Pocket screen off after idle and can't get on again?
The issue that you are seeing in that WARNING is here:
pc : gpiod_set_value+0x3c/0x70
lr : jdi_panel_prepare+0xbc/0x170
gpiod_set_value() (the non-sleeping variant) contains a guard in gpiolib.c, WARN_ON(desc->gdev->can_sleep), with a comment to the effect of “should be using gpiod_set_value_cansleep()”. So the warning isn’t about a failed GPIO write. It’s gpiolib telling you that you called the atomic-context API on a GPIO whose backing controller is flagged can_sleep.
I updated the panel driver and I don’t see these warnings anymore. See the “prepare” and “unprepare” functions which all change: gpiod_set_value -> gpiod_set_value_cansleep.
Sadly, this didn’t get rid of the issue I was seeing with a blank screen, so I added more patches to play around with the timings a bit. That seems to have worked as I haven’t seen a blank screen in months. My guess is that some of these panels have a manufacturing defect small enough to nudge some of the timings out of wack. By poking at those values I was able to find a happy medium. This is just a guess as I’d need to disassemble and hook the panel up to a logic analyzer / scope to see if it’s an issue with the panel or the driver.
Hopefully that helps a bit, if nothing else, don’t chase that WARNING around. :slight_smile:
so the answer is just, to replace a bad panel, that or the driver needs like some sort of grace window or something to account for that if at all possible.
is a driver update with some sort of “grace period” like adding a few ms delay or maybe awaiting a response from the panel to confirm its done what it should regardless of timing a potential fix (if so can it just be from MNT’s side, and work for everyone, or do I need custom?) or do I just have to buy a new panel?
I think we have a few options.
  1. Do an A/B comparison with a second panel.
  2. Do an A/B comparison with a patched kernel.
  3. Debug with a scope/logic analyzer.
  4. Use a different panel.
I’ve started #2 on my panel and it seems to work. We’d need several folks with (and without) this issue to try it if we’re going to say for sure that it works. Then we’d need to cleanup the patches and narrow down exactly which changes make the difference. Even then, I wouldn’t try upstreaming this kind of code (i.e. linux-image-mnt-reform kernel).
I know that MNT is working on the MNT Vector (7inch tablet). My hope is that the display will be compatible with the pocket. I might try swaping it out once it is available. This will doubtless require some hardware updates unless MNT happens to have that exact thing in mind. :thinking:
i’m happy to try #2 if you can gimme a set of instructions for what exactly to do, how, and what you need from the results, in the meantime i’ll try and work towards getting a new panel, depends how much they are if I get a second of the same model and do option 1 or just go to option 4.
also why not upstream the fix? it would ensure nobody else has this issue and would ensure a seamless experience assuming we can patch it in such a manner that doesn’t have any adverse effects outside maybe a couple extra ms of latency.
edit: seems this is an exact (or near exact) replacement, so i’ll buy that when i can spare the cash since i’m saving for an original Reform with RK3588 to play a round of musical SOMs (love MNT for this) with it and the Pocket Reform, as well as a Steam Frame, so until then i’ll be ready and available to do option 2.
Happy to help. I’ll start with the easiest path and work up from there, since I’m not sure how comfortable you are with patching and compiling kernels.
Looks like you’re on the MNT Pocket Reform with BPI-CM4 Module. Same as me.
1. Try my Arch image (easiest). Grab an image from the release page of my Arch Linux build, burn it to an SD card, and boot it (instructions in the README). Run it a few days. If the issue doesn’t show up, that’s a decent test.
2. Boot a separate kernel on Debian. Use my pre-compiled kernel and modules with your existing install. You’ll need to build your own initramfs (e.g. sudo update-initramfs -c -k 7.0.13.reform1-aarch64), so you should know how your system boots and where the boot parts live.
3. Compile and patch your own kernel. Not “hard,” but time-consuming the first time. On the A311D it works, but expect ~4 hours to compile. See the Debian kernel handbook and docs.kernel.org. The patches you need are for MNT hardware and my messy driver patches (debugging + timing “fixes”).
DM me if you go with path 2 or 3 and want help. These paths and the MNT hardware can be a fun way to learn boot/kernel mechanics.
On upstreaming: if these patches work across multiple users/panels and we can clean them down to just fixes (no debug info), they could be a candidate. But it depends on the root cause. Generally, if only a subset of panels misbehave, upstreaming fixes for broken hardware isn’t good practice. A large manufacturer like BOE, Innolux, or AUO would work with their distributor to diagnose issues and either guarantee the panel meets spec or replace it.
gotta get some spare microSD cards but once i do i’ll try path 1 and get back to you when it’s flashed and if the issue appears. when i do, i assume i should install gnome and everything just like i have it now to reduce variables?
Sure. I’d set yourself up in a similar set of apps. It probably won’t matter but gnome is certainly a good way to test the display driver.
I’ll review the base install of arch this weekend. IIRC, it took a bit of work to get wifi or ethernet working.
Network manager is installed but wifi needs to be set up.
Also, there seems to be an issue with reform-hw-setup on Arch, so if you want to use ethernet you need to run that script agin.
yeah definitely, less variables is always better.
yeah i’m happy to tinker. luckily it reliably happens within a day, or when I check it the next morning, without fail, so I shouldn’t need to run too long, meaning it doesn’t have to be perfect, not by any means, only gotta work for like 3 days or so
alrighty gotcha, I can set those up, but I usually only use wifi.
thank you for the help, I’ll let you know as soon as I flash it
Seems after a long while I now got the dreaded no screen wakeup. Any idea what registers to dump?
Not sure what the display pipeline looks like on i.MX8MP.
Also not sure if this is related to u-boot which in turn can include some early firmware which provides power management capabilities.
hey, revoked my switch’s SD card privileges for path 1. how do I set up the wifi?
if the answer is rtfm (/j) then which page lol /lh
Try something like this, assuming your wifi is on wlan0:
/etc/systemd/network/25-wlan.network
[Match]
Name=wlan0
[Network]
DHCP=yes
Then enable/start network manager:
sudo systemctl enable --now NetworkManager
Then you can use nmtui to connect to your network.
If you run into any issues let me know and I’ll update my issue on GitHub so I can actually fix this issue. :slight_smile:
Sorry I mixed my services up there.
I think you can just enable NetworkManager and use nmtui without any config needed. I need to test that on the A311D which I can do later this week, as right now my RCM4 board has a rk3588s from Radxa in it. :slight_smile:
Anyway, just ignore the config above and nmtui should be able to set up the config you need for you.
hey just got back to this, didn’t realise i had to capitalise NetworkManager and used nmtui from there
it seemed to work fine, albeit with a slightly weird “flicker”
new issue: screen won’t come up properly on boot. gonna try reflashing SD card and starting from scratch
also i had a potential fix idea that, if nothing else, may serve as inspiration: since you said it’s a timings issue, and most monitors have a sort of vsync, i had the idea that if the interface these monitors have supports that, would it be possible to add in the driver or via systemd, on boot and maybe periodically like once every 24 hours after that, a vsync check, where it uses vsync for 5 minutes or x number of frames, averages the timings, and exports them to a variable for the driver to use? that would be unobtrusive, require minimal system resources, and fix it for everyone. if it were systemd based or even with something like a cronjob, that would also potentially enable the fix for custom screens (if the driver here is generic or multi-purpose) with, for example, OLED panels or another LCD like a sunlight readable one. that said i’m not sure if that’s the kind of issue it is, like if i’m thinking about it right, or if the driver can even pull from a variable like that without rebooting
Ah, that’s an issue with the latest mesa that debian patches:
Long story short, run PAN_MESA_DEBUG=noafbc sway instead of sway.
Let me know if the display does not come up on boot after several reboots. If that’s the case then my “fixes” might only be working for my panel.
