Pocket reform with NVME randomly power-downs with new firmware, now will not turn on
Running 20260808 firmware. I also should point out my power supply broke and I jumped the power supply with the instructions to route around the power controller. Waiting on the part via RMA.
The MNTPR os runs on emmc, but of course I want to use my NVME (WD_Black SN750 SE 500gb).
When I run reform-setup-encrypted-disk it works until it asks to transfer over the system, then the device shuts down.
I can see the 500gb drive (LUKS encrypted) when I boot into the emmc, but if I open files interface and click on the drive the computer shuts down immediately.
Now the device will not power on at all.
I should note: I removed the NVME, and the device will still not boot at all – I start it up from the keyboard menu and it shuts down right away.
How are you powering the Pocket Reform, meaning what USB-C power supply model?
I am using an Apple power supply, it’s what I’ve been using since I got the machine in March. I tried a few other power supplies, and I’m getting the same response.
Hmm, sounds like a short or loose cable, or the bypass jumper is loose. Definitely unusual. If you’ve cleaned and seated everything and it doesn’t improve, I would suggest we do a quick inspection/repair under warranty.
BTW i’ve did a quick survey on the fediverse and got some feedback that the fw/kernel upgrade on imx8mp Pocket Reform worked out for other people, so that rules out a software/firmware issue I’d say.
I just saw this thread after posting Important note about the new MNT Pocket Reform kernel and firmware updates 20260808 (updated) - #64 by nlordell, but I also have power issues with Apple power supplies since fw 20260808, where my battery will cycle between charging and discharging every few seconds.
Right, it could be a combination of USB-C PD regression with Apple charger(s) and having no batteries connected, the symptoms would be exactly like that.
I borrowed a Thinkpad USB-C charger and it booted right up. Still without the NVME, but I will let you know if anything comes up when I re-install it. Thanks @nlordell and @minute !
Aha, awesome! Then your mainboard is fine and I can fix Apple compat in firmware.
So, the computer boots. I reinstalled the NVME that worked before the firmware update.
I am getting the same behavior: When I try to create a new encrypted disk, the formatting works, but when the recover system portion of the wizard happens the device shuts down.
If I boot into the device and open files, then click on the 500gb device, it asks me for the password to decrypt the device, when I enter it it seems to work until the File interface goes to load the directory, then it shuts down again
Dmesg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 7.1.8-mnt-reform-arm64 (debian-kernel@lists.debian.org) (aarch64-linux-gnu-gcc-15 (Debian 15.3.0-2) 15.3.0, GNU ld (GNU Binutils for Debian) 2.47) #1 SMP PREEMPT Debian 7.1.8-2+reform20260814T225949Z (2026-08-14
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: MNT Pocket Reform with i.MX8MP Module
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: 0x0000000057e00000..0x0000000057ffffff (2048 KiB) nomap non-reusable optee_shm@57e00000
[    0.000000] OF: reserved mem: 0x0000000056000000..0x0000000057dfffff (30720 KiB) nomap non-reusable optee_core@56000000
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000023fffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x23efc0280-0x23efc3a7f]
[    0.000000] cma: Reserved 256 MiB at 0x00000000f0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000023fffffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x0000000055ffffff]
[    0.000000]   node   0: [mem 0x0000000058000000-0x000000023fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
[    0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[    0.000000] percpu: Embedded 36 pages/cpu s108056 r8192 d31208 u147456
[    0.000000] pcpu-alloc: s108056 r8192 d31208 u147456 alloc=36*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GICv3 CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ro no_console_suspend pci=pcie_bus_perf nvme_core.default_ps_max_latency_us=0 console=ttymxc1,115200 console=tty1 fbcon=font:TER16x32 cma=256MB console=tty1
[    0.000000] PCIe ASPM is disabled
[    0.000000] printk: log buffer data + meta data: 131072 + 557056 = 688128 bytes
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2088960
[    0.000000] Policy zone: Normal
[    0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 55398 entries in 218 pages
[    0.000000] ftrace: allocated 218 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 160 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: GICD_CTLR.DS=0, SCR_EL3.FIQ=1
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.000000] arch_timer: cp15 timer running at 8.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[    0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[    0.001673] Console: colour dummy device 80x25
[    0.001685] printk: legacy console [tty1] enabled
[    0.003090] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[    0.003124] pid_max: default: 32768 minimum: 301
[    0.006200] landlock: Up and running.
[    0.006214] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.006506] AppArmor: AppArmor initialized
[    0.006572] TOMOYO Linux initialized
[    0.007002] LSM support for eBPF active
[    0.008589] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.008628] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.009967] VFS: Finished mounting rootfs on nullfs
[    0.015809] rcu: Hierarchical SRCU implementation.
[    0.015840] rcu: 	Max phase no-delay instances is 1000.
[    0.016163] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.019713] EFI services will not be available.
[    0.020242] smp: Bringing up secondary CPUs ...
[    0.020974] Detected VIPT I-cache on CPU1
[    0.021099] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[    0.021141] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.021992] Detected VIPT I-cache on CPU2
[    0.022110] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[    0.022141] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.022997] Detected VIPT I-cache on CPU3
[    0.023112] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[    0.023142] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.023259] smp: Brought up 1 node, 4 CPUs
[    0.023360] SMP: Total of 4 processors activated.
[    0.023372] CPU: All CPU(s) started at EL2
[    0.023410] CPU features: detected: 32-bit EL0 Support
[    0.023425] CPU features: detected: 32-bit EL1 Support
[    0.023441] CPU features: detected: CRC32 instructions
[    0.023463] CPU features: detected: PMUv3
[    0.023519] alternatives: applying system-wide alternatives
[    0.072144] node 0 deferred pages initialised in 44ms
[    0.072268] Memory: 7781856K/8355840K available (18816K kernel code, 5154K rwdata, 11428K rodata, 3776K init, 913K bss, 306596K reserved, 262144K cma-reserved)
[    0.074291] devtmpfs: initialized
[    0.094148] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.094252] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[    0.098972] 22688 pages in range for non-PLT usage
[    0.098997] 514208 pages in range for PLT usage
[    0.105061] DMI: not present or invalid.
[    0.108301] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.109854] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.110185] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.110255] audit: initializing netlink subsys (disabled)
[    0.110441] audit: type=2000 audit(0.108:1): state=initialized audit_enabled=0 res=1
[    0.113525] thermal_sys: Registered thermal governor 'fair_share'
[    0.113539] thermal_sys: Registered thermal governor 'bang_bang'
[    0.113562] thermal_sys: Registered thermal governor 'step_wise'
[    0.113576] thermal_sys: Registered thermal governor 'user_space'
[    0.113589] thermal_sys: Registered thermal governor 'power_allocator'
[    0.113675] cpuidle: using governor ladder
[    0.113725] cpuidle: using governor menu
[    0.114159] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.114286] ASID allocator initialised with 65536 entries
[    0.116538] Serial: AMBA PL011 UART driver
[    0.125955] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[    0.126070] /soc@0/etm@28440000: Fixed dependency cycle(s) with /funnel
[    0.126258] /soc@0/etm@28540000: Fixed dependency cycle(s) with /funnel
[    0.126334] /soc@0/etm@28640000: Fixed dependency cycle(s) with /funnel
[    0.126408] /soc@0/etm@28740000: Fixed dependency cycle(s) with /funnel
[    0.126458] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[    0.126512] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /funnel
[    0.126560] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[    0.126621] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[    0.126704] /soc@0/etr@28c06000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[    0.127706] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[    0.127787] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[    0.127947] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.128051] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.128390] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[    0.128513] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[    0.128756] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.129028] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.129469] /soc@0/interrupt-controller@38800000: Fixed dependency cycle(s) with /soc@0/interrupt-controller@38800000
[    0.130252] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28440000
[    0.130389] /soc@0/etm@28440000: Fixed dependency cycle(s) with /funnel
[    0.130616] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28540000
[    0.130766] /soc@0/etm@28540000: Fixed dependency cycle(s) with /funnel
[    0.130976] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28640000
[    0.131131] /soc@0/etm@28640000: Fixed dependency cycle(s) with /funnel
[    0.131324] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28740000
[    0.131448] /soc@0/etm@28740000: Fixed dependency cycle(s) with /funnel
[    0.131727] /funnel: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[    0.131826] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[    0.131889] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /funnel
[    0.132127] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[    0.132228] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[    0.132295] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[    0.132503] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[    0.132634] /soc@0/etr@28c06000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[    0.137773] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[    0.138653] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[    0.140164] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[    0.141541] /soc@0/bus@30000000/clock-controller@30380000: Fixed dependency cycle(s) with /soc@0/interrupt-controller@38800000
[    0.156498] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[    0.156587] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[    0.156698] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.156849] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.157186] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[    0.157276] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[    0.157432] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.157683] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.158593] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[    0.158666] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[    0.158873] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.159338] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[    0.159514] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    0.162940] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[    0.163042] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[    0.163598] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[    0.163793] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.164532] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[    0.164799] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[    0.184440] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.184473] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.184490] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.184505] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.184520] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.184533] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.184548] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.184561] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.194732] ACPI: Interpreter disabled.
[    0.198420] iommu: Default domain type: Translated
[    0.198456] iommu: DMA domain TLB invalidation policy: strict mode
[    0.206966] pps_core: LinuxPPS API ver. 1 registered
[    0.206994] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.207021] PTP clock support registered
[    0.207146] EDAC MC: Ver: 3.0.0
[    0.207607] scmi_core: SCMI protocol bus registered
[    0.210037] NetLabel: Initializing
[    0.210062] NetLabel:  domain hash size = 128
[    0.210074] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.210155] NetLabel:  unlabeled traffic allowed by default
[    0.210449] vgaarb: loaded
[    0.210986] clocksource: Switched to clocksource arch_sys_counter
[    0.213633] VFS: Disk quotas dquot_6.6.0
[    0.213782] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.214933] AppArmor: AppArmor Filesystem Enabled
[    0.215164] pnp: PnP ACPI: disabled
[    0.225835] NET: Registered PF_INET protocol family
[    0.226134] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.233267] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.233401] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.233499] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.234185] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.236164] TCP: Hash tables configured (established 65536 bind 65536)
[    0.236706] MPTCP token hash table entries: 8192 (order: 6, 196608 bytes, linear)
[    0.237112] UDP hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.237678] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.237737] NET: Registered PF_XDP protocol family
[    0.237766] PCI: CLS 0 bytes, default 64
[    0.238136] Trying to unpack rootfs image as initramfs...
