Performance of MNT web cam?
Can the web cam deliver smooth video calling experience? Not expecting top of the line high end performance.
I have the camera here. Anything in particular you’d want me to try? The only “oddity” compared to other cameras I’ve had is that you only get a raw stream and no compression at all, not even mjpeg. So your USB connection needs to be able to handle this (especially at higher resolutions) and your CPU needs to be able to have enough spare cycles for the encoding.
Does that mean it use higher bandwidth? Can it produce smooth vdo call like typical webcams?
As it has no built-in compression, it depends on the processing power of the computer you’re using. Also please note it has a very wide angle lens, which might not be suitable for everyone.