Interesting idea. Let me ponder that concept a bit.
tried rebooting about 5 times, no dice.
while it was running it worked fine with gnome.
not sure that’d work since first thing i’m doing is enabling sudo, and installing gnome.
update: after a reflash, it worked fine, likely just some failure of bmaptool or the flashing process (when in doubt, re flash lol), or maybe i just messed something up with how i did things. it consistently locked and shut the screen off and come back on about a half dozen times but then finally locked up after a bit of sitting idle. that said, the screen did come back on after a reboot, so no issues there. i’m gonna try leaving it on overnight idle and see if that also makes it lock up. i need sleep now so i’m going to bed after this reply
also got dmesg for ya too from like right before it locked up (fair warning: it’s insanely long, and it’s already trimmed since a lot of it loops). if there’s other logs you want i’ll be back on forums in about 11-12 hours
[ 1636.711871] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] sent tables OK
[ 1636.711877] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1144 +1336712ms] pocket_display_v2_init: display_v2_init_count incremented to 3
[ 1636.711886] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1145 +1336712ms] jdi_dcs_exit_sleep_mode: issuing exit sleep mode
[ 1636.838602] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1146 +1336840ms] pocket_display_v2_init: post-exit-sleep delay complete
[ 1636.838614] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1147 +1336840ms] pocket_display_v2_init: probing panel runtime status registers
[ 1636.839630] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1636.840642] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1636.841652] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1636.842603] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1636.843615] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1636.843620] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1148 +1336844ms] jdi_dcs_set_display_on: issuing set display on
[ 1636.843626] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1149 +1336844ms] pocket_display_v2_init: probing panel runtime status registers
[ 1636.844638] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1636.845648] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1636.846583] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1636.847595] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1636.848606] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1636.848613] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1150 +1336848ms] pocket_display_v2_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1636.848619] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1151 +1336848ms] pocket_display_v2_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1636.848624] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1152 +1336848ms] pocket_display_v2_init: supplies: vddp=true iovcc=true
[ 1636.848633] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1153 +1336848ms] pocket_display_v2_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1636.848636] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] OK
[ 1636.848642] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1154 +1336848ms] jdi_panel_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1636.848646] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1155 +1336848ms] jdi_panel_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1636.848650] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1156 +1336848ms] jdi_panel_init: supplies: vddp=true iovcc=true
[ 1636.848655] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1157 +1336848ms] jdi_panel_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1636.848660] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1158 +1336848ms] jdi_panel_prepare: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1636.848665] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1159 +1336848ms] jdi_panel_prepare: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1636.848669] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1160 +1336848ms] jdi_panel_prepare: supplies: vddp=true iovcc=true
[ 1636.848673] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1161 +1336848ms] jdi_panel_prepare: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1636.848859] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1162 +1336848ms] jdi_panel_enable: enter
[ 1636.848864] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1163 +1336848ms] jdi_panel_enable: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1636.848869] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1164 +1336848ms] jdi_panel_enable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1636.848873] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1165 +1336848ms] jdi_panel_enable: supplies: vddp=true iovcc=true
[ 1636.848877] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1166 +1336848ms] jdi_panel_enable: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1636.848882] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1167 +1336848ms] jdi_panel_enable: forcing LPM for enable-time display on
[ 1636.848887] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1168 +1336848ms] jdi_panel_enable: probing panel runtime status registers
[ 1636.869612] meson-dw-mipi-dsi ffd07000.dsi: Timeout during read operation
[ 1636.869624] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a failed: -110
[ 1636.885613] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x94
[ 1636.903617] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x94
[ 1636.922583] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x94
[ 1636.940609] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x94
[ 1636.940630] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1169 +1336940ms] jdi_panel_enable: state: prepared=true enabled=true panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1636.940643] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1170 +1336940ms] jdi_panel_enable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1636.940655] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1171 +1336940ms] jdi_panel_enable: supplies: vddp=true iovcc=true
[ 1636.940669] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1172 +1336940ms] jdi_panel_enable: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1646.634438] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1173 +1346632ms] jdi_panel_disable: enter
[ 1646.634470] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1174 +1346632ms] jdi_panel_disable: state: prepared=true enabled=true panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1646.634483] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1175 +1346632ms] jdi_panel_disable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1646.634494] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1176 +1346632ms] jdi_panel_disable: supplies: vddp=true iovcc=true
[ 1646.634510] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1177 +1346632ms] jdi_panel_disable: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1646.634519] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1178 +1346632ms] jdi_dcs_set_display_off: issuing set display off
[ 1646.634531] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1179 +1346632ms] jdi_panel_disable: probing panel runtime status registers
[ 1646.641626] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1646.659603] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1646.677611] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1646.695537] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1646.714598] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1646.714617] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1180 +1346716ms] jdi_panel_disable: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1646.714630] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1181 +1346716ms] jdi_panel_disable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1646.714642] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1182 +1346716ms] jdi_panel_disable: supplies: vddp=true iovcc=true
[ 1646.714656] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1183 +1346716ms] jdi_panel_disable: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1646.714674] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1184 +1346716ms] jdi_panel_unprepare: enter
[ 1646.714686] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1185 +1346716ms] jdi_panel_unprepare: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1646.714696] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1186 +1346716ms] jdi_panel_unprepare: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1646.714705] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1187 +1346716ms] jdi_panel_unprepare: supplies: vddp=true iovcc=true
[ 1646.714714] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1188 +1346716ms] jdi_panel_unprepare: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1646.714728] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1189 +1346716ms] jdi_panel_unprepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1646.714737] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1190 +1346716ms] jdi_panel_unprepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1646.714746] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1191 +1346716ms] jdi_panel_unprepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1646.714757] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1192 +1346716ms] jdi_panel_unprepare: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1646.714767] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1193 +1346716ms] jdi_panel_unprepare: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1646.714776] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1194 +1346716ms] jdi_panel_unprepare: supplies: vddp=true iovcc=true
[ 1646.714784] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1195 +1346716ms] jdi_panel_unprepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1647.666611] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1196 +1347668ms] jdi_panel_prepare: enter
[ 1647.666642] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1197 +1347668ms] jdi_panel_prepare: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.666654] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1198 +1347668ms] jdi_panel_prepare: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.666665] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1199 +1347668ms] jdi_panel_prepare: supplies: vddp=true iovcc=true
[ 1647.666679] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1200 +1347668ms] jdi_panel_prepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1647.666692] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1201 +1347668ms] jdi_panel_prepare: enabling regulators
[ 1647.666731] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1202 +1347668ms] jdi_panel_prepare: sleeping 20ms after regulator enable before gpio sequencing
[ 1647.695003] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1203 +1347696ms] jdi_panel_prepare: 20ms post-regulator delay complete
[ 1647.695030] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1204 +1347696ms] jdi_panel_prepare: supplies: vddp=true iovcc=true
[ 1647.695044] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1205 +1347696ms] jdi_panel_prepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1647.695092] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1206 +1347696ms] jdi_panel_prepare: gpios: enable=0 reset=-2 dcdc_en=-2
[ 1647.695136] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1207 +1347696ms] jdi_panel_prepare: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.695176] panel-mnt-pocket-reform ffd07000.dsi.0: [display] init in prepare...