[    0.251895] kvm [1]: nv: 570 coarse grained trap handlers
[    0.252255] kvm [1]: nv: 710 fine grained trap handlers
[    0.252754] kvm [1]: IPA Size Limit: 40 bits
[    0.256011] kvm [1]: GICv3: no GICV resource entry
[    0.256045] kvm [1]: disabling GICv2 emulation
[    0.256070] kvm [1]: GICv3 sysreg trapping enabled ([C], reduced performance)
[    0.256106] kvm [1]: GIC system register CPU interface enabled
[    0.256145] kvm [1]: vgic interrupt IRQ9
[    0.256178] kvm [1]: Hyp nVHE mode initialized successfully
[    0.261259] Initialise system trusted keyrings
[    0.261368] Key type blacklist registered
[    0.261878] workingset: timestamp_bits=42 (anon: 38) max_order=21 bucket_order=0 (anon: 0)
[    0.268268] fuse: init (API version 7.45)
[    0.269271] integrity: Platform Keyring initialized
[    0.269328] integrity: Machine keyring initialized
[    0.269411] Key type asymmetric registered
[    0.269426] Asymmetric key parser 'x509' registered
[    0.269672] alg: self-tests disabled
[    0.270017] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.270253] io scheduler mq-deadline registered
[    0.287082] ledtrig-cpu: registered to indicate activity on CPUs
[    0.308563] SoC: i.MX8MP revision 1.1
[    0.346345] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.351058] Serial: AMBA driver
[    0.352792] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 15, base_baud = 5000000) is a IMX
[    0.353354] serial serial0: tty port ttymxc0 registered
[    0.354210] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 5000000) is a IMX
[    0.355595] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[    0.355835] printk: console [ttymxc1] enabled
[    0.363762] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 18, base_baud = 5000000) is a IMX
[    0.365516] msm_serial: driver initialized
[    0.366583] SuperH (H)SCI(F) driver initialized
[    0.391303] mousedev: PS/2 mouse device common for all mice
[    0.411564] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.419616] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.426684] NET: Registered PF_INET6 protocol family
[    0.429531] Segment Routing with IPv6
[    0.429571] RPL Segment Routing with IPv6
[    0.429627] In-situ OAM (IOAM) with IPv6
[    0.429713] mip6: Mobile IPv6
[    0.429737] NET: Registered PF_PACKET protocol family
[    0.430040] mpls_gso: MPLS GSO support
[    0.447183] registered taskstats version 1
[    0.447524] Loading compiled-in X.509 certificates
[    1.191747] Freeing initrd memory: 39180K
[    1.229783] Loaded X.509 cert 'Build time autogenerated kernel key: c04c9a71383acc3572cbddaeea03bc718d333ffc'
[    1.253395] Demotion targets for Node 0: null
[    1.254048] Key type .fscrypt registered
[    1.254066] Key type fscrypt-provisioning registered
[    1.317941] Key type encrypted registered
[    1.317980] AppArmor: AppArmor sha256 policy hashing enabled
[    1.318002] ima: No TPM chip found, activating TPM-bypass!
[    1.318019] ima: Allocated hash algorithm: sha256
[    1.318207] ima: No architecture policies found
[    1.318313] evm: Initialising EVM extended attributes:
[    1.318328] evm: security.selinux
[    1.318340] evm: security.SMACK64 (disabled)
[    1.318351] evm: security.SMACK64EXEC (disabled)
[    1.318365] evm: security.SMACK64TRANSMUTE (disabled)
[    1.318379] evm: security.SMACK64MMAP (disabled)
[    1.318391] evm: security.apparmor
[    1.318404] evm: security.ima
[    1.318414] evm: security.capability
[    1.318430] evm: HMAC attrs: 0x1
[    1.338497] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.341089] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.343568] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.346127] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.348507] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.378298] clk: Disabling unused clocks
[    1.383216] PM: genpd: Disabling unused power domains
[    1.395271] Freeing unused kernel memory: 3776K
[    1.563489] Checked W+X mappings: passed, no W+X pages found
[    1.563542] Run /init as init process
[    1.563556]   with arguments:
[    1.563564]     /init
[    1.563570]   with environment:
[    1.563578]     HOME=/
[    1.563586]     TERM=linux
[    3.451611]  cs_system_cfg: CoreSight Configuration manager initialised
[    3.486366] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[    3.491410] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[    3.688665] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[    3.692261] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
[    3.702600] i2c i2c-0: using pinctrl states for GPIO recovery
[    3.702690] i2c i2c-0: using generic GPIOs for recovery
[    3.703392] i2c i2c-0: IMX I2C adapter registered
[    3.706054] i2c i2c-1: using pinctrl states for GPIO recovery
[    3.706165] i2c i2c-1: using generic GPIOs for recovery
[    3.706398] i2c i2c-1: IMX I2C adapter registered
[    3.706918] i2c i2c-2: using pinctrl states for GPIO recovery
[    3.707126] i2c i2c-2: using generic GPIOs for recovery
[    3.719939] i2c i2c-2: IMX I2C adapter registered
[    3.843365] imx-sdma 30bd0000.dma-controller: loaded firmware 4.6
[    3.879401] imx-sdma 30e00000.dma-controller: loaded firmware 4.6
[    3.886641] sdhci-esdhc-imx 30b40000.mmc: Got CD GPIO
[    3.907314] sdhci-esdhc-imx 30b40000.mmc: drop HS400 support since no 8-bit bus
[    3.907388] sdhci-esdhc-imx 30b50000.mmc: drop HS400 support since no 8-bit bus
[    3.911066] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[    3.949761] imx-sdma 30e10000.dma-controller: loaded firmware 4.6
[    3.960726] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[    3.971555] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
[    3.971649] imx6q-pcie 33800000.pcie:       IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
[    3.971686] imx6q-pcie 33800000.pcie:      MEM 0x0018000000..0x001fefffff -> 0x0018000000
[    3.971803] imx6q-pcie 33800000.pcie: config reg[1] 0x1ff00000 == cpu 0x1ff00000
               ; no fixup was ever needed for this devicetree
[    4.013102] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[    4.015077] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[    4.027852] mmcblk2: mmc2:0001 X29128 117 GiB
[    4.035927]  mmcblk2: p1 p2
[    4.040117] mmcblk2boot0: mmc2:0001 X29128 4.00 MiB
[    4.062390] mmc1: queuing unknown CIS tuple 0x01 [d9 01 ff] (3 bytes)
[    4.070944] mmc1: queuing unknown CIS tuple 0x1a [01 01 00 02 07] (5 bytes)
[    4.074945] mmc1: queuing unknown CIS tuple 0x1b [c1 41 30 30 ff ff 32 00] (8 bytes)
[    4.075942] mmc1: queuing unknown CIS tuple 0x14 [] (0 bytes)
[    4.079571] mmc1: new UHS-I speed DDR50 SDIO card at address 0001
[    4.135235] mmcblk2boot1: mmc2:0001 X29128 4.00 MiB
[    4.139548] mmcblk2rpmb: mmc2:0001 X29128 4.00 MiB, chardev (238:0)
[    4.179283] imx6q-pcie 33800000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 16G
[    4.315504] nxp-pca9450 0-0025: PWRON interrupt.
[    4.317209] nxp-pca9450 0-0025: pca9450bc probed.
