I’ve got a zz9000 ordered for a 2000. However my plans have sorta changed. Seeing the zz9000 can take better advantage of the Z3 bus, I’m going to put it into a 3000 machine I recently picked up. Is the flyer card/bus the same between the 2000 and 3000/4000 and only the cable length different? Or do I need a different flyer card and cable? I assume I can just change the cards firmware between the two?
Or should I request the order simply be updated to a 3000 spec? Or could I order the parts needed to test the card in both a 2000 or 3000 machine?