[ 1647.695183] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1208 +1347696ms] jdi_panel_init: enter
[ 1647.695195] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1209 +1347696ms] jdi_panel_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.695204] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1210 +1347696ms] jdi_panel_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.695213] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1211 +1347696ms] jdi_panel_init: supplies: vddp=true iovcc=true
[ 1647.695221] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1212 +1347696ms] jdi_panel_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.695229] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1213 +1347696ms] jdi_panel_init: sleeping 20ms before panel identification
[ 1647.720873] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1214 +1347720ms] jdi_panel_init: 20ms identify delay complete
[ 1647.720898] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1215 +1347720ms] jdi_panel_init: panel version selected: 2
[ 1647.720908] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1216 +1347720ms] pocket_display_v2_init: begin panel v2 init
[ 1647.720922] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1217 +1347720ms] pocket_display_v2_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=3 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.720934] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1218 +1347720ms] pocket_display_v2_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.720946] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1219 +1347720ms] pocket_display_v2_init: supplies: vddp=true iovcc=true
[ 1647.720961] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1220 +1347720ms] pocket_display_v2_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.720971] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1221 +1347720ms] jdi_dcs_soft_reset: issuing soft reset
[ 1647.720985] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1222 +1347720ms] pocket_display_v2_init: sleeping 20ms before panel identification
[ 1647.742643] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1223 +1347744ms] pocket_display_v2_init: 20ms identify delay complete
[ 1647.742670] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1224 +1347744ms] pocket_display_v2_init: post-soft-reset delay complete
[ 1647.742682] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1225 +1347744ms] pocket_display_v2_init: probing panel runtime status registers
[ 1647.743725] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1647.744763] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1647.745797] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1647.746622] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1647.747659] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1647.747678] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1226 +1347748ms] dsi_write_raw: tx tag=v2-0xE0 len=3 cmd=0xe0 payload[3]=e0 ab ba flags=0x2
[ 1647.747695] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1227 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE0 ret=7
[ 1647.747712] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1228 +1347748ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 01 flags=0x2
[ 1647.747727] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1229 +1347748ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.747743] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1230 +1347748ms] dsi_write_raw: tx tag=v2-0x83 len=2 cmd=0x83 payload[2]=83 16 flags=0x2
[ 1647.747759] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1231 +1347748ms] dsi_write_raw: tx complete tag=v2-0x83 ret=6
[ 1647.747775] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1232 +1347748ms] dsi_write_raw: tx tag=v2-0x90 len=2 cmd=0x90 payload[2]=90 81 flags=0x2
[ 1647.747790] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1233 +1347748ms] dsi_write_raw: tx complete tag=v2-0x90 ret=6
[ 1647.747807] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1234 +1347748ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 02 flags=0x2
[ 1647.747823] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1235 +1347748ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.747839] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1236 +1347748ms] dsi_write_raw: tx tag=v2-0x80 len=2 cmd=0x80 payload[2]=80 a0 flags=0x2
[ 1647.747854] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1237 +1347748ms] dsi_write_raw: tx complete tag=v2-0x80 ret=6
[ 1647.747870] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1238 +1347748ms] dsi_write_raw: tx tag=v2-0x81 len=2 cmd=0x81 payload[2]=81 50 flags=0x2
[ 1647.747885] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1239 +1347748ms] dsi_write_raw: tx complete tag=v2-0x81 ret=6
[ 1647.747901] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1240 +1347748ms] dsi_write_raw: tx tag=v2-0x82 len=2 cmd=0x82 payload[2]=82 50 flags=0x2
[ 1647.747917] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1241 +1347748ms] dsi_write_raw: tx complete tag=v2-0x82 ret=6
[ 1647.747933] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1242 +1347748ms] dsi_write_raw: tx tag=v2-0xA2 len=2 cmd=0xa2 payload[2]=a2 b0 flags=0x2
[ 1647.747948] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1243 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA2 ret=6
[ 1647.747964] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1244 +1347748ms] dsi_write_raw: tx tag=v2-0xA3 len=2 cmd=0xa3 payload[2]=a3 49 flags=0x2
[ 1647.747980] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1245 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA3 ret=6
[ 1647.747996] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1246 +1347748ms] dsi_write_raw: tx tag=v2-0xA4 len=2 cmd=0xa4 payload[2]=a4 6b flags=0x2
[ 1647.748011] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1247 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA4 ret=6
[ 1647.748027] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1248 +1347748ms] dsi_write_raw: tx tag=v2-0xA5 len=2 cmd=0xa5 payload[2]=a5 34 flags=0x2
[ 1647.748043] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1249 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA5 ret=6
[ 1647.748060] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1250 +1347748ms] dsi_write_raw: tx tag=v2-0xA6 len=2 cmd=0xa6 payload[2]=a6 22 flags=0x2
[ 1647.748075] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1251 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA6 ret=6
[ 1647.748091] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1252 +1347748ms] dsi_write_raw: tx tag=v2-0xA7 len=2 cmd=0xa7 payload[2]=a7 34 flags=0x2
[ 1647.748107] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1253 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA7 ret=6
[ 1647.748122] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1254 +1347748ms] dsi_write_raw: tx tag=v2-0xA8 len=2 cmd=0xa8 payload[2]=a8 22 flags=0x2
[ 1647.748138] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1255 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA8 ret=6
[ 1647.748154] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1256 +1347748ms] dsi_write_raw: tx tag=v2-0xA9 len=2 cmd=0xa9 payload[2]=a9 51 flags=0x2
[ 1647.748170] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1257 +1347748ms] dsi_write_raw: tx complete tag=v2-0xA9 ret=6
[ 1647.748186] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1258 +1347748ms] dsi_write_raw: tx tag=v2-0xAA len=2 cmd=0xaa payload[2]=aa d4 flags=0x2
[ 1647.748201] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1259 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAA ret=6
[ 1647.748217] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1260 +1347748ms] dsi_write_raw: tx tag=v2-0xAB len=2 cmd=0xab payload[2]=ab a6 flags=0x2
[ 1647.748232] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1261 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAB ret=6
[ 1647.748248] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1262 +1347748ms] dsi_write_raw: tx tag=v2-0xAC len=2 cmd=0xac payload[2]=ac 05 flags=0x2
[ 1647.748264] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1263 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAC ret=6
[ 1647.748280] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1264 +1347748ms] dsi_write_raw: tx tag=v2-0xAD len=2 cmd=0xad payload[2]=ad ab flags=0x2
[ 1647.748295] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1265 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAD ret=6
[ 1647.748312] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1266 +1347748ms] dsi_write_raw: tx tag=v2-0xAE len=2 cmd=0xae payload[2]=ae 3b flags=0x2
[ 1647.748327] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1267 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAE ret=6
[ 1647.748343] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1268 +1347748ms] dsi_write_raw: tx tag=v2-0xAF len=2 cmd=0xaf payload[2]=af 1b flags=0x2
[ 1647.748358] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1269 +1347748ms] dsi_write_raw: tx complete tag=v2-0xAF ret=6
[ 1647.748375] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1270 +1347748ms] dsi_write_raw: tx tag=v2-0xB0 len=2 cmd=0xb0 payload[2]=b0 1e flags=0x2
[ 1647.748390] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1271 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB0 ret=6
[ 1647.748406] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1272 +1347748ms] dsi_write_raw: tx tag=v2-0xB1 len=2 cmd=0xb1 payload[2]=b1 ab flags=0x2
[ 1647.748421] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1273 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB1 ret=6
[ 1647.748437] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1274 +1347748ms] dsi_write_raw: tx tag=v2-0xB2 len=2 cmd=0xb2 payload[2]=b2 c1 flags=0x2
[ 1647.748453] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1275 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB2 ret=6