[    4.340282] rtc-pcf8523 2-0068: registered as rtc0
[    4.341836] rtc-pcf8523 2-0068: hctosys: unable to read the hardware clock
[    5.139026] imx6q-pcie 33800000.pcie: Device not found
[    5.139516] imx6q-pcie 33800000.pcie: PCI host bridge to bus 0000:00
[    5.139553] pci_bus 0000:00: root bus resource [bus 00-ff]
[    5.139576] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    5.139597] pci_bus 0000:00: root bus resource [mem 0x18000000-0x1fefffff]
[    5.139650] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400 PCIe Root Port
[    5.139702] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x000fffff]
[    5.139723] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[    5.139741] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    5.139804] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
[    5.139823] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
[    5.139844] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff pref]
[    5.139904] pci 0000:00:00.0: supports D1
[    5.139919] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[    5.143829] pci 0000:00:00.0: BAR 0 [mem 0x18000000-0x180fffff]: assigned
[    5.143890] pci 0000:00:00.0: ROM [mem 0x18100000-0x1810ffff pref]: assigned
[    5.143916] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    5.143939] pci_bus 0000:00: resource 4 [io  0x0000-0xffff]
[    5.143995] pci_bus 0000:00: resource 5 [mem 0x18000000-0x1fefffff]
[    5.144023] pci 0000:00:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  128
[    5.144667] pcieport 0000:00:00.0: PME: Signaling with IRQ 206
[    5.145286] pcieport 0000:00:00.0: AER: enabled with IRQ 206
[    5.223030] random: crng init done
[    5.286461] samsung-dsim 32e60000.dsi: supply vddcore not found, using dummy regulator
[    5.286687] samsung-dsim 32e60000.dsi: supply vddio not found, using dummy regulator
[    5.303294] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[    5.303427] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[    5.304622] usbcore: registered new interface driver usbfs
[    5.304709] usbcore: registered new interface driver hub
[    5.304782] usbcore: registered new device driver usb
[    5.368191] imx-dwmac 30bf0000.ethernet: IRQ sfty not found
[    5.380856] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[    5.380911] imx-dwmac 30bf0000.ethernet: 	DWMAC4/5
[    5.380925] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[    5.380937] imx-dwmac 30bf0000.ethernet: Active PHY interface: RGMII (1)
[    5.380949] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[    5.380960] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[    5.380971] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[    5.381125] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    5.381148] imx-dwmac 30bf0000.ethernet: device MAC address f2:80:32:ce:d7:83
[    5.381162] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[    5.381174] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[    5.381199] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    5.381213] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device width
[    5.388829] mdio_bus stmmac-1: ethernet-phy has invalid PHY address
[    5.388871] mdio_bus stmmac-1: scan phy ethernet-phy at address 0
[    5.389238] mdio_bus stmmac-1: scan phy ethernet-phy at address 1
[    5.389543] mdio_bus stmmac-1: scan phy ethernet-phy at address 2
[    5.389821] mdio_bus stmmac-1: scan phy ethernet-phy at address 3
[    5.390069] mdio_bus stmmac-1: scan phy ethernet-phy at address 4
[    5.390312] mdio_bus stmmac-1: scan phy ethernet-phy at address 5
[    5.390549] mdio_bus stmmac-1: scan phy ethernet-phy at address 6
[    5.390787] mdio_bus stmmac-1: scan phy ethernet-phy at address 7
[    5.523921] imx-dwmac 30bf0000.ethernet end1: renamed from eth0
[    5.532384] imx8mp-dw-hdmi-tx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (SAMSUNG HDMI TX PHY)
[    5.533040] imx8mp-dw-hdmi-tx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[    5.576410] Registered IR keymap rc-cec
[    5.576588] rc rc0: dw_hdmi as /devices/platform/soc@0/32c00000.bus/32fd8000.hdmi/rc/rc0
[    5.576745] input: dw_hdmi as /devices/platform/soc@0/32c00000.bus/32fd8000.hdmi/rc/rc0/input0
[    5.676874] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    5.676927] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    5.677297] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x000080a001000010
[    5.677352] xhci-hcd xhci-hcd.0.auto: irq 210, io mem 0x38200000
[    5.677479] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    5.677497] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    5.677524] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    5.677771] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    5.677788] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.677802] usb usb1: Product: xHCI Host Controller
[    5.677813] usb usb1: Manufacturer: Linux 7.1.8-mnt-reform-arm64 xhci-hcd
[    5.677824] usb usb1: SerialNumber: xhci-hcd.0.auto
[    5.678334] hub 1-0:1.0: USB hub found
[    5.678382] hub 1-0:1.0: 1 port detected
[    5.678863] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.679061] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[    5.679082] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.679093] usb usb2: Product: xHCI Host Controller
[    5.679105] usb usb2: Manufacturer: Linux 7.1.8-mnt-reform-arm64 xhci-hcd
[    5.679115] usb usb2: SerialNumber: xhci-hcd.0.auto
[    5.679739] hub 2-0:1.0: USB hub found
[    5.679804] hub 2-0:1.0: 1 port detected
[    5.680369] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    5.680410] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    5.680789] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x000080a001000010
[    5.680857] xhci-hcd xhci-hcd.1.auto: irq 211, io mem 0x38100000
[    5.680990] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    5.681006] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    5.681029] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    5.681248] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[    5.681265] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.681276] usb usb3: Product: xHCI Host Controller
[    5.681285] usb usb3: Manufacturer: Linux 7.1.8-mnt-reform-arm64 xhci-hcd
[    5.681295] usb usb3: SerialNumber: xhci-hcd.1.auto
[    5.681867] hub 3-0:1.0: USB hub found
[    5.681930] hub 3-0:1.0: 1 port detected
[    5.682408] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.682549] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[    5.682565] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.682577] usb usb4: Product: xHCI Host Controller
[    5.682587] usb usb4: Manufacturer: Linux 7.1.8-mnt-reform-arm64 xhci-hcd
[    5.682600] usb usb4: SerialNumber: xhci-hcd.1.auto
[    5.683210] hub 4-0:1.0: USB hub found
[    5.683258] hub 4-0:1.0: 1 port detected
[    5.936302] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    6.083508] usb 3-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    6.083548] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    6.083563] usb 3-1: SerialNumber: 3C010061A4CD
[    6.104932] hid: raw HID events driver (C) Jiri Kosina
[    6.125128] usbcore: registered new interface driver usbhid
[    6.125168] usbhid: USB HID core driver
[    6.129613] hub 3-1:1.0: USB hub found
[    6.129766] hub 3-1:1.0: 4 ports detected
[    6.203315] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[    6.219810] usb 4-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[    6.219850] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    6.237895] usbcore: registered new device driver onboard-usb-dev
[    6.241830] hub 4-1:1.0: USB hub found
[    6.242251] hub 4-1:1.0: 4 ports detected
[    6.335687] mc: Linux media interface: v0.10
[    6.407915] videodev: Linux video capture interface: v2.00
[    6.479022] usb 3-1.3: new full-speed USB device number 3 using xhci-hcd
[    6.485800] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[    6.680456] usb 3-1.3: New USB device found, idVendor=1209, idProduct=6d06, bcdDevice= 0.01
[    6.680526] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.680542] usb 3-1.3: Product: Pocket Reform Input 2.0
[    6.680551] usb 3-1.3: Manufacturer: MNT
[    6.680560] usb 3-1.3: SerialNumber: DE625492030D5A2B
[    6.835737] input: MNT Pocket Reform Input 2.0 Keyboard as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input1
[    6.971242] input: MNT Pocket Reform Input 2.0 Mouse as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input2
[    6.971715] input: MNT Pocket Reform Input 2.0 as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input3
[    6.972001] hid-generic 0003:1209:6D06.0001: input,hidraw0: USB HID v1.11 Keyboard [MNT Pocket Reform Input 2.0] on usb-xhci-hcd.1.auto-1.3/input0
[    7.128194] SPI driver mnt_sc has no spi_device_id for mntre,system-controller
[    7.128345] mnt_sc spi1.0: MNT System Controller v4
[    7.129510] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] start...
[    7.129550] panel-mnt-pocket-reform 32e60000.dsi.0: DSI burst mode enabled via device tree
[    7.129633] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 1)
[    7.133071] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 8 0)
[    7.136420] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] jdi_panel_add done.
[    7.136476] samsung-dsim 32e60000.dsi: [drm:samsung_dsim_host_attach [samsung_dsim]] Attached lt070me05000 device (lanes:4 bpp:24 mode-flags:0x13)
[    7.136542] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] done.
[    7.387691] reform2_lpc: loading out-of-tree module taints kernel.
[    7.387748] reform2_lpc: module verification failed: signature and/or required key missing - tainting kernel
[    7.684897] EXT4-fs (mmcblk2p2): orphan cleanup on readonly fs
[    7.685140] EXT4-fs (mmcblk2p2): mounted filesystem 80e5956e-299d-4aff-b0ab-5443fff1732c ro with ordered data mode. Quota mode: none.
[    7.948813] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    8.072594] systemd[1]: System time advanced to built-in epoch: Thu 2026-07-23 11:31:52 PDT
[    8.157186] systemd[1]: Inserted module 'autofs4'
[    8.557968] systemd[1]: systemd 261.2-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +LIBARCHIVE)
[    8.558093] systemd[1]: Detected architecture arm64.
[    8.602079] systemd[1]: Hostname set to <arkilikos>.
[    8.845456] systemd[1]: bpf-restrict-fs: Failed to load BPF object: No such process
[    9.636480] systemd[1]: Queued start job for default target graphical.target.
[    9.660830] systemd[1]: Created slice system-cups.slice - CUPS Slice.
[    9.662779] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    9.664704] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    9.666610] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    9.668584] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    9.669865] systemd[1]: Created slice user.slice - User and Session Slice.
[    9.670283] systemd[1]: Started ntpsec-systemd-netif.path.
[    9.670592] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    9.670877] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    9.671671] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    9.672004] systemd[1]: Expecting device dev-mmcblk2p1.device - /dev/mmcblk2p1...
[    9.672162] systemd[1]: Expecting device dev-ttymxc1.device - /dev/ttymxc1...
[    9.672331] systemd[1]: Reached target imports.target - Image Downloads.
[    9.672522] systemd[1]: Reached target network-pre.target - Preparation for Network.
[    9.672688] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    9.672888] systemd[1]: Reached target slices.target - Slice Units.
[    9.673052] systemd[1]: Reached target swap.target - Swaps.
[    9.673538] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[    9.674004] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[    9.695923] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[    9.711565] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
[    9.716023] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    9.728559] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
[    9.729163] systemd[1]: Listening on systemd-hostnamed.socket - Hostname Service Socket.
[    9.729732] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    9.730345] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[    9.748963] systemd[1]: Listening on systemd-mute-console.socket - Console Output Muting Service Socket.
[    9.749598] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    9.750011] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    9.750483] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
[    9.756097] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    9.759497] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    9.762830] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    9.766036] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    9.786790] systemd[1]: tmp.mount: x-systemd.graceful-option=usrquota specified, but option is not available, suppressing.
[    9.812239] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[    9.812828] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS skipped, unmet condition check ConditionPathExists=/etc/krb5.keytab
[    9.816159] systemd[1]: Starting blk-availability.service - Availability of block devices...
[    9.836749] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    9.841005] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    9.847358] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[    9.847922] systemd[1]: modprobe@configfs.service - Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[    9.854285] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    9.854684] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[    9.860857] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    9.867181] systemd[1]: modprobe@fuse.service - Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[    9.871722] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    9.875913] systemd[1]: Starting modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics...
[    9.878068] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
[    9.878247] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[    9.913990] systemd[1]: Starting systemd-journald.service - Journal Service...
[    9.947216] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    9.950772] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    9.955258] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[    9.964047] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[   10.096818] systemd[1]: Finished blk-availability.service - Availability of block devices.
[   10.187154] Key type psk registered
[   10.193094] i2c_dev: i2c /dev entries driver
[   10.193444] EXT4-fs (mmcblk2p2): re-mounted 80e5956e-299d-4aff-b0ab-5443fff1732c r/w.
[   10.214679] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[   10.216057] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[   10.217792] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[   10.219174] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[   10.220507] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[   10.222248] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[   10.224603] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[   10.226064] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[   10.227928] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   10.234262] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   10.239919] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[   10.245426] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[   10.248103] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[   10.252522] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[   10.256807] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[   10.257192] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/fs/pstore
[   10.267603] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[   10.280082] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[   10.291295] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[   10.319940] systemd-journald[383]: Collecting audit messages is disabled.
