Pocket reform reboots sometimes when I start charging it
Sometimes when I am using the pocket reform and I start charging it the screen goes blank and it reboots.
It has happened at different battery levels, it has happened when it is low but also above 70%.
Any idea of what could be causing it? Or where I could start looking for the cause?
Thank you.
This got solved after an apt update and upgrade.