[ 1647.748469] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1276 +1347748ms] dsi_write_raw: tx tag=v2-0xB3 len=2 cmd=0xb3 payload[2]=b3 22 flags=0x2
[ 1647.748484] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1277 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB3 ret=6
[ 1647.748500] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1278 +1347748ms] dsi_write_raw: tx tag=v2-0xB4 len=2 cmd=0xb4 payload[2]=b4 ff flags=0x2
[ 1647.748516] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1279 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB4 ret=6
[ 1647.748532] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1280 +1347748ms] dsi_write_raw: tx tag=v2-0xB5 len=2 cmd=0xb5 payload[2]=b5 cc flags=0x2
[ 1647.748548] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1281 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB5 ret=6
[ 1647.748564] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1282 +1347748ms] dsi_write_raw: tx tag=v2-0xB6 len=2 cmd=0xb6 payload[2]=b6 23 flags=0x2
[ 1647.748579] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1283 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB6 ret=6
[ 1647.748596] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1284 +1347748ms] dsi_write_raw: tx tag=v2-0xB7 len=2 cmd=0xb7 payload[2]=b7 01 flags=0x2
[ 1647.748611] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1285 +1347748ms] dsi_write_raw: tx complete tag=v2-0xB7 ret=6
[ 1647.748627] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1286 +1347748ms] dsi_write_raw: tx tag=v2-0xBF len=2 cmd=0xbf payload[2]=bf 00 flags=0x2
[ 1647.748642] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1287 +1347748ms] dsi_write_raw: tx complete tag=v2-0xBF ret=6
[ 1647.748658] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1288 +1347748ms] dsi_write_raw: tx tag=v2-0xC0 len=2 cmd=0xc0 payload[2]=c0 0e flags=0x2
[ 1647.748674] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1289 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC0 ret=6
[ 1647.748690] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1290 +1347748ms] dsi_write_raw: tx tag=v2-0xC1 len=2 cmd=0xc1 payload[2]=c1 00 flags=0x2
[ 1647.748705] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1291 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC1 ret=6
[ 1647.748721] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1292 +1347748ms] dsi_write_raw: tx tag=v2-0xC2 len=2 cmd=0xc2 payload[2]=c2 ff flags=0x2
[ 1647.748736] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1293 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC2 ret=6
[ 1647.748752] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1294 +1347748ms] dsi_write_raw: tx tag=v2-0xC3 len=2 cmd=0xc3 payload[2]=c3 08 flags=0x2
[ 1647.748767] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1295 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC3 ret=6
[ 1647.748783] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1296 +1347748ms] dsi_write_raw: tx tag=v2-0xC5 len=2 cmd=0xc5 payload[2]=c5 ff flags=0x2
[ 1647.748798] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1297 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC5 ret=6
[ 1647.748814] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1298 +1347748ms] dsi_write_raw: tx tag=v2-0xC7 len=2 cmd=0xc7 payload[2]=c7 00 flags=0x2
[ 1647.748830] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1299 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC7 ret=6
[ 1647.748846] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1300 +1347748ms] dsi_write_raw: tx tag=v2-0xC8 len=2 cmd=0xc8 payload[2]=c8 05 flags=0x2
[ 1647.748861] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1301 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC8 ret=6
[ 1647.748877] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1302 +1347748ms] dsi_write_raw: tx tag=v2-0xC9 len=2 cmd=0xc9 payload[2]=c9 12 flags=0x2
[ 1647.748893] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1303 +1347748ms] dsi_write_raw: tx complete tag=v2-0xC9 ret=6
[ 1647.748909] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1304 +1347748ms] dsi_write_raw: tx tag=v2-0xCA len=2 cmd=0xca payload[2]=ca 29 flags=0x2
[ 1647.748924] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1305 +1347748ms] dsi_write_raw: tx complete tag=v2-0xCA ret=6
[ 1647.748940] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1306 +1347748ms] dsi_write_raw: tx tag=v2-0xCB len=2 cmd=0xcb payload[2]=cb 41 flags=0x2
[ 1647.748956] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1307 +1347748ms] dsi_write_raw: tx complete tag=v2-0xCB ret=6
[ 1647.748971] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1308 +1347748ms] dsi_write_raw: tx tag=v2-0xCE len=2 cmd=0xce payload[2]=ce 06 flags=0x2
[ 1647.748987] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1309 +1347748ms] dsi_write_raw: tx complete tag=v2-0xCE ret=6
[ 1647.749003] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1310 +1347748ms] dsi_write_raw: tx tag=v2-0xD1 len=2 cmd=0xd1 payload[2]=d1 7f flags=0x2
[ 1647.749018] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1311 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD1 ret=6
[ 1647.749034] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1312 +1347748ms] dsi_write_raw: tx tag=v2-0xD2 len=2 cmd=0xd2 payload[2]=d2 6a flags=0x2
[ 1647.749049] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1313 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD2 ret=6
[ 1647.749065] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1314 +1347748ms] dsi_write_raw: tx tag=v2-0xD3 len=2 cmd=0xd3 payload[2]=d3 63 flags=0x2
[ 1647.749081] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1315 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD3 ret=6
[ 1647.749097] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1316 +1347748ms] dsi_write_raw: tx tag=v2-0xD4 len=2 cmd=0xd4 payload[2]=d4 63 flags=0x2
[ 1647.749112] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1317 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD4 ret=6
[ 1647.749128] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1318 +1347748ms] dsi_write_raw: tx tag=v2-0xD5 len=2 cmd=0xd5 payload[2]=d5 61 flags=0x2
[ 1647.749144] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1319 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD5 ret=6
[ 1647.749159] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1320 +1347748ms] dsi_write_raw: tx tag=v2-0xD6 len=2 cmd=0xd6 payload[2]=d6 61 flags=0x2
[ 1647.749175] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1321 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD6 ret=6
[ 1647.749191] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1322 +1347748ms] dsi_write_raw: tx tag=v2-0xD7 len=2 cmd=0xd7 payload[2]=d7 5d flags=0x2
[ 1647.749206] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1323 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD7 ret=6
[ 1647.749222] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1324 +1347748ms] dsi_write_raw: tx tag=v2-0xD8 len=2 cmd=0xd8 payload[2]=d8 5b flags=0x2
[ 1647.749237] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1325 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD8 ret=6
[ 1647.749253] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1326 +1347748ms] dsi_write_raw: tx tag=v2-0xD9 len=2 cmd=0xd9 payload[2]=d9 55 flags=0x2
[ 1647.749269] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1327 +1347748ms] dsi_write_raw: tx complete tag=v2-0xD9 ret=6
[ 1647.749284] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1328 +1347748ms] dsi_write_raw: tx tag=v2-0xDA len=2 cmd=0xda payload[2]=da 4d flags=0x2
[ 1647.749300] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1329 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDA ret=6
[ 1647.749316] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1330 +1347748ms] dsi_write_raw: tx tag=v2-0xDB len=2 cmd=0xdb payload[2]=db 4b flags=0x2
[ 1647.749331] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1331 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDB ret=6
[ 1647.749347] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1332 +1347748ms] dsi_write_raw: tx tag=v2-0xDC len=2 cmd=0xdc payload[2]=dc 49 flags=0x2
[ 1647.749362] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1333 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDC ret=6
[ 1647.749378] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1334 +1347748ms] dsi_write_raw: tx tag=v2-0xDD len=2 cmd=0xdd payload[2]=dd 47 flags=0x2
[ 1647.749393] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1335 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDD ret=6
[ 1647.749410] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1336 +1347748ms] dsi_write_raw: tx tag=v2-0xDE len=2 cmd=0xde payload[2]=de 43 flags=0x2
[ 1647.749425] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1337 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDE ret=6
[ 1647.749441] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1338 +1347748ms] dsi_write_raw: tx tag=v2-0xDF len=2 cmd=0xdf payload[2]=df 27 flags=0x2
[ 1647.749456] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1339 +1347748ms] dsi_write_raw: tx complete tag=v2-0xDF ret=6
[ 1647.749472] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1340 +1347748ms] dsi_write_raw: tx tag=v2-0xE0 len=2 cmd=0xe0 payload[2]=e0 14 flags=0x2
[ 1647.749487] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1341 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE0 ret=6
[ 1647.749503] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1342 +1347748ms] dsi_write_raw: tx tag=v2-0xE1 len=2 cmd=0xe1 payload[2]=e1 00 flags=0x2
[ 1647.749518] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1343 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE1 ret=6
[ 1647.749534] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1344 +1347748ms] dsi_write_raw: tx tag=v2-0xE2 len=2 cmd=0xe2 payload[2]=e2 7f flags=0x2