[   10.367787] systemd[1]: modprobe@nvme_fabrics.service: Deactivated successfully.
[   10.368521] systemd[1]: Finished modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics.
[   10.434810] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   10.448612] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[   10.448880] device-mapper: uevent: version 1.0.3
[   10.451175] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[   10.488506] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[   10.493554] systemd[1]: Started systemd-journald.service - Journal Service.
[   10.588175] systemd-journald[383]: Received client request to flush runtime journal.
[   10.629505] systemd-journald[383]: /var/log/journal/4bd4a97f63fa4d1681b7d4d61de50883/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
[   10.631857] systemd-journald[383]: Rotating system journal.
[   12.667445] EXT4-fs (mmcblk2p1): mounted filesystem 235f1391-e471-4c7a-a506-c0a57df9fb95 r/w with ordered data mode. Quota mode: none.
[   12.888245] audit: type=1400 audit(1784831516.820:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=496 comm="apparmor_parser"
[   12.888310] audit: type=1400 audit(1784831516.820:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=497 comm="apparmor_parser"
[   12.893687] audit: type=1400 audit(1784831516.824:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=495 comm="apparmor_parser"
[   12.893732] audit: type=1400 audit(1784831516.824:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=494 comm="apparmor_parser"
[   12.958053] audit: type=1400 audit(1784831516.888:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=504 comm="apparmor_parser"
[   12.958127] audit: type=1400 audit(1784831516.888:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=505 comm="apparmor_parser"
[   12.958147] audit: type=1400 audit(1784831516.888:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=503 comm="apparmor_parser"
[   13.009531] audit: type=1400 audit(1784831516.940:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=508 comm="apparmor_parser"
[   13.012351] audit: type=1400 audit(1784831516.944:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=509 comm="apparmor_parser"
[   13.014151] audit: type=1400 audit(1784831516.944:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=510 comm="apparmor_parser"
[   13.210327] RPC: Registered named UNIX socket transport module.
[   13.210383] RPC: Registered udp transport module.
[   13.210393] RPC: Registered tcp transport module.
[   13.210400] RPC: Registered tcp-with-tls transport module.
[   13.210409] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.353118] CSCFG registered etm0
[   13.353153] coresight etm0: CPU0: etm v4.0 initialized
[   13.353809] CSCFG registered etm1
[   13.353838] coresight etm1: CPU1: etm v4.0 initialized
[   13.356491] CSCFG registered etm2
[   13.356512] coresight etm2: CPU2: etm v4.0 initialized
[   13.357410] CSCFG registered etm3
[   13.357428] coresight etm3: CPU3: etm v4.0 initialized
[   13.820487] optee: probing for conduit method.
[   13.820563] optee: revision 3.17 (0000000098499642)
[   13.835130] optee: dynamic shared memory is enabled
[   13.835529] optee: initialized driver
[   13.858158] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
[   13.858223] caam 30900000.crypto: job rings = 1, qi = 0
[   14.017194] dw100 32e30000.dwe: dw100 v4l2 m2m registered as /dev/video0
[   14.043773] [drm] Initialized imx-lcdif 1.0.0 for 32e80000.display-controller on minor 0
[   14.043950] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 0
[   14.174793] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_prepare] prepared: 0
[   14.174830] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_power_on] panel version: 0
[   14.281685] clk: failed to reparent clk_ext2 to audio_pll2_out: -22
[   14.297465] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_enable] enabled: 0 prepared: 1
[   14.297503] panel-mnt-pocket-reform 32e60000.dsi.0: [display] init in enable...
[   14.297507] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_init] enabled: 0 prepared: 1
[   14.297556] samsung-dsim 32e60000.dsi: response too long (1 > 15 bytes), stripping
[   14.297591] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_detect_version] read register 12a: 0x0
[   14.297596] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_detect_version] detected panel_version: 2
[   14.297600] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_power_on] panel version: 2
[   14.297611] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 0)
[   14.344164] Bluetooth: Core ver 2.22
[   14.346670] NET: Registered PF_BLUETOOTH protocol family
[   14.346685] Bluetooth: HCI device and connection manager initialized
[   14.346701] Bluetooth: HCI socket layer initialized
[   14.346707] Bluetooth: L2CAP socket layer initialized
[   14.346735] Bluetooth: SCO socket layer initialized
[   14.407025] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 1)
[   14.507366] etnaviv etnaviv: bound 38000000.gpu (ops gpu_ops [etnaviv])
[   14.518142] etnaviv etnaviv: bound 38008000.gpu (ops gpu_ops [etnaviv])
[   14.531136] etnaviv etnaviv: bound 38500000.npu (ops gpu_ops [etnaviv])
[   14.537922] etnaviv-gpu 38000000.gpu: model: GC7000, revision: 6204
[   14.539105] etnaviv-gpu 38008000.gpu: model: GC520, revision: 5341
[   14.539236] etnaviv-gpu 38500000.npu: model: GC8000, revision: 8002
[   14.539243] etnaviv-gpu 38500000.npu: etnaviv has been instantiated on a NPU, for which the UAPI is still experimental
[   14.554059] [drm] Initialized etnaviv 1.4.0 for etnaviv on minor 1
[   14.617760] hantro-vpu 38300000.video-codec: registered nxp,imx8mm-vpu-g1-dec as /dev/video1
[   14.648785] hantro-vpu 38310000.video-codec: registered nxp,imx8mq-vpu-g2-dec as /dev/video2
[   14.721902] OF: /sound-wwan: Read of boolean property 'simple-audio-card,bitclock-inversion' with a value.
[   14.853643] Bluetooth: HCI UART driver ver 2.3
[   14.853685] Bluetooth: HCI UART protocol H4 registered
[   14.853805] Bluetooth: HCI UART protocol LL registered
[   14.853814] Bluetooth: HCI UART protocol ATH3K registered
[   14.853846] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.854205] Bluetooth: HCI UART protocol Intel registered
[   14.854599] Bluetooth: HCI UART protocol Broadcom registered
[   14.854656] Bluetooth: HCI UART protocol QCA registered
[   14.854660] Bluetooth: HCI UART protocol AG6XX registered
[   14.854687] Bluetooth: HCI UART protocol Marvell registered
[   14.856449] Bluetooth: hci0: setting up ROME/QCA6390
[   15.062652] Bluetooth: hci0: Frame reassembly failed (-84)
[   15.286026] trusted_key: caam algorithms registered in /proc/crypto
[   15.286693] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[   15.286711] caam 30900000.crypto: registering rng-caam
[   15.286882] caam 30900000.crypto: rng crypto API alg registered prng-caam
[   15.327552] Bluetooth: hci0: QCA Product ID   :0x00000008
[   15.327573] Bluetooth: hci0: QCA SOC Version  :0x00000023
[   15.327586] Bluetooth: hci0: QCA ROM Version  :0x00000302
[   15.327590] Bluetooth: hci0: QCA Patch Version:0x00000111
[   15.327596] Bluetooth: hci0: QCA controller version 0x00230302
[   15.327600] Bluetooth: hci0: QCA Downloading qca/rampatch_00230302.bin
[   15.479878] Bluetooth: hci0: Frame reassembly failed (-84)
[   15.587030] Bluetooth: hci0: QCA Downloading qca/nvm_00230302.bin
[   15.786519] Bluetooth: hci0: QCA setup on UART is completed
[   20.958656] panel-mnt-pocket-reform 32e60000.dsi.0: [display v2] sent tables OK
[   21.058880] panel-mnt-pocket-reform 32e60000.dsi.0: [display v2] OK
[   21.058899] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 8 1)
[   21.062234] mnt_sc spi1.0: enabling PWM display backlight control by MNT System Controller.
[   21.069609] Console: switching to colour frame buffer device 120x37
[   21.182011] imx-lcdif 32e80000.display-controller: [drm] fb0: imx-lcdifdrmfb frame buffer device
[   21.184646] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[   21.191605] [drm] Initialized imx-lcdif 1.0.0 for 32fc6000.display-controller on minor 2
[   21.193843] imx-lcdif 32fc6000.display-controller: [drm] Cannot find any crtc or sizes
[   21.847330] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   21.854032] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   21.861154] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   21.867964] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   21.874110] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   21.989288] qcacld2: bad vermagic: kernel tainted.
