I have been fighting random system controller communication issues.
Reform-Check
Leaving the system on or off plugged in to power or not the battery level in the OS will go to zero and the keyboard controller will show a T . I can not narrow down how or when it will error out.
To reset it I may need to flip the hardware power switch one or more times.
Is there a way to reset it via the command line?
I have not reseated cables and screen position does not seem to effect anything.
I have a new System Controller + accompanying keyboard firmware in the works and almost ready to release which has a new command line interface directly in the keyboard OLED, which will help debug issues like this. Lets hope I can get a beta out later today.
I have updated to the latest firmware. Unfortunately the issue seems to persist though different symptoms. Is the new API documented or is there a command that can test the system controller to keyboard communication or reset the system controller?
The below post seems to also be related. This is making me wonder if it is also related to attempting custom cpupower settings. I have been attempting to throttle the CPU to reduce heat. I will retry with default settings.
The way i feel it is similar is that only a hard system controller power cycle seems to fix the issue.
Currently my battery status does not show up properly.
Keyboard display show status run may or may not show the system controller firmware number 20260819. it seems like it is trying to show depending on device status at time of the request.
I also have an a311d and have had significant SC issues since the firmware upgrade (20260819).
I can’t get the pocket reform to start without having to open the top panel and pushing the SC reset button. This doesn’t always work the first time either. Once I do get it up and running, the battery reporting is hit or miss. Most of the time it reports 0%.