[ 1647.749550] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1345 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE2 ret=6
[ 1647.749566] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1346 +1347748ms] dsi_write_raw: tx tag=v2-0xE3 len=2 cmd=0xe3 payload[2]=e3 6a flags=0x2
[ 1647.749581] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1347 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE3 ret=6
[ 1647.749597] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1348 +1347748ms] dsi_write_raw: tx tag=v2-0xE4 len=2 cmd=0xe4 payload[2]=e4 63 flags=0x2
[ 1647.749612] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1349 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE4 ret=6
[ 1647.749628] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1350 +1347748ms] dsi_write_raw: tx tag=v2-0xE5 len=2 cmd=0xe5 payload[2]=e5 63 flags=0x2
[ 1647.749643] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1351 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE5 ret=6
[ 1647.749659] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1352 +1347748ms] dsi_write_raw: tx tag=v2-0xE6 len=2 cmd=0xe6 payload[2]=e6 61 flags=0x2
[ 1647.749674] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1353 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE6 ret=6
[ 1647.749690] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1354 +1347748ms] dsi_write_raw: tx tag=v2-0xE7 len=2 cmd=0xe7 payload[2]=e7 61 flags=0x2
[ 1647.749706] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1355 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE7 ret=6
[ 1647.749722] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1356 +1347748ms] dsi_write_raw: tx tag=v2-0xE8 len=2 cmd=0xe8 payload[2]=e8 5d flags=0x2
[ 1647.749737] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1357 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE8 ret=6
[ 1647.749753] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1358 +1347748ms] dsi_write_raw: tx tag=v2-0xE9 len=2 cmd=0xe9 payload[2]=e9 5b flags=0x2
[ 1647.749768] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1359 +1347748ms] dsi_write_raw: tx complete tag=v2-0xE9 ret=6
[ 1647.749784] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1360 +1347748ms] dsi_write_raw: tx tag=v2-0xEA len=2 cmd=0xea payload[2]=ea 55 flags=0x2
[ 1647.749799] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1361 +1347748ms] dsi_write_raw: tx complete tag=v2-0xEA ret=6
[ 1647.749816] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1362 +1347748ms] dsi_write_raw: tx tag=v2-0xEB len=2 cmd=0xeb payload[2]=eb 4d flags=0x2
[ 1647.749831] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1363 +1347748ms] dsi_write_raw: tx complete tag=v2-0xEB ret=6
[ 1647.749847] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1364 +1347748ms] dsi_write_raw: tx tag=v2-0xEC len=2 cmd=0xec payload[2]=ec 4b flags=0x2
[ 1647.749862] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1365 +1347748ms] dsi_write_raw: tx complete tag=v2-0xEC ret=6
[ 1647.749878] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1366 +1347748ms] dsi_write_raw: tx tag=v2-0xED len=2 cmd=0xed payload[2]=ed 49 flags=0x2
[ 1647.749894] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1367 +1347748ms] dsi_write_raw: tx complete tag=v2-0xED ret=6
[ 1647.749909] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1368 +1347748ms] dsi_write_raw: tx tag=v2-0xEE len=2 cmd=0xee payload[2]=ee 47 flags=0x2
[ 1647.749925] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1369 +1347748ms] dsi_write_raw: tx complete tag=v2-0xEE ret=6
[ 1647.749941] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1370 +1347748ms] dsi_write_raw: tx tag=v2-0xEF len=2 cmd=0xef payload[2]=ef 43 flags=0x2
[ 1647.749956] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1371 +1347748ms] dsi_write_raw: tx complete tag=v2-0xEF ret=6
[ 1647.749972] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1372 +1347748ms] dsi_write_raw: tx tag=v2-0xF0 len=2 cmd=0xf0 payload[2]=f0 27 flags=0x2
[ 1647.749987] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1373 +1347748ms] dsi_write_raw: tx complete tag=v2-0xF0 ret=6
[ 1647.750003] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1374 +1347748ms] dsi_write_raw: tx tag=v2-0xF1 len=2 cmd=0xf1 payload[2]=f1 14 flags=0x2
[ 1647.750018] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1375 +1347748ms] dsi_write_raw: tx complete tag=v2-0xF1 ret=6
[ 1647.750035] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1376 +1347748ms] dsi_write_raw: tx tag=v2-0xF2 len=2 cmd=0xf2 payload[2]=f2 00 flags=0x2
[ 1647.750050] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1377 +1347748ms] dsi_write_raw: tx complete tag=v2-0xF2 ret=6
[ 1647.750066] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1378 +1347748ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 03 flags=0x2
[ 1647.750081] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1379 +1347748ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.750097] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1380 +1347748ms] dsi_write_raw: tx tag=v2-0x9D len=2 cmd=0x9d payload[2]=9d 00 flags=0x2
[ 1647.750112] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1381 +1347748ms] dsi_write_raw: tx complete tag=v2-0x9D ret=6
[ 1647.750128] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1382 +1347748ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 04 flags=0x2
[ 1647.750143] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1383 +1347748ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.750159] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1384 +1347748ms] dsi_write_raw: tx tag=v2-0x80 len=2 cmd=0x80 payload[2]=80 cd flags=0x2
[ 1647.750174] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1385 +1347748ms] dsi_write_raw: tx complete tag=v2-0x80 ret=6
[ 1647.750190] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1386 +1347748ms] dsi_write_raw: tx tag=v2-0x81 len=2 cmd=0x81 payload[2]=81 cb flags=0x2
[ 1647.750205] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1387 +1347748ms] dsi_write_raw: tx complete tag=v2-0x81 ret=6
[ 1647.750221] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1388 +1347748ms] dsi_write_raw: tx tag=v2-0x82 len=2 cmd=0x82 payload[2]=82 a9 flags=0x2
[ 1647.750236] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1389 +1347748ms] dsi_write_raw: tx complete tag=v2-0x82 ret=6
[ 1647.750252] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1390 +1347748ms] dsi_write_raw: tx tag=v2-0x83 len=2 cmd=0x83 payload[2]=83 8c flags=0x2
[ 1647.750267] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1391 +1347748ms] dsi_write_raw: tx complete tag=v2-0x83 ret=6
[ 1647.750283] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1392 +1347748ms] dsi_write_raw: tx tag=v2-0x84 len=2 cmd=0x84 payload[2]=84 46 flags=0x2
[ 1647.750298] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1393 +1347748ms] dsi_write_raw: tx complete tag=v2-0x84 ret=6
[ 1647.750314] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1394 +1347748ms] dsi_write_raw: tx tag=v2-0x85 len=2 cmd=0x85 payload[2]=85 66 flags=0x2
[ 1647.750330] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1395 +1347748ms] dsi_write_raw: tx complete tag=v2-0x85 ret=6
[ 1647.750346] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1396 +1347748ms] dsi_write_raw: tx tag=v2-0x86 len=2 cmd=0x86 payload[2]=86 66 flags=0x2
[ 1647.750361] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1397 +1347748ms] dsi_write_raw: tx complete tag=v2-0x86 ret=6
[ 1647.750377] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1398 +1347748ms] dsi_write_raw: tx tag=v2-0x87 len=2 cmd=0x87 payload[2]=87 64 flags=0x2
[ 1647.750392] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1399 +1347748ms] dsi_write_raw: tx complete tag=v2-0x87 ret=6
[ 1647.750408] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1400 +1347748ms] dsi_write_raw: tx tag=v2-0x88 len=2 cmd=0x88 payload[2]=88 a0 flags=0x2
[ 1647.750424] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1401 +1347748ms] dsi_write_raw: tx complete tag=v2-0x88 ret=6
[ 1647.750440] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1402 +1347748ms] dsi_write_raw: tx tag=v2-0x89 len=2 cmd=0x89 payload[2]=89 08 flags=0x2
[ 1647.750455] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1403 +1347748ms] dsi_write_raw: tx complete tag=v2-0x89 ret=6
[ 1647.750471] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1404 +1347748ms] dsi_write_raw: tx tag=v2-0x8A len=2 cmd=0x8a payload[2]=8a a0 flags=0x2
[ 1647.750486] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1405 +1347748ms] dsi_write_raw: tx complete tag=v2-0x8A ret=6
[ 1647.750503] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1406 +1347748ms] dsi_write_raw: tx tag=v2-0x8B len=2 cmd=0x8b payload[2]=8b 08 flags=0x2
[ 1647.750518] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1407 +1347748ms] dsi_write_raw: tx complete tag=v2-0x8B ret=6
[ 1647.750534] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1408 +1347748ms] dsi_write_raw: tx tag=v2-0x8C len=2 cmd=0x8c payload[2]=8c 02 flags=0x2
[ 1647.750550] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1409 +1347748ms] dsi_write_raw: tx complete tag=v2-0x8C ret=6
[ 1647.750565] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1410 +1347748ms] dsi_write_raw: tx tag=v2-0x8D len=2 cmd=0x8d payload[2]=8d 81 flags=0x2
[ 1647.750610] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1411 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8D ret=6
[ 1647.750628] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1412 +1347752ms] dsi_write_raw: tx tag=v2-0x8E len=2 cmd=0x8e payload[2]=8e 00 flags=0x2
[ 1647.750643] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1413 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8E ret=6
[ 1647.750659] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1414 +1347752ms] dsi_write_raw: tx tag=v2-0x8F len=2 cmd=0x8f payload[2]=8f 00 flags=0x2
[ 1647.750675] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1415 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8F ret=6