[   21.994969] Disabling lock debugging due to kernel taint
[   22.052493] qcacld2: loading driver v4.5.25.57
[   22.064845] hifDeviceInserted: Dumping clocks (50000000,200000000)
[   22.273240] ol_download_firmware: chip_id:0x5020001 board_id:0x0
[   22.279942] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[   22.290288] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[   22.298013] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[   22.298037] ar6k_wlan mmc1:0001:1: Direct firmware load for qcacld2/bdwlan30.b00 failed with error -2
[   22.298048] __ol_transfer_bin_file: Failed to get qcacld2/bdwlan30.b00:-2
[   22.298051] __ol_transfer_bin_file: Trying to load default qcacld2/bdwlan30.bin
[   22.304138] Board extended Data download address: 0x0
[   22.333126] __ol_transfer_bin_file: Loading setup file qcacld2/qsetup30.bin
[   22.336195] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[   22.340705] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[   22.344989] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[   22.349226] ar6k_wlan mmc1:0001:1: Direct firmware load for qcacld2/qsetup30.bin failed with error -2
[   22.353333] __ol_transfer_bin_file: Failed to get qcacld2/qsetup30.bin:-2
[   22.454035] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   22.459081] Bluetooth: BNEP filters: protocol multicast
[   22.461575] Bluetooth: BNEP socket layer initialized
[   22.496404] Bluetooth: MGMT ver 1.23
[   22.531852] NET: Registered PF_ALG protocol family
[   22.672414] Bluetooth: hci0: setting up ROME/QCA6390
[   22.819320] NET: Registered PF_QIPCRTR protocol family
[   22.872403] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[   22.879096] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[   22.881609] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[   22.889890] Bluetooth: hci0: Frame reassembly failed (-84)
[   22.891193] ar6k_wlan mmc1:0001:1: Direct firmware load for wlan/qcacld2/wlan_mac.bin failed with error -2
[   22.894621] ------------[ cut here ]------------
[   22.900100] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:627:33
[   22.902503] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   22.905321] CPU: 0 UID: 0 PID: 783 Comm: insmod Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   22.905340] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   22.905343] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   22.905347] Call trace:
[   22.905350]  show_stack+0x20/0x40 (C)
[   22.905364]  dump_stack_lvl+0x60/0x80
[   22.905371]  dump_stack+0x18/0x24
[   22.905376]  ubsan_epilogue+0x10/0x48
[   22.905383]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   22.905391]  csrUpdateChannelList+0x578/0x828 [qcacld2]
[   22.906014]  csrStart+0x154/0x198 [qcacld2]
[   22.906568]  sme_Start+0x20/0x90 [qcacld2]
[   22.907167]  vos_start+0x90/0x198 [qcacld2]
[   22.907809]  hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[   22.908404]  ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[   22.908986]  hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[   22.909571]  hifDeviceInserted+0x210/0x828 [qcacld2]
[   22.910137]  sdio_bus_probe+0x134/0x1f0
[   22.910150]  really_probe+0xc8/0x3f0
[   22.910158]  __driver_probe_device+0x90/0x1b0
[   22.910164]  driver_probe_device+0x44/0x128
[   22.910169]  __driver_attach+0xd0/0x208
[   22.910175]  bus_for_each_dev+0x84/0xf0
[   22.910180]  driver_attach+0x2c/0x40
[   22.910185]  bus_add_driver+0x124/0x250
[   22.910190]  driver_register+0x70/0x138
[   22.910196]  __sdio_register_driver+0x38/0x78
[   22.910202]  HIFInit+0x80/0xc0 [qcacld2]
[   22.910780]  hif_register_driver+0x74/0xe0 [qcacld2]
[   22.911381]  hdd_hif_register_driver+0x44/0x90 [qcacld2]
[   22.911980]  hdd_module_init+0x104/0xf20 [qcacld2]
[   22.912565]  do_one_initcall+0x5c/0x478
[   22.912578]  do_init_module+0x5c/0x278
[   22.912586]  load_module+0x1d40/0x2698
[   22.912592]  init_module_from_file+0xe8/0x158
[   22.912599]  __arm64_sys_finit_module+0x1f8/0x388
[   22.912606]  invoke_syscall.constprop.0+0xac/0x110
[   22.912613]  el0_svc_common.constprop.0+0x40/0xf0
[   22.912618]  do_el0_svc+0x24/0x40
[   22.912623]  el0_svc+0x40/0x1b0
[   22.912631]  el0t_64_sync_handler+0xa0/0xe8
[   22.912637]  el0t_64_sync+0x198/0x1a0
[   22.918059] ---[ end trace ]---
[   22.993123] ------------[ cut here ]------------
[   22.993135] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:631:55
[   22.993145] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   22.993154] CPU: 0 UID: 0 PID: 783 Comm: insmod Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   22.993164] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   22.993167] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   22.993171] Call trace:
[   22.993174]  show_stack+0x20/0x40 (C)
[   22.993189]  dump_stack_lvl+0x60/0x80
[   22.993196]  dump_stack+0x18/0x24
[   22.993201]  ubsan_epilogue+0x10/0x48
[   22.993209]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   22.993218]  csrUpdateChannelList+0x550/0x828 [qcacld2]
[   22.993936]  csrStart+0x154/0x198 [qcacld2]
[   22.994583]  sme_Start+0x20/0x90 [qcacld2]
[   22.995188]  vos_start+0x90/0x198 [qcacld2]
[   22.995802]  hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[   22.996438]  ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[   22.997069]  hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[   22.997684]  hifDeviceInserted+0x210/0x828 [qcacld2]
[   22.998281]  sdio_bus_probe+0x134/0x1f0
[   22.998294]  really_probe+0xc8/0x3f0
[   22.998302]  __driver_probe_device+0x90/0x1b0
[   22.998308]  driver_probe_device+0x44/0x128
[   22.998313]  __driver_attach+0xd0/0x208
[   22.998319]  bus_for_each_dev+0x84/0xf0
[   22.998324]  driver_attach+0x2c/0x40
[   22.998330]  bus_add_driver+0x124/0x250
[   22.998335]  driver_register+0x70/0x138
[   22.998341]  __sdio_register_driver+0x38/0x78
[   22.998347]  HIFInit+0x80/0xc0 [qcacld2]
[   22.998941]  hif_register_driver+0x74/0xe0 [qcacld2]
[   22.999541]  hdd_hif_register_driver+0x44/0x90 [qcacld2]
[   23.000127]  hdd_module_init+0x104/0xf20 [qcacld2]
[   23.000745]  do_one_initcall+0x5c/0x478
[   23.000761]  do_init_module+0x5c/0x278
[   23.000770]  load_module+0x1d40/0x2698
[   23.000775]  init_module_from_file+0xe8/0x158
[   23.000781]  __arm64_sys_finit_module+0x1f8/0x388
[   23.000788]  invoke_syscall.constprop.0+0xac/0x110
[   23.000795]  el0_svc_common.constprop.0+0x40/0xf0
[   23.000800]  do_el0_svc+0x24/0x40
[   23.000805]  el0_svc+0x40/0x1b0
[   23.000813]  el0t_64_sync_handler+0xa0/0xe8
[   23.000819]  el0t_64_sync+0x198/0x1a0
[   23.001081] ---[ end trace ]---
[   23.001118] ------------[ cut here ]------------
[   23.001121] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:629:33
[   23.001140] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.001149] CPU: 0 UID: 0 PID: 783 Comm: insmod Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.001159] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.001162] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.001166] Call trace:
[   23.001169]  show_stack+0x20/0x40 (C)
[   23.001182]  dump_stack_lvl+0x60/0x80
[   23.001190]  dump_stack+0x18/0x24
[   23.001195]  ubsan_epilogue+0x10/0x48
[   23.001203]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.001211]  csrUpdateChannelList+0x5a0/0x828 [qcacld2]
[   23.001794]  csrStart+0x154/0x198 [qcacld2]
[   23.002296]  sme_Start+0x20/0x90 [qcacld2]
[   23.002798]  vos_start+0x90/0x198 [qcacld2]
[   23.003307]  hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[   23.003796]  ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[   23.004292]  hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[   23.004788]  hifDeviceInserted+0x210/0x828 [qcacld2]
[   23.005287]  sdio_bus_probe+0x134/0x1f0
[   23.005299]  really_probe+0xc8/0x3f0
[   23.005306]  __driver_probe_device+0x90/0x1b0
[   23.005312]  driver_probe_device+0x44/0x128
[   23.005318]  __driver_attach+0xd0/0x208
[   23.005323]  bus_for_each_dev+0x84/0xf0
[   23.005328]  driver_attach+0x2c/0x40
[   23.005334]  bus_add_driver+0x124/0x250
[   23.005338]  driver_register+0x70/0x138
[   23.005344]  __sdio_register_driver+0x38/0x78
[   23.005350]  HIFInit+0x80/0xc0 [qcacld2]
[   23.005849]  hif_register_driver+0x74/0xe0 [qcacld2]
[   23.006351]  hdd_hif_register_driver+0x44/0x90 [qcacld2]
[   23.006854]  hdd_module_init+0x104/0xf20 [qcacld2]
[   23.007357]  do_one_initcall+0x5c/0x478
[   23.007367]  do_init_module+0x5c/0x278
[   23.007375]  load_module+0x1d40/0x2698
[   23.007380]  init_module_from_file+0xe8/0x158
[   23.007387]  __arm64_sys_finit_module+0x1f8/0x388
[   23.007393]  invoke_syscall.constprop.0+0xac/0x110
[   23.007400]  el0_svc_common.constprop.0+0x40/0xf0
[   23.007405]  do_el0_svc+0x24/0x40
[   23.007410]  el0_svc+0x40/0x1b0
[   23.007417]  el0t_64_sync_handler+0xa0/0xe8
[   23.007423]  el0t_64_sync+0x198/0x1a0
[   23.007758] ---[ end trace ]---
[   23.007771] ------------[ cut here ]------------
[   23.007773] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:649:37
[   23.007779] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.007786] CPU: 0 UID: 0 PID: 783 Comm: insmod Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.007796] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.007798] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.007802] Call trace:
[   23.007805]  show_stack+0x20/0x40 (C)
[   23.007819]  dump_stack_lvl+0x60/0x80
[   23.007825]  dump_stack+0x18/0x24
[   23.007830]  ubsan_epilogue+0x10/0x48
[   23.007838]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.007846]  csrUpdateChannelList+0x764/0x828 [qcacld2]
[   23.008451]  csrStart+0x154/0x198 [qcacld2]
[   23.009029]  sme_Start+0x20/0x90 [qcacld2]
[   23.009598]  vos_start+0x90/0x198 [qcacld2]
[   23.010158]  hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[   23.010723]  ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[   23.011345]  hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[   23.011967]  hifDeviceInserted+0x210/0x828 [qcacld2]
