Pocket Reform Mainboard 2.0
I have a few questions regarding the Pocket Reform Mainboard 2.0. Maybe somebody has got experience on that:
  • Will all connectors and cables fit 1:1 with the orientation of the previous board?
  • The new mainboard has improved voltage regulators. Is there a chance that the problems with the display at boot (only half screen visible; no video on the internal screen) are fixed using the new board?
  • Has someone used the USB-C port for video by now?
Cheers
Claus
As I partly mentioned in this post I had some issues with my Pocket Reform that I wished to be solved in some way. Here’s some positive feedback:
  • Half screen or blank screen at boot: This disappeared after installing barebox and after the firmware fixes minute made
  • Keyboard or/and trackball unresponsive until usb-/keyboard reset: This was gone after installing keyboard pcb 2.0.
By now I’m truely sattisfied with my little pocket!
RK3588
Keyboard 2.0
Display v.2
FW 20260819
Mainboard v1
Thank you for the update, it’s great to hear that these main troubles are solved.
