The Pocket Reform was born to be a mobile workhorse. It is designed in such a way that it really lends itself to this role. To that end, I’m curious if anyone has found a way to get a full days worth of work out of it?
Amospallo made a nice little script which kind of puts the imx8+ into a low power running state, not to be confused with suspend. This gets you about 1.5 times the amount of battery life you would normally get. Meaning it can extend your battery life, but not by much, in the scope of a day.
So then the question is until suspend or preferably hibernation are possible, how are you getting through the day? If you are using battery packs, let us know what ones you are using and the kind of additional run time you are seeing from it.