[   23.012570]  sdio_bus_probe+0x134/0x1f0
[   23.012583]  really_probe+0xc8/0x3f0
[   23.012592]  __driver_probe_device+0x90/0x1b0
[   23.012599]  driver_probe_device+0x44/0x128
[   23.012605]  __driver_attach+0xd0/0x208
[   23.012610]  bus_for_each_dev+0x84/0xf0
[   23.012616]  driver_attach+0x2c/0x40
[   23.012621]  bus_add_driver+0x124/0x250
[   23.012626]  driver_register+0x70/0x138
[   23.012632]  __sdio_register_driver+0x38/0x78
[   23.012638]  HIFInit+0x80/0xc0 [qcacld2]
[   23.013261]  hif_register_driver+0x74/0xe0 [qcacld2]
[   23.013864]  hdd_hif_register_driver+0x44/0x90 [qcacld2]
[   23.014463]  hdd_module_init+0x104/0xf20 [qcacld2]
[   23.015055]  do_one_initcall+0x5c/0x478
[   23.015067]  do_init_module+0x5c/0x278
[   23.015076]  load_module+0x1d40/0x2698
[   23.015081]  init_module_from_file+0xe8/0x158
[   23.015088]  __arm64_sys_finit_module+0x1f8/0x388
[   23.015094]  invoke_syscall.constprop.0+0xac/0x110
[   23.015101]  el0_svc_common.constprop.0+0x40/0xf0
[   23.015107]  do_el0_svc+0x24/0x40
[   23.015111]  el0_svc+0x40/0x1b0
[   23.015119]  el0t_64_sync_handler+0xa0/0xe8
[   23.015125]  el0t_64_sync+0x198/0x1a0
[   23.015309] ---[ end trace ]---
[   23.168694] Bluetooth: hci0: QCA Product ID   :0x00000008
[   23.170562] ------------[ cut here ]------------
[   23.171730] Bluetooth: hci0: QCA SOC Version  :0x00000023
[   23.171764] Bluetooth: hci0: QCA ROM Version  :0x00000302
[   23.171769] Bluetooth: hci0: QCA Patch Version:0x00000111
[   23.171780] Bluetooth: hci0: QCA controller version 0x00230302
[   23.173532] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:651:37
[   23.174870] Bluetooth: hci0: QCA Downloading qca/rampatch_00230302.bin
[   23.240081] index 15 is out of range for type 'tSirUpdateChanParam [1]'
[   23.240103] CPU: 2 UID: 0 PID: 783 Comm: insmod Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.240114] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.240116] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.240121] Call trace:
[   23.240124]  show_stack+0x20/0x40 (C)
[   23.240140]  dump_stack_lvl+0x60/0x80
[   23.240147]  dump_stack+0x18/0x24
[   23.240152]  ubsan_epilogue+0x10/0x48
[   23.240160]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.240168]  csrUpdateChannelList+0x724/0x828 [qcacld2]
[   23.240873]  csrStart+0x154/0x198 [qcacld2]
[   23.241559]  sme_Start+0x20/0x90 [qcacld2]
[   23.242223]  vos_start+0x90/0x198 [qcacld2]
[   23.242869]  hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[   23.243525]  ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[   23.244160]  hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[   23.244794]  hifDeviceInserted+0x210/0x828 [qcacld2]
[   23.245421]  sdio_bus_probe+0x134/0x1f0
[   23.245434]  really_probe+0xc8/0x3f0
[   23.245443]  __driver_probe_device+0x90/0x1b0
[   23.245450]  driver_probe_device+0x44/0x128
[   23.245455]  __driver_attach+0xd0/0x208
[   23.245461]  bus_for_each_dev+0x84/0xf0
[   23.245466]  driver_attach+0x2c/0x40
[   23.245471]  bus_add_driver+0x124/0x250
[   23.245476]  driver_register+0x70/0x138
[   23.245482]  __sdio_register_driver+0x38/0x78
[   23.245488]  HIFInit+0x80/0xc0 [qcacld2]
[   23.246139]  hif_register_driver+0x74/0xe0 [qcacld2]
[   23.246777]  hdd_hif_register_driver+0x44/0x90 [qcacld2]
[   23.247413]  hdd_module_init+0x104/0xf20 [qcacld2]
[   23.248044]  do_one_initcall+0x5c/0x478
[   23.248057]  do_init_module+0x5c/0x278
[   23.248065]  load_module+0x1d40/0x2698
[   23.248071]  init_module_from_file+0xe8/0x158
[   23.248077]  __arm64_sys_finit_module+0x1f8/0x388
[   23.248084]  invoke_syscall.constprop.0+0xac/0x110
[   23.248091]  el0_svc_common.constprop.0+0x40/0xf0
[   23.248096]  do_el0_svc+0x24/0x40
[   23.248101]  el0_svc+0x40/0x1b0
[   23.248109]  el0t_64_sync_handler+0xa0/0xe8
[   23.248115]  el0t_64_sync+0x198/0x1a0
[   23.248327] ---[ end trace ]---
[   23.316227] ------------[ cut here ]------------
[   23.317816] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12543:41
[   23.319282] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.320687] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.320702] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.320705] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.320709] Call trace:
[   23.320712]  show_stack+0x20/0x40 (C)
[   23.320725]  dump_stack_lvl+0x60/0x80
[   23.320731]  dump_stack+0x18/0x24
[   23.320736]  ubsan_epilogue+0x10/0x48
[   23.320744]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.320987] target uses HTT version 3.60; host uses 3.28
[   23.320751]  wma_update_channel_list+0x254/0x300 [qcacld2]
[   23.321391]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.322059]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.322688]  kthread+0x134/0x150
[   23.322702]  ret_from_fork+0x10/0x20
[   23.322712] ---[ end trace ]---
[   23.324021] *** Warning: host/target HTT versions are different, though compatible!
[   23.349356] ------------[ cut here ]------------
[   23.351189] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12546:27
[   23.352963] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.354751] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.354769] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.354772] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.354777] Call trace:
[   23.354780]  show_stack+0x20/0x40 (C)
[   23.354793]  dump_stack_lvl+0x60/0x80
[   23.354800]  dump_stack+0x18/0x24
[   23.354805]  ubsan_epilogue+0x10/0x48
[   23.354812]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.354819]  wma_update_channel_list+0x2d0/0x300 [qcacld2]
[   23.355523]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.355984]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.356409]  kthread+0x134/0x150
[   23.356421]  ret_from_fork+0x10/0x20
[   23.356501] ---[ end trace ]---
[   23.385522] ------------[ cut here ]------------
[   23.385531] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12550:27
[   23.385538] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.385545] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.385555] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.385557] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.385561] Call trace:
[   23.385564]  show_stack+0x20/0x40 (C)
[   23.385576]  dump_stack_lvl+0x60/0x80
[   23.385583]  dump_stack+0x18/0x24
[   23.385587]  ubsan_epilogue+0x10/0x48
[   23.385594]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.385602]  wma_update_channel_list+0x270/0x300 [qcacld2]
[   23.386030] imx-dwmac 30bf0000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   23.386190]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.386750]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.387292]  kthread+0x134/0x150
[   23.387303]  ret_from_fork+0x10/0x20
[   23.387364] Bluetooth: hci0: Frame reassembly failed (-84)
[   23.387385] ---[ end trace ]---
[   23.387389] ------------[ cut here ]------------
[   23.387391] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12552:34
[   23.387396] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.387403] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.387412] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.387415] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.387418] Call trace:
[   23.387421]  show_stack+0x20/0x40 (C)
[   23.387431]  dump_stack_lvl+0x60/0x80
[   23.387436]  dump_stack+0x18/0x24
[   23.387441]  ubsan_epilogue+0x10/0x48
[   23.387448]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.387455]  wma_update_channel_list+0x2f0/0x300 [qcacld2]
[   23.387980]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.388479]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.388982]  kthread+0x134/0x150
[   23.388994]  ret_from_fork+0x10/0x20
[   23.389002] ---[ end trace ]---
[   23.389006] ------------[ cut here ]------------
[   23.389008] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12572:3
[   23.389014] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.389020] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.389029] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.389032] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.389035] Call trace:
[   23.389037]  show_stack+0x20/0x40 (C)
[   23.389045]  dump_stack_lvl+0x60/0x80
[   23.389050]  dump_stack+0x18/0x24
[   23.389055]  ubsan_epilogue+0x10/0x48
[   23.389061]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.389069]  wma_update_channel_list+0x2b0/0x300 [qcacld2]
[   23.389567]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.390056]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.390534]  kthread+0x134/0x150
[   23.390546]  ret_from_fork+0x10/0x20
[   23.390554] ---[ end trace ]---
[   23.390558] ------------[ cut here ]------------
[   23.390560] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12575:3
[   23.390565] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[   23.390572] CPU: 2 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   23.390582] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   23.390584] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   23.390587] Call trace:
[   23.390589]  show_stack+0x20/0x40 (C)
[   23.390597]  dump_stack_lvl+0x60/0x80
[   23.390602]  dump_stack+0x18/0x24
[   23.390607]  ubsan_epilogue+0x10/0x48
[   23.390614]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   23.390621]  wma_update_channel_list+0x290/0x300 [qcacld2]
[   23.391114]  wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[   23.391637]  VosMCThread+0x210/0x4c8 [qcacld2]
[   23.392075]  kthread+0x134/0x150
[   23.392087]  ret_from_fork+0x10/0x20
[   23.392168] ---[ end trace ]---
[   23.449790] imx-dwmac 30bf0000.ethernet end1: PHY [stmmac-1:07] driver [Micrel KSZ9031 Gigabit PHY] (irq=105)
[   23.491090] Bluetooth: hci0: QCA Downloading qca/nvm_00230302.bin
