a cause. Have you updated debian lately? Perhaps you managed to get a mismatch of versions installed? Run sudo apt update
then sudo apt upgrade
to get things up to date and see if that persists.
I am also experiencing this issue now and I’m not sure why. Perhaps there is some important system update that I’m missing?
Here is my system information:
_,met$$$$$gg. ecgade@reform
,g$$$$$$$$$$$$$$$P. -------------
,g$$P" """Y$$.". OS: Debian GNU/Linux trixie/sid aarch64
,$$P' `$$$. Host: MNT Reform 2
',$$P ,ggs. `$$b: Kernel: 5.12.0+
`d$$' ,$P"' . $$$ Uptime: 28 mins
$$P d$' , $$P Packages: 2092 (dpkg), 13 (guix-user)
$$: $$. - ,d$$' Shell: bash 5.2.15
$$; Y$b._ _,d$P' Resolution: 1920x1080
Y$$. `.`"Y$$$$P"' WM: sway
`$$b "-.__ Terminal: .emacs-29.0.60-
`Y$$ CPU: (4) @ 1.500GHz
`Y$$. Memory: 975MiB / 3924MiB
`$$b.
`Y$$b.
`"Y$b._
Perhaps this output from apt update is also of use (I’m no good with apt)?
eyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: Skipping acquire of configured file 'Sources' as repository 'https://mntre.com/reform-debian sid/ InRelease' does not seem to provide it (sources.list entry misspelt?)
