I’m getting trace errors when starting up my Pocket Reform. I’m not linux savy enough to understand what this means. Can I get help understanding what it means and how to resolve the issue?
Hi, this is a somewhat known issue that recently appeared with a kernel upgrade. It is a warning that the kernel detects a programming issue in the third-party qualcomm wifi drivers (on i.MX8MPlus platform). As far as we know it’s harmless, but we should probably patch the driver to fix this. CCing @josch here just so that there’s another pair of eyes.
I don’t think it is preventing me from doing anything. My unit boots fine. I don’t know if it should be a priority. It is a minor annoyance b/c I get the tracing notification for it before I login. Which means I just press enter a couple times for the login prompt.
What’s your reform-tools version? What kernel? What board? If you are feeling lazy, copypasting the sudo reform-check output answers all these questions.
You can usually just select what you want to copy with your mouse and then middle click wherever you want to paste it. No button needed to “copy”.
Alternatively, depending on the terminal, you can right click and copy the current selection or press shift+ctrl+C to copy to clipboard. I usually just select and then middle click.
If you use sudo then you only need the password of your current user. Since your user is in the sudo group it is allowed to perform superuser actions after giving the password.
You could run this to redirect everything reform-check outputs to a file called “output”:
sudo reform-check > output 2>&1
The 2>&1 is needed because reform-check outputs most of what it prints to standard-error and > only redirects standard-output.
I: `uname -a` output: Linux [computername] 6.15.4-mnt-reform-arm64 #1 SMP Debian 6.15.4-1~exp1+reform20250628T170930Z (2025-06-28) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.15.4-1~exp1+reform20250628T170930Z
I: Version of reform-tools: 1.75-2+reform20250622T103710Z+1
I: Mount source of /: /dev/mmcblk2p2 (eMMC)
W: MNT Reform Desktop meta-package is not installed: reform-desktop-full
W: Depends of reform-desktop-full is not installed: espeak-ng
W: Depends of reform-desktop-full is not installed: espeak-ng-data
W: Depends of reform-desktop-full is not installed: gnome
W: Depends of reform-desktop-full is not installed: gnome-firmware
W: Depends of reform-desktop-full is not installed: gnome-shell-extension-dashtodock
W: Depends of reform-desktop-full is not installed: gnome-shell-extension-manager
W: Depends of reform-desktop-full is not installed: modemmanager
W: Depends of reform-desktop-full is not installed: network-manager-gnome
W: Depends of reform-desktop-full is not installed: reform-desktop-minimal
W: Depends of reform-desktop-full is not installed: rtkit
W: Depends of reform-desktop-full is not installed: speech-dispatcher-espeak-ng
W: Depends of reform-desktop-full is not installed: wlr-randr
W: MNT Reform Desktop meta-package is not installed: reform-desktop-minimal
W: Depends of reform-desktop-minimal is not installed: dhcpcd-base
W: Depends of reform-desktop-minimal is not installed: fdisk
W: Depends of reform-desktop-minimal is not installed: hdparm
W: Depends of reform-desktop-minimal is not installed: iputils-ping
W: Depends of reform-desktop-minimal is not installed: iw
W: Depends of reform-desktop-minimal is not installed: lshw
W: Depends of reform-desktop-minimal is not installed: netcat-openbsd
W: Depends of reform-desktop-minimal is not installed: nvme-cli
W: Depends of reform-desktop-minimal is not installed: picotool
W: Depends of reform-desktop-minimal is not installed: pocket-reform-handbook
W: Depends of reform-desktop-minimal is not installed: unzip
W: Depends of reform-desktop-minimal is not installed: wavemon
W: Depends of reform-desktop-minimal is not installed: wireless-regdb
W: Depends of reform-desktop-minimal is not installed: zstd
W: Suggests of reform-desktop-minimal is not installed: firmware-atheros
W: Suggests of reform-desktop-minimal is not installed: firmware-iwlwifi
W: Suggests of reform-desktop-minimal is not installed: firmware-mediatek
W: Suggests of reform-desktop-minimal is not installed: firmware-misc-nonfree
E: Your /etc/skel/.profile contains an outdated line that attempts to print /etc/reform-help or run reform-help.
E: Consider simply deleting that offending last line of your /etc/skel/.profile.
??5?????? c /etc/skel/.config/wayfire.ini
??5?????? c /etc/skel/.config/sway/config.d/input
- fbcon=font:TER16x32
W: /boot/flash.bin is not the latest uboot
reform-flash-uboot
Thank you. There is indeed something odd going on.
Can you tell me whether you have this file: /etc/flash-kernel/ubootenv.d/00reform2_tuigreet_loglevel and if not, what you get when running this command:
grep tuigreet /etc/greetd/config.toml doesn’t return anything. I also tried it using the sudo grep tuigreet /etc/greetd/config.toml just in case that would make a difference.
Are there next steps or should I just ignore it until it gets fixed?
Then I still fail to understand what the actual problem is.
In your initial message you show the call trace that you get and which looks scary and which should get fixed, yes. But in a later message you say that everything else is still working fine and the mayor annoyance is that you get the trace before logging in. This made me assume that you are using tuigreet to log in. Are you? How do you log in?
Could you describe the problem you are facing in more detail?
If the grep command above returns nothing then that suggests that you are not using tuigreet. Are you using gdm instead? Probably not because then the trace would not cause problems. What do you use to log in?
Posting your /etc/greetd/config.toml could help if you are using greetd to log in.
There are no major disruptions that I’m aware of other than logging in. When I log in I get the trace error stuff which I didn’t realize was a known issue. I do not know if I’m using tuigreet or greetd. I’m using whatever came default with the pocket reform.
I am not being prevented from doing anything in the computer. The Pocket Reform is not my primary computer so if there was a major problem, it would not be blocking me from doing things.
Usually you would get this change automatically by upgrading the reform-tools package. The reason you did not get it is because according to your /etc/greetd/config.toml you are not using tuigreet to log in and this change only makes sense for those logging in via the text terminal.
I was not aware that there were Pocket Reforms shipped which did not have tuigreet configured but which just used, probably agreety?
I had a quick look at the qcacld2 sources, and fixing these will be a pain. ISTM a lot of structs use char ...[1] to indicate a flexible array member, and then UBSAN trips over that.
Replacing the [1] with [] is not so easy, as “on paper” the structure size changes. And obviously qcacld2 uses sizeof(…) on these stucts to allocate them.
Thank you @zeha for looking into fixing the actual cause rather than papering over the symptom.
Though I’m afraid that qcacld2 might be a dead-end and I’m already not feeling great with the time I put into making it work with each new kernel release…