[   23.496313] imx-dwmac 30bf0000.ethernet end1: No Safety Features support found
[   23.547024] imx-dwmac 30bf0000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
[   23.547887] imx-dwmac 30bf0000.ethernet end1: registered PTP clock
[   23.551501] imx-dwmac 30bf0000.ethernet end1: configuring for phy/rgmii-id link mode
[   23.562343] Host SW:4.5.25.57, FW:0.0.0.136, HW:QCA93x7_REV1_1
[   23.595286] ENTER sme_set_btc_coex_dutycycle = 30
[   23.595305] ENTER sme_set_btc_coex_dutycycle =30
[   23.597510] ath_hif_sdio: HIF (Atheros/multi-bss)
[   23.603276] qcacld2: driver loaded in 1548000
[   23.912883] Bluetooth: hci0: QCA setup on UART is completed
[   24.204684] ------------[ cut here ]------------
[   24.206913] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiScan.c:5923:95
[   24.209210] index 8 is out of range for type 'tANI_U8 [8]'
[   24.223588] CPU: 1 UID: 0 PID: 794 Comm: wpa_supplicant Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   24.223619] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   24.223622] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   24.223627] Call trace:
[   24.223631]  show_stack+0x20/0x40 (C)
[   24.223649]  dump_stack_lvl+0x60/0x80
[   24.223656]  dump_stack+0x18/0x24
[   24.223661]  ubsan_epilogue+0x10/0x48
[   24.223670]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   24.223679]  csrSendMBScanReq+0x764/0x790 [qcacld2]
[   24.224522]  csrScanChannels+0x138/0x190 [qcacld2]
[   24.225299]  csrProcessScanCommand+0x1ec/0x3e0 [qcacld2]
[   24.226170]  smeProcessScanQueue+0x1c8/0x210 [qcacld2]
[   24.227043]  smeProcessCommand+0x1c4/0xbd0 [qcacld2]
[   24.227861]  smeProcessPendingQueue+0x30/0x50 [qcacld2]
[   24.228685]  csrQueueSmeCommand+0x244/0x2e0 [qcacld2]
[   24.229478]  csrScanRequest+0x4c0/0x938 [qcacld2]
[   24.230279]  sme_ScanRequest+0xb8/0x118 [qcacld2]
[   24.231087]  __wlan_hdd_cfg80211_scan+0x490/0x928 [qcacld2]
[   24.231930]  wlan_hdd_cfg80211_scan+0x3c/0x68 [qcacld2]
[   24.232746]  rdev_scan+0x44/0x290 [cfg80211]
[   24.233228]  cfg80211_scan+0x110/0x188 [cfg80211]
[   24.233674]  nl80211_trigger_scan+0x494/0x908 [cfg80211]
[   24.234061]  genl_family_rcv_msg_doit+0xec/0x160
[   24.234078]  genl_rcv_msg+0x214/0x298
[   24.234085]  netlink_rcv_skb+0x70/0x158
[   24.234092]  genl_rcv+0x3c/0x60
[   24.234098]  netlink_unicast+0x1ec/0x300
[   24.234104]  netlink_sendmsg+0x1ac/0x428
[   24.234110]  __sock_sendmsg+0x5c/0xc0
[   24.234117]  ____sys_sendmsg+0x250/0x2c0
[   24.234122]  ___sys_sendmsg+0xb0/0x110
[   24.234128]  __sys_sendmsg+0xa4/0x120
[   24.234135]  __arm64_sys_sendmsg+0x28/0x40
[   24.234141]  invoke_syscall.constprop.0+0xac/0x110
[   24.234149]  el0_svc_common.constprop.0+0x40/0xf0
[   24.234154]  do_el0_svc+0x24/0x40
[   24.234160]  el0_svc+0x40/0x1b0
[   24.234168]  el0t_64_sync_handler+0xa0/0xe8
[   24.234174]  el0t_64_sync+0x198/0x1a0
[   24.324904] ---[ end trace ]---
[   24.326494] ------------[ cut here ]------------
[   24.328301] UBSAN: array-index-out-of-bounds in CORE/MAC/src/pe/lim/limProcessSmeReqMessages.c:1349:51
[   24.329840] index 8 is out of range for type 'tANI_U8 [8]'
[   24.332400] CPU: 1 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   24.332427] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   24.332430] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   24.332435] Call trace:
[   24.332439]  show_stack+0x20/0x40 (C)
[   24.332456]  dump_stack_lvl+0x60/0x80
[   24.332463]  dump_stack+0x18/0x24
[   24.332468]  ubsan_epilogue+0x10/0x48
[   24.332477]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   24.332486]  __limProcessSmeScanReq+0xf34/0x1030 [qcacld2]
[   24.333270]  limProcessSmeReqMessages+0x12ec/0x31d8 [qcacld2]
[   24.334085]  limProcessNormalHddMsg+0xc4/0x138 [qcacld2]
[   24.334884]  limProcessMessages+0xaa8/0x2170 [qcacld2]
[   24.335692]  limMessageProcessor+0x120/0x1e8 [qcacld2]
[   24.336531]  peProcessMessages+0x4c/0x88 [qcacld2]
[   24.337450]  VosMCThread+0xf0/0x4c8 [qcacld2]
[   24.338287]  kthread+0x134/0x150
[   24.338304]  ret_from_fork+0x10/0x20
[   24.343169] ---[ end trace ]---
[   24.343244] ------------[ cut here ]------------
[   24.343247] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:11908:41
[   24.343259] index 8 is out of range for type 'tANI_U8 [8]'
[   24.343268] CPU: 1 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   24.343278] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   24.343281] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   24.343285] Call trace:
[   24.343289]  show_stack+0x20/0x40 (C)
[   24.343306]  dump_stack_lvl+0x60/0x80
[   24.343314]  dump_stack+0x18/0x24
[   24.343319]  ubsan_epilogue+0x10/0x48
[   24.343328]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   24.343336]  wma_get_buf_start_scan_cmd+0x944/0x9c0 [qcacld2]
[   24.344191]  wma_start_scan+0x88/0x2f8 [qcacld2]
[   24.345024]  wma_mc_process_msg+0x140/0x2e98 [qcacld2]
[   24.345833]  VosMCThread+0x210/0x4c8 [qcacld2]
[   24.346706]  kthread+0x134/0x150
[   24.346720]  ret_from_fork+0x10/0x20
[   24.346732] ---[ end trace ]---
[   25.334349] tun: Universal TUN/TAP device driver, 1.6
[   27.163360] ------------[ cut here ]------------
[   27.163409] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiScan.c:5665:42
[   27.163452] index 2 is out of range for type 'tLimScanChn [1]'
[   27.163467] CPU: 1 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   27.163478] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   27.163480] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   27.163485] Call trace:
[   27.163488]  show_stack+0x20/0x40 (C)
[   27.163503]  dump_stack_lvl+0x60/0x80
[   27.163511]  dump_stack+0x18/0x24
[   27.163516]  ubsan_epilogue+0x10/0x48
[   27.163526]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   27.163534]  csrScanAgeResults+0x190/0x1a0 [qcacld2]
[   27.164256]  csrScanSmeScanResponse+0x214/0x300 [qcacld2]
[   27.164926]  csrScanningStateMsgProcessor+0x44/0x3f0 [qcacld2]
[   27.165599]  csrMsgProcessor+0x1cc/0x4d0 [qcacld2]
[   27.166247]  sme_ProcessMsg+0xbbc/0xd38 [qcacld2]
[   27.166896]  VosMCThread+0x1e4/0x4c8 [qcacld2]
[   27.167543]  kthread+0x134/0x150
[   27.167555]  ret_from_fork+0x10/0x20
[   27.167658] ---[ end trace ]---
[   27.415788] ------------[ cut here ]------------
[   27.415840] UBSAN: array-index-out-of-bounds in CORE/SME/src/ccm/ccmApi.c:421:40
[   27.415865] index 1 is out of range for type 'tANI_U32 [1]'
[   27.415878] CPU: 3 UID: 0 PID: 804 Comm: VosMCThread Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   27.415888] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   27.415891] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   27.415895] Call trace:
[   27.415898]  show_stack+0x20/0x40 (C)
[   27.415911]  dump_stack_lvl+0x60/0x80
[   27.415918]  dump_stack+0x18/0x24
[   27.415923]  ubsan_epilogue+0x10/0x48
[   27.415931]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   27.415939]  ccmCfgCnfMsgHandler+0x64/0x330 [qcacld2]
[   27.416619]  sme_ProcessMsg+0xa88/0xd38 [qcacld2]
[   27.417237]  VosMCThread+0x1e4/0x4c8 [qcacld2]
[   27.417840]  kthread+0x134/0x150
[   27.417853]  ret_from_fork+0x10/0x20
[   27.417899] ---[ end trace ]---
[   27.492176] ------------[ cut here ]------------
[   27.492208] UBSAN: array-index-out-of-bounds in CORE/CLD_TXRX/HTT/htt_t2h.c:885:35
[   27.492217] index 1 is out of range for type 'A_UINT16 [1]'
[   27.492229] CPU: 1 UID: 0 PID: 849 Comm: AR6K RxCompleti Tainted: GF        C OE       7.1.8-mnt-reform-arm64 #1 PREEMPTLAZY  Debian 7.1.8-2+reform20260814T225949Z
[   27.492239] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[   27.492242] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[   27.492247] Call trace:
[   27.492249]  show_stack+0x20/0x40 (C)
[   27.492264]  dump_stack_lvl+0x60/0x80
[   27.492271]  dump_stack+0x18/0x24
[   27.492276]  ubsan_epilogue+0x10/0x48
[   27.492283]  __ubsan_handle_out_of_bounds+0x90/0xc0
[   27.492291]  htt_t2h_msg_handler+0x698/0x7c0 [qcacld2]
[   27.492899]  DoRecvCompletion.part.0+0x88/0x140 [qcacld2]
[   27.493444]  HTCRxCompletionHandler+0x62c/0x848 [qcacld2]
[   27.493980]  processHdrAndRxComp.part.0.isra.0+0x9c/0xd0 [qcacld2]
[   27.494562]  processHdrAndRxComp.constprop.0+0x5c/0x110 [qcacld2]
[   27.495236]  rx_completion_task+0x474/0x520 [qcacld2]
[   27.495922]  kthread+0x134/0x150
[   27.495934]  ret_from_fork+0x10/0x20
[   27.495944] ---[ end trace ]---
[   28.335421] Bluetooth: RFCOMM TTY layer initialized
[   28.335488] Bluetooth: RFCOMM socket layer initialized
[   28.335526] Bluetooth: RFCOMM ver 1.11
[   30.979807] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[   35.818595] rfkill: input handler disabled
[   38.111903] SCSI subsystem initialized
[   52.822281] rfkill: input handler enabled
[   54.782640] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
journal:
Jul 23 11:32:11.435040 arkilikos kernel:  ret_from_fork+0x10/0x20
Jul 23 11:32:11.435081 arkilikos kernel: ---[ end trace ]---
Jul 23 11:32:12.277597 arkilikos kernel: Bluetooth: RFCOMM TTY layer initialized
Jul 23 11:32:12.277808 arkilikos kernel: Bluetooth: RFCOMM socket layer initialized
Jul 23 11:32:12.277870 arkilikos kernel: Bluetooth: RFCOMM ver 1.11
Jul 23 11:32:14.918276 arkilikos kernel: panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
Jul 23 11:32:19.762473 arkilikos kernel: rfkill: input handler disabled
Aug 16 13:04:24.675450 arkilikos kernel: SCSI subsystem initialized
Aug 16 13:04:39.381800 arkilikos kernel: rfkill: input handler enabled
Aug 16 13:04:41.355244 arkilikos kernel: panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
lspci -nnvvv (detailed, capped 500 lines)
00:00.0 PCI bridge [0604]: Synopsys, Inc. DWC_usb3 / PCIe bridge [16c3:abcd] (rev 01) (prog-if 00 [Normal decode])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupts: pin B routed to IRQ 206
	Region 0: Memory at 18000000 (32-bit, non-prefetchable) [size=1M]
	Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
	I/O behind bridge: f000-0fff [disabled] [16-bit]
	Memory behind bridge: fff00000-000fffff [disabled] [32-bit]
	Prefetchable memory behind bridge: fff00000-000fffff [disabled] [32-bit]
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
	Expansion ROM at 18100000 [virtual] [disabled] [size=64K]
	BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold+)
		Status: D3 NoSoftRst- PME-Enable+ DSel=0 DScale=0 PME-
	Capabilities: [70] Express (v2) Root Port (Slot-), IntMsgNum 0
		DevCap:	MaxPayload 128 bytes, PhantFunc 0
			ExtTag- RBE+ TEE-IO-
		DevCtl:	CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 8GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <8us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt+ FltModeDis-
		LnkSta:	Speed 2.5GT/s, Width x1
			TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		RootCap: CRSVisible+
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible+
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP+ LTR-
			 10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
			 EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
			 FRS- LN System CLS Not Supported, TPHComp- ExtTPHComp- ARIFwd-
			 AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- ARIFwd-
			 AtomicOpsCtl: ReqEn- EgressBlck-
			 IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
			 10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
		LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
		LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
			 EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
			 Retimer- 2Retimers- CrosslinkRes: unsupported, FltMode-
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
			ECRC- UnsupReq- ACSViol- UncorrIntErr- BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
			PoisonTLPBlocked- DMWrReqBlocked- IDECheck- MisIDETLP- PCRC_CHECK- TLPXlatBlocked-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
			ECRC- UnsupReq- ACSViol- UncorrIntErr+ BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr- CorrIntErr- HeaderOF-
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr+ HeaderOF+
		AERCap:	First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
			MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
		HeaderLog: 00000000 00000000 00000000 00000000
		RootCmd: CERptEn+ NFERptEn+ FERptEn+
		RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
			 FirstFatal- NonFatalMsg- FatalMsg- IntMsgNum 0
		ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
	Capabilities: [148 v1] Secondary PCI Express
		LnkCtl3: LnkEquIntrruptEn- PerformEqu-
		LaneErrStat: 0
	Capabilities: [158 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1- L1_PM_Substates-
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
		L1SubCtl2:
	Kernel driver in use: pcieport
	Kernel modules: shpchp
PCIe link/ASPM details
00:00.0 PCI bridge: Synopsys, Inc. DWC_usb3 / PCIe bridge (rev 01) (prog-if 00 [Normal decode])
PCIe device sysfs summary
== 0000:00:00.0 ==
vendor=0x16c3 device=0xabcd class=0x060400 revision=0x01
max_link_speed=8.0 GT/s PCIe
current_link_speed=2.5 GT/s PCIe
max_link_width=1
current_link_width=1
remove=0
nvme list
Node                  Generic               SN                   Model                                    Namespace  Usage                      Format           FW Rev
NVMe module parameters (nvme_core)
admin_timeout = 60
apst_primary_latency_tol_us = 15000
apst_primary_timeout_ms = 100
apst_secondary_latency_tol_us = 100000
apst_secondary_timeout_ms = 2000
default_ps_max_latency_us = 0
disable_pi_offsets = N
force_apst = N
io_timeout = 30
iopolicy = numa
max_retries = 5
multipath = Y
multipath_always_on = N
shutdown_timeout = 5
NVMe transport parameters (nvme_tcp/fabrics)
Power & regulators
Power supply entries
== BAT0 ==
type: Battery
status: Not charging
capacity: 0
voltage_now: 0
current_now: 0
present: 1
charge_now: 0
Regulator summary (debugfs)
 regulator                      use open bypass  opmode voltage current     min     max
 regulator-dummy                 15   14      0 unknown     0mV     0mA     0mV     0mV
    32e60000.dsi-vddio            1                                 0mA     0mV     0mV
    32e60000.dsi-vddcore          1                                 0mA     0mV     0mV
    382f0040.usb-phy-vbus         1                                 0mA     0mV     0mV
    381f0040.usb-phy-vbus         1                                 0mA     0mV     0mV
    BUCK1                         1    0      0  normal   950mV     0mA   600mV  2187mV
    BUCK2                         2    1      0  normal   950mV     0mA   600mV  2187mV
       cpu0-cpu                   1                                 0mA   950mV   950mV
    BUCK4                         1    0      0  normal  3300mV     0mA   600mV  3400mV
    BUCK5                         1    0      0  normal  1800mV     0mA   600mV  3400mV
    BUCK6                         1    0      0  normal  1100mV     0mA   600mV  3400mV
    LDO1                          1    0      0 unknown  1800mV     0mA  1600mV  3300mV
    LDO2                          1    0      0 unknown   850mV     0mA   800mV  1150mV
    LDO3                          1    0      0 unknown  1800mV     0mA   800mV  3300mV
    LDO4                          1    0      0 unknown   900mV     0mA   800mV  3300mV
    LDO5                          1    0      0 unknown  1800mV     0mA  1800mV  3300mV
 5V                               6    5      0 unknown  5000mV     0mA  5000mV  5000mV
    2-0018-SPLVDD                 1                                 0mA     0mV     0mV
    2-0018-SPRVDD                 1                                 0mA     0mV     0mV
    USB_PWR                       1    0      0 unknown  5000mV     0mA  5000mV  5000mV
    1V2                           1    0      0 unknown  1200mV     0mA  1200mV  1200mV
    MPCIE_3V3                     3    3      0 unknown  3300mV     0mA  3300mV  3300mV
       33800000.pcie-vph          0                                 0mA     0mV     0mV
       33800000.pcie-vpcie        1                                 0mA     0mV     0mV
       phy-32f00000.pcie-phy.2-phy   1                                 0mA     0mV     0mV
 3V3                              7    7      0 unknown  3300mV     0mA  3300mV  3300mV
    2-0018-IOVDD                  1                                 0mA     0mV     0mV
    2-0018-AVDD                   1                                 0mA     0mV     0mV
    2-0018-HPVDD                  1                                 0mA     0mV     0mV
    30b40000.mmc-vqmmc            1                                 0mA     0mV     0mV
    30b40000.mmc-vmmc             0                                 0mA  3300mV  3400mV
    30b60000.mmc-vmmc             1                                 0mA  3300mV  3400mV
    1V8                           4    3      0 unknown  1800mV     0mA  1800mV  1800mV
       2-0018-DVDD                1                                 0mA     0mV     0mV
       30b50000.mmc-vqmmc         1                                 0mA     0mV     0mV
       30b60000.mmc-vqmmc         1                                 0mA     0mV     0mV
 reg_wlan_vmmc                    1    1      0 unknown  3300mV     0mA  3300mV  3300mV
    30b50000.mmc-vmmc             1                                 0mA  3300mV  3400mV
Regulator sysfs summary
== regulator.0 ==
name=regulator-dummy num_users=15 type=voltage
== regulator.1 ==
name=5V num_users=6 type=voltage microvolts=5000000
== regulator.10 ==
name=BUCK4 state=enabled num_users=1 type=voltage microvolts=3300000 min_microvolts=600000 max_microvolts=3400000
== regulator.11 ==
name=BUCK5 state=enabled num_users=1 type=voltage microvolts=1800000 min_microvolts=600000 max_microvolts=3400000
== regulator.12 ==
name=BUCK6 state=enabled num_users=1 type=voltage microvolts=1100000 min_microvolts=600000 max_microvolts=3400000
== regulator.13 ==
name=LDO1 state=enabled num_users=1 type=voltage microvolts=1800000 miBattery/AC via upower (if available)
Device: /org/freedesktop/UPower/devices/battery_BAT0
  native-path:          BAT0
  power supply:         yes
  updated:              Sun 16 Aug 2026 01:06:22 PM PDT (10 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               pending-charge
    warning-level:       none
    energy:              0 Wh
    energy-empty:        0 Wh
    energy-full:         40 Wh
    energy-full-design:  40 Wh
    energy-rate: n_microvolts=1600000 max_microvolts=3300000
== regulator.14 ==
name=LDO2 state=enabled num_users=1 type=voltage microvolts=850000 min_microvolts=800000 max_microvolts=1150000
== regulator.15 ==
name=LDO3 state=enabled num_users=1 type=voltage microvolts=1800000 min_microvolts=800000 max_microvolts=3300000
== regulator.16 ==
name=LDO4 state=enabled num_users=1 type=voltage microvolts=900000 min_microvolts=800000 max_microvolts=3300000
== regulator.17 ==
name=LDO5 state=enabled num_users=1 type=voltage microvolts=1800000 min_microvolts=1800000 max_microvolts=3300000
== regulator.2 ==
name=3V3 num_users=7 type=voltage microvolts=3300000
== regulator.3 ==
name=USB_PWR num_users=1 type=voltage microvolts=5000000
== regulator.4 ==
name=1V8 num_users=4 type=voltage microvolts=1800000
== regulator.5 ==
name=1V2 num_users=1 type=voltage microvolts=1200000
== regulator.6 ==
name=MPCIE_3V3 num_users=3 type=voltage microvolts=3300000
== regulator.7 ==
name=reg_wlan_vmmc state=enabled num_users=1 type=voltage microvolts=3300000
== regulator.8 ==
name=BUCK1 state=enabled num_users=1 type=voltage microvolts=950000 min_microvolts=600000 max_microvolts=2187500
== regulator.9 ==
name=BUCK2 state=enabled num_users=2 type=voltage microvolts=1000000 min_microvolts=600000 max_microvolts=2187500
This bug was fixed by this new firmware: I have a UART and an i.MX8MP MNT Pocket Reform that will not boot - #2 by josch
Awesome! I added the fixed tag to this thread.