[ 1647.750691] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1416 +1347752ms] dsi_write_raw: tx tag=v2-0x90 len=2 cmd=0x90 payload[2]=90 00 flags=0x2
[ 1647.750707] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1417 +1347752ms] dsi_write_raw: tx complete tag=v2-0x90 ret=6
[ 1647.750723] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1418 +1347752ms] dsi_write_raw: tx tag=v2-0x91 len=2 cmd=0x91 payload[2]=91 05 flags=0x2
[ 1647.750739] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1419 +1347752ms] dsi_write_raw: tx complete tag=v2-0x91 ret=6
[ 1647.750755] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1420 +1347752ms] dsi_write_raw: tx tag=v2-0x92 len=2 cmd=0x92 payload[2]=92 00 flags=0x2
[ 1647.750770] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1421 +1347752ms] dsi_write_raw: tx complete tag=v2-0x92 ret=6
[ 1647.750786] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1422 +1347752ms] dsi_write_raw: tx tag=v2-0x93 len=2 cmd=0x93 payload[2]=93 0f flags=0x2
[ 1647.750801] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1423 +1347752ms] dsi_write_raw: tx complete tag=v2-0x93 ret=6
[ 1647.750817] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1424 +1347752ms] dsi_write_raw: tx tag=v2-0x94 len=2 cmd=0x94 payload[2]=94 00 flags=0x2
[ 1647.750833] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1425 +1347752ms] dsi_write_raw: tx complete tag=v2-0x94 ret=6
[ 1647.750849] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1426 +1347752ms] dsi_write_raw: tx tag=v2-0x95 len=2 cmd=0x95 payload[2]=95 08 flags=0x2
[ 1647.750864] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1427 +1347752ms] dsi_write_raw: tx complete tag=v2-0x95 ret=6
[ 1647.750880] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1428 +1347752ms] dsi_write_raw: tx tag=v2-0x96 len=2 cmd=0x96 payload[2]=96 00 flags=0x2
[ 1647.750895] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1429 +1347752ms] dsi_write_raw: tx complete tag=v2-0x96 ret=6
[ 1647.750912] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1430 +1347752ms] dsi_write_raw: tx tag=v2-0x97 len=2 cmd=0x97 payload[2]=97 00 flags=0x2
[ 1647.750927] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1431 +1347752ms] dsi_write_raw: tx complete tag=v2-0x97 ret=6
[ 1647.750943] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1432 +1347752ms] dsi_write_raw: tx tag=v2-0x98 len=2 cmd=0x98 payload[2]=98 00 flags=0x2
[ 1647.750958] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1433 +1347752ms] dsi_write_raw: tx complete tag=v2-0x98 ret=6
[ 1647.750974] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1434 +1347752ms] dsi_write_raw: tx tag=v2-0x99 len=2 cmd=0x99 payload[2]=99 00 flags=0x2
[ 1647.750989] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1435 +1347752ms] dsi_write_raw: tx complete tag=v2-0x99 ret=6
[ 1647.751005] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1436 +1347752ms] dsi_write_raw: tx tag=v2-0x9A len=2 cmd=0x9a payload[2]=9a 00 flags=0x2
[ 1647.751020] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1437 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9A ret=6
[ 1647.751036] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1438 +1347752ms] dsi_write_raw: tx tag=v2-0x9B len=2 cmd=0x9b payload[2]=9b 01 flags=0x2
[ 1647.751051] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1439 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9B ret=6
[ 1647.751067] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1440 +1347752ms] dsi_write_raw: tx tag=v2-0x9C len=2 cmd=0x9c payload[2]=9c 00 flags=0x2
[ 1647.751082] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1441 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9C ret=6
[ 1647.751098] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1442 +1347752ms] dsi_write_raw: tx tag=v2-0x9D len=2 cmd=0x9d payload[2]=9d 74 flags=0x2
[ 1647.751113] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1443 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9D ret=6
[ 1647.751129] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1444 +1347752ms] dsi_write_raw: tx tag=v2-0x9E len=2 cmd=0x9e payload[2]=9e 12 flags=0x2
[ 1647.751145] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1445 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9E ret=6
[ 1647.751160] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1446 +1347752ms] dsi_write_raw: tx tag=v2-0x9F len=2 cmd=0x9f payload[2]=9f b2 flags=0x2
[ 1647.751176] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1447 +1347752ms] dsi_write_raw: tx complete tag=v2-0x9F ret=6
[ 1647.751191] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1448 +1347752ms] dsi_write_raw: tx tag=v2-0xA0 len=2 cmd=0xa0 payload[2]=a0 07 flags=0x2
[ 1647.751207] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1449 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA0 ret=6
[ 1647.751223] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1450 +1347752ms] dsi_write_raw: tx tag=v2-0xA1 len=2 cmd=0xa1 payload[2]=a1 a0 flags=0x2
[ 1647.751238] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1451 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA1 ret=6
[ 1647.751254] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1452 +1347752ms] dsi_write_raw: tx tag=v2-0xA2 len=2 cmd=0xa2 payload[2]=a2 08 flags=0x2
[ 1647.751270] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1453 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA2 ret=6
[ 1647.751286] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1454 +1347752ms] dsi_write_raw: tx tag=v2-0xA3 len=2 cmd=0xa3 payload[2]=a3 60 flags=0x2
[ 1647.751301] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1455 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA3 ret=6
[ 1647.751317] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1456 +1347752ms] dsi_write_raw: tx tag=v2-0xA4 len=2 cmd=0xa4 payload[2]=a4 08 flags=0x2
[ 1647.751332] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1457 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA4 ret=6
[ 1647.751348] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1458 +1347752ms] dsi_write_raw: tx tag=v2-0xA5 len=2 cmd=0xa5 payload[2]=a5 02 flags=0x2
[ 1647.751363] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1459 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA5 ret=6
[ 1647.751379] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1460 +1347752ms] dsi_write_raw: tx tag=v2-0xA6 len=2 cmd=0xa6 payload[2]=a6 54 flags=0x2
[ 1647.751395] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1461 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA6 ret=6
[ 1647.751410] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1462 +1347752ms] dsi_write_raw: tx tag=v2-0xA7 len=2 cmd=0xa7 payload[2]=a7 80 flags=0x2
[ 1647.751426] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1463 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA7 ret=6
[ 1647.751442] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1464 +1347752ms] dsi_write_raw: tx tag=v2-0xA8 len=2 cmd=0xa8 payload[2]=a8 00 flags=0x2
[ 1647.751458] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1465 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA8 ret=6
[ 1647.751474] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1466 +1347752ms] dsi_write_raw: tx tag=v2-0xA9 len=2 cmd=0xa9 payload[2]=a9 00 flags=0x2
[ 1647.751489] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1467 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA9 ret=6
[ 1647.751506] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1468 +1347752ms] dsi_write_raw: tx tag=v2-0xAA len=2 cmd=0xaa payload[2]=aa 00 flags=0x2
[ 1647.751521] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1469 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAA ret=6
[ 1647.751537] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1470 +1347752ms] dsi_write_raw: tx tag=v2-0xAB len=2 cmd=0xab payload[2]=ab 00 flags=0x2
[ 1647.751553] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1471 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAB ret=6
[ 1647.751569] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1472 +1347752ms] dsi_write_raw: tx tag=v2-0xAC len=2 cmd=0xac payload[2]=ac 00 flags=0x2
[ 1647.751584] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1473 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAC ret=6
[ 1647.751600] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1474 +1347752ms] dsi_write_raw: tx tag=v2-0xAD len=2 cmd=0xad payload[2]=ad 00 flags=0x2
[ 1647.751616] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1475 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAD ret=6
[ 1647.751631] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1476 +1347752ms] dsi_write_raw: tx tag=v2-0xAE len=2 cmd=0xae payload[2]=ae 00 flags=0x2
[ 1647.751647] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1477 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAE ret=6
[ 1647.751663] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1478 +1347752ms] dsi_write_raw: tx tag=v2-0xAF len=2 cmd=0xaf payload[2]=af 00 flags=0x2
[ 1647.751678] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1479 +1347752ms] dsi_write_raw: tx complete tag=v2-0xAF ret=6
[ 1647.751694] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1480 +1347752ms] dsi_write_raw: tx tag=v2-0xB0 len=2 cmd=0xb0 payload[2]=b0 00 flags=0x2
[ 1647.751710] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1481 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB0 ret=6
[ 1647.751726] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1482 +1347752ms] dsi_write_raw: tx tag=v2-0xB1 len=2 cmd=0xb1 payload[2]=b1 00 flags=0x2
[ 1647.751741] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1483 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB1 ret=6
[ 1647.751757] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1484 +1347752ms] dsi_write_raw: tx tag=v2-0xB2 len=2 cmd=0xb2 payload[2]=b2 00 flags=0x2
