Hello - is there a list anywhere of what parts one will need to source to finish building the Reform from the CrowdSupply DIY kit. I’m imagining it’s at least some of the following?
Answering my own question - I missed that the contents of the DIY kit were listed about 3/4ths of the way down the Crowd Supply page. The SD card, 18650 cells and power supply are included.
Hi, just FYI the SSD is not a Samsung EVO, as I have found at least the 970 EVO Plus does not work. It might draw too much power, but the real reason is unknown. IIRC it also doesn’t work in the Pinebook Pro.
We ship Transcend MTE220S (1TB) and MTE110S (256/512GB) NVMe SSDs which work well in MNT Reform.
And yes, power supply and batteries are included with the DIY kit, as well as a 32GB MicroSD card with full size adapter. The Wi-Fi card (Compex WLE200NX) is an optional add-on.
I’ve been working with a few boards, including the Solidrun Honeycomb, in the Solidrun Discord forums they speculate that some of these SSDs have x86 option ROMs that may be conflicting.
I just received my diy kit and am very happy with it. The build quality is great.
Now I bought ssd and wifi card myself, which antenna do I need to get? Can someone point me to some models that work?
Many thanks
Thanks for the info.
I habe bought the wifi card and 1tb ssd you recommended in thos thread, just to have a working system.
I might try different brands when I have gotten used to the system
Are you looking to buy specific card (WLE200NX) or just any mpcie card known to be working in linux? I have a stock of cards from older laptops (demolished by kids) so planning to use one of those (once DYI appears in store). But take a look here.
Nothing specific, ideally something that is mostlikely to work. Once I’ve gotten some experience with this I might consider switching but for now I’d just want to see it working successfuly.
Hi, just to contribute to the list of working wifi cards:
AzureWave AR5B195 (with the Laird antenna)
I bought the wifi-card a few years ago, I’ve been using that in my old laptop. I needed to buy a half to full height bracket (this is the one I bought) as that card is half-size and the MNT Reform only takes a full sized one.
It seems to be working fine, although I have only been using it for about a day. Got my MNT Reform a few days ago but needed to wait for the antenna and bracket to arrive before I could test out the wifi-card.