[ 1647.751772] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1485 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB2 ret=6
[ 1647.751789] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1486 +1347752ms] dsi_write_raw: tx tag=v2-0xB3 len=2 cmd=0xb3 payload[2]=b3 00 flags=0x2
[ 1647.751804] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1487 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB3 ret=6
[ 1647.751820] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1488 +1347752ms] dsi_write_raw: tx tag=v2-0xB4 len=2 cmd=0xb4 payload[2]=b4 09 flags=0x2
[ 1647.751835] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1489 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB4 ret=6
[ 1647.751852] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1490 +1347752ms] dsi_write_raw: tx tag=v2-0xB5 len=2 cmd=0xb5 payload[2]=b5 01 flags=0x2
[ 1647.751867] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1491 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB5 ret=6
[ 1647.751883] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1492 +1347752ms] dsi_write_raw: tx tag=v2-0xB6 len=2 cmd=0xb6 payload[2]=b6 13 flags=0x2
[ 1647.751898] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1493 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB6 ret=6
[ 1647.751914] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1494 +1347752ms] dsi_write_raw: tx tag=v2-0xB7 len=2 cmd=0xb7 payload[2]=b7 08 flags=0x2
[ 1647.751930] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1495 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB7 ret=6
[ 1647.751946] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1496 +1347752ms] dsi_write_raw: tx tag=v2-0xB8 len=2 cmd=0xb8 payload[2]=b8 12 flags=0x2
[ 1647.751961] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1497 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB8 ret=6
[ 1647.751977] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1498 +1347752ms] dsi_write_raw: tx tag=v2-0xB9 len=2 cmd=0xb9 payload[2]=b9 00 flags=0x2
[ 1647.751993] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1499 +1347752ms] dsi_write_raw: tx complete tag=v2-0xB9 ret=6
[ 1647.752008] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1500 +1347752ms] dsi_write_raw: tx tag=v2-0xBA len=2 cmd=0xba payload[2]=ba 03 flags=0x2
[ 1647.752024] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1501 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBA ret=6
[ 1647.752040] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1502 +1347752ms] dsi_write_raw: tx tag=v2-0xBB len=2 cmd=0xbb payload[2]=bb 00 flags=0x2
[ 1647.752055] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1503 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBB ret=6
[ 1647.752071] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1504 +1347752ms] dsi_write_raw: tx tag=v2-0xBC len=2 cmd=0xbc payload[2]=bc 00 flags=0x2
[ 1647.752087] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1505 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBC ret=6
[ 1647.752103] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1506 +1347752ms] dsi_write_raw: tx tag=v2-0xBD len=2 cmd=0xbd payload[2]=bd 01 flags=0x2
[ 1647.752119] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1507 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBD ret=6
[ 1647.752134] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1508 +1347752ms] dsi_write_raw: tx tag=v2-0xBE len=2 cmd=0xbe payload[2]=be 70 flags=0x2
[ 1647.752150] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1509 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBE ret=6
[ 1647.752165] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1510 +1347752ms] dsi_write_raw: tx tag=v2-0xBF len=2 cmd=0xbf payload[2]=bf ba flags=0x2
[ 1647.752181] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1511 +1347752ms] dsi_write_raw: tx complete tag=v2-0xBF ret=6
[ 1647.752196] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1512 +1347752ms] dsi_write_raw: tx tag=v2-0xC0 len=2 cmd=0xc0 payload[2]=c0 98 flags=0x2
[ 1647.752212] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1513 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC0 ret=6
[ 1647.752228] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1514 +1347752ms] dsi_write_raw: tx tag=v2-0xC1 len=2 cmd=0xc1 payload[2]=c1 76 flags=0x2
[ 1647.752243] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1515 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC1 ret=6
[ 1647.752259] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1516 +1347752ms] dsi_write_raw: tx tag=v2-0xC2 len=2 cmd=0xc2 payload[2]=c2 54 flags=0x2
[ 1647.752274] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1517 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC2 ret=6
[ 1647.752290] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1518 +1347752ms] dsi_write_raw: tx tag=v2-0xC3 len=2 cmd=0xc3 payload[2]=c3 32 flags=0x2
[ 1647.752305] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1519 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC3 ret=6
[ 1647.752321] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1520 +1347752ms] dsi_write_raw: tx tag=v2-0xC4 len=2 cmd=0xc4 payload[2]=c4 10 flags=0x2
[ 1647.752337] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1521 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC4 ret=6
[ 1647.752353] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1522 +1347752ms] dsi_write_raw: tx tag=v2-0xC5 len=2 cmd=0xc5 payload[2]=c5 cd flags=0x2
[ 1647.752368] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1523 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC5 ret=6
[ 1647.752383] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1524 +1347752ms] dsi_write_raw: tx tag=v2-0xC6 len=2 cmd=0xc6 payload[2]=c6 ef flags=0x2
[ 1647.752399] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1525 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC6 ret=6
[ 1647.752415] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1526 +1347752ms] dsi_write_raw: tx tag=v2-0xC7 len=2 cmd=0xc7 payload[2]=c7 00 flags=0x2
[ 1647.752430] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1527 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC7 ret=6
[ 1647.752446] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1528 +1347752ms] dsi_write_raw: tx tag=v2-0xC8 len=2 cmd=0xc8 payload[2]=c8 00 flags=0x2
[ 1647.752461] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1529 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC8 ret=6
[ 1647.752478] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1530 +1347752ms] dsi_write_raw: tx tag=v2-0xC9 len=2 cmd=0xc9 payload[2]=c9 20 flags=0x2
[ 1647.752493] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1531 +1347752ms] dsi_write_raw: tx complete tag=v2-0xC9 ret=6
[ 1647.752509] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1532 +1347752ms] dsi_write_raw: tx tag=v2-0xCB len=2 cmd=0xcb payload[2]=cb 21 flags=0x2
[ 1647.752524] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1533 +1347752ms] dsi_write_raw: tx complete tag=v2-0xCB ret=6
[ 1647.752539] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1534 +1347752ms] dsi_write_raw: tx tag=v2-0xCD len=2 cmd=0xcd payload[2]=cd 0b flags=0x2
[ 1647.752555] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1535 +1347752ms] dsi_write_raw: tx complete tag=v2-0xCD ret=6
[ 1647.752571] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1536 +1347752ms] dsi_write_raw: tx tag=v2-0xCF len=2 cmd=0xcf payload[2]=cf 10 flags=0x2
[ 1647.752586] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1537 +1347752ms] dsi_write_raw: tx complete tag=v2-0xCF ret=6
[ 1647.752602] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1538 +1347752ms] dsi_write_raw: tx tag=v2-0xD0 len=2 cmd=0xd0 payload[2]=d0 12 flags=0x2
[ 1647.752617] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1539 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD0 ret=6
[ 1647.752633] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1540 +1347752ms] dsi_write_raw: tx tag=v2-0xD1 len=2 cmd=0xd1 payload[2]=d1 14 flags=0x2
[ 1647.752649] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1541 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD1 ret=6
[ 1647.752662] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1542 +1347752ms] dsi_write_raw: tx tag=v2-0xD2 len=2 cmd=0xd2 payload[2]=d2 16 flags=0x2
[ 1647.752671] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1543 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD2 ret=6
[ 1647.752679] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1544 +1347752ms] dsi_write_raw: tx tag=v2-0xD3 len=2 cmd=0xd3 payload[2]=d3 18 flags=0x2
[ 1647.752689] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1545 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD3 ret=6
[ 1647.752698] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1546 +1347752ms] dsi_write_raw: tx tag=v2-0xD4 len=2 cmd=0xd4 payload[2]=d4 1a flags=0x2
[ 1647.752707] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1547 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD4 ret=6
[ 1647.752716] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1548 +1347752ms] dsi_write_raw: tx tag=v2-0xD5 len=2 cmd=0xd5 payload[2]=d5 05 flags=0x2
[ 1647.752725] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1549 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD5 ret=6
[ 1647.752734] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1550 +1347752ms] dsi_write_raw: tx tag=v2-0xD6 len=2 cmd=0xd6 payload[2]=d6 07 flags=0x2
[ 1647.752742] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1551 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD6 ret=6
[ 1647.752751] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1552 +1347752ms] dsi_write_raw: tx tag=v2-0xD7 len=2 cmd=0xd7 payload[2]=d7 09 flags=0x2
[ 1647.752760] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1553 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD7 ret=6
[ 1647.752769] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1554 +1347752ms] dsi_write_raw: tx tag=v2-0xD9 len=2 cmd=0xd9 payload[2]=d9 00 flags=0x2
[ 1647.752778] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1555 +1347752ms] dsi_write_raw: tx complete tag=v2-0xD9 ret=6
[ 1647.752787] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1556 +1347752ms] dsi_write_raw: tx tag=v2-0xDA len=2 cmd=0xda payload[2]=da 00 flags=0x2
[ 1647.752796] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1557 +1347752ms] dsi_write_raw: tx complete tag=v2-0xDA ret=6
[ 1647.752805] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1558 +1347752ms] dsi_write_raw: tx tag=v2-0xDB len=2 cmd=0xdb payload[2]=db 00 flags=0x2
[ 1647.752814] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1559 +1347752ms] dsi_write_raw: tx complete tag=v2-0xDB ret=6
[ 1647.752823] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1560 +1347752ms] dsi_write_raw: tx tag=v2-0xDC len=2 cmd=0xdc payload[2]=dc 00 flags=0x2
[ 1647.752832] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1561 +1347752ms] dsi_write_raw: tx complete tag=v2-0xDC ret=6
[ 1647.752841] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1562 +1347752ms] dsi_write_raw: tx tag=v2-0xDD len=2 cmd=0xdd payload[2]=dd 20 flags=0x2
[ 1647.752850] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1563 +1347752ms] dsi_write_raw: tx complete tag=v2-0xDD ret=6
[ 1647.752859] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1564 +1347752ms] dsi_write_raw: tx tag=v2-0xDF len=2 cmd=0xdf payload[2]=df 21 flags=0x2
[ 1647.752868] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1565 +1347752ms] dsi_write_raw: tx complete tag=v2-0xDF ret=6
[ 1647.752877] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1566 +1347752ms] dsi_write_raw: tx tag=v2-0xE3 len=2 cmd=0xe3 payload[2]=e3 0b flags=0x2
[ 1647.752886] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1567 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE3 ret=6
[ 1647.752895] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1568 +1347752ms] dsi_write_raw: tx tag=v2-0xE5 len=2 cmd=0xe5 payload[2]=e5 11 flags=0x2
[ 1647.752904] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1569 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE5 ret=6
[ 1647.752913] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1570 +1347752ms] dsi_write_raw: tx tag=v2-0xE6 len=2 cmd=0xe6 payload[2]=e6 13 flags=0x2
[ 1647.752922] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1571 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE6 ret=6
[ 1647.752931] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1572 +1347752ms] dsi_write_raw: tx tag=v2-0xE7 len=2 cmd=0xe7 payload[2]=e7 15 flags=0x2
[ 1647.752939] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1573 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE7 ret=6
[ 1647.752948] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1574 +1347752ms] dsi_write_raw: tx tag=v2-0xE8 len=2 cmd=0xe8 payload[2]=e8 17 flags=0x2
[ 1647.752957] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1575 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE8 ret=6
[ 1647.752966] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1576 +1347752ms] dsi_write_raw: tx tag=v2-0xE9 len=2 cmd=0xe9 payload[2]=e9 19 flags=0x2
[ 1647.752975] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1577 +1347752ms] dsi_write_raw: tx complete tag=v2-0xE9 ret=6
[ 1647.752984] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1578 +1347752ms] dsi_write_raw: tx tag=v2-0xEA len=2 cmd=0xea payload[2]=ea 1b flags=0x2
[ 1647.752993] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1579 +1347752ms] dsi_write_raw: tx complete tag=v2-0xEA ret=6
[ 1647.753002] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1580 +1347752ms] dsi_write_raw: tx tag=v2-0xEB len=2 cmd=0xeb payload[2]=eb 06 flags=0x2
[ 1647.753010] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1581 +1347752ms] dsi_write_raw: tx complete tag=v2-0xEB ret=6
[ 1647.753019] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1582 +1347752ms] dsi_write_raw: tx tag=v2-0xEC len=2 cmd=0xec payload[2]=ec 08 flags=0x2
[ 1647.753028] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1583 +1347752ms] dsi_write_raw: tx complete tag=v2-0xEC ret=6
[ 1647.753037] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1584 +1347752ms] dsi_write_raw: tx tag=v2-0xED len=2 cmd=0xed payload[2]=ed 0a flags=0x2
[ 1647.753046] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1585 +1347752ms] dsi_write_raw: tx complete tag=v2-0xED ret=6
[ 1647.753055] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1586 +1347752ms] dsi_write_raw: tx tag=v2-0xEF len=2 cmd=0xef payload[2]=ef 00 flags=0x2
[ 1647.753064] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1587 +1347752ms] dsi_write_raw: tx complete tag=v2-0xEF ret=6
[ 1647.753072] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1588 +1347752ms] dsi_write_raw: tx tag=v2-0xF0 len=2 cmd=0xf0 payload[2]=f0 00 flags=0x2
[ 1647.753081] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1589 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF0 ret=6
[ 1647.753090] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1590 +1347752ms] dsi_write_raw: tx tag=v2-0xF1 len=2 cmd=0xf1 payload[2]=f1 a2 flags=0x2
[ 1647.753099] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1591 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF1 ret=6
[ 1647.753108] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1592 +1347752ms] dsi_write_raw: tx tag=v2-0xF2 len=2 cmd=0xf2 payload[2]=f2 18 flags=0x2
[ 1647.753117] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1593 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF2 ret=6
[ 1647.753126] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1594 +1347752ms] dsi_write_raw: tx tag=v2-0xF3 len=2 cmd=0xf3 payload[2]=f3 11 flags=0x2
[ 1647.753135] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1595 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF3 ret=6
[ 1647.753144] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1596 +1347752ms] dsi_write_raw: tx tag=v2-0xF4 len=2 cmd=0xf4 payload[2]=f4 00 flags=0x2
[ 1647.753153] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1597 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF4 ret=6
[ 1647.753162] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1598 +1347752ms] dsi_write_raw: tx tag=v2-0xF5 len=2 cmd=0xf5 payload[2]=f5 11 flags=0x2
[ 1647.753176] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1599 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF5 ret=6
[ 1647.753192] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1600 +1347752ms] dsi_write_raw: tx tag=v2-0xF6 len=2 cmd=0xf6 payload[2]=f6 00 flags=0x2
[ 1647.753207] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1601 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF6 ret=6
[ 1647.753223] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1602 +1347752ms] dsi_write_raw: tx tag=v2-0xF7 len=2 cmd=0xf7 payload[2]=f7 11 flags=0x2
[ 1647.753239] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1603 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF7 ret=6
[ 1647.753255] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1604 +1347752ms] dsi_write_raw: tx tag=v2-0xF8 len=2 cmd=0xf8 payload[2]=f8 00 flags=0x2
[ 1647.753270] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1605 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF8 ret=6
[ 1647.753286] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1606 +1347752ms] dsi_write_raw: tx tag=v2-0xF9 len=2 cmd=0xf9 payload[2]=f9 00 flags=0x2
[ 1647.753301] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1607 +1347752ms] dsi_write_raw: tx complete tag=v2-0xF9 ret=6
[ 1647.753317] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1608 +1347752ms] dsi_write_raw: tx tag=v2-0xFA len=2 cmd=0xfa payload[2]=fa 00 flags=0x2
[ 1647.753332] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1609 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFA ret=6
[ 1647.753348] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1610 +1347752ms] dsi_write_raw: tx tag=v2-0xFB len=2 cmd=0xfb payload[2]=fb 00 flags=0x2
[ 1647.753364] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1611 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFB ret=6
[ 1647.753379] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1612 +1347752ms] dsi_write_raw: tx tag=v2-0xFC len=2 cmd=0xfc payload[2]=fc 20 flags=0x2
[ 1647.753395] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1613 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFC ret=6
[ 1647.753411] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1614 +1347752ms] dsi_write_raw: tx tag=v2-0xFD len=2 cmd=0xfd payload[2]=fd 00 flags=0x2
[ 1647.753426] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1615 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFD ret=6
[ 1647.753442] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1616 +1347752ms] dsi_write_raw: tx tag=v2-0xFE len=2 cmd=0xfe payload[2]=fe 00 flags=0x2
[ 1647.753457] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1617 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFE ret=6
[ 1647.753473] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1618 +1347752ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 05 flags=0x2
[ 1647.753489] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1619 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.753504] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1620 +1347752ms] dsi_write_raw: tx tag=v2-0x8F len=2 cmd=0x8f payload[2]=8f e8 flags=0x2
[ 1647.753519] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1621 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8F ret=6
[ 1647.753536] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1622 +1347752ms] dsi_write_raw: tx tag=v2-0x90 len=2 cmd=0x90 payload[2]=90 84 flags=0x2
[ 1647.753551] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1623 +1347752ms] dsi_write_raw: tx complete tag=v2-0x90 ret=6
[ 1647.753567] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1624 +1347752ms] dsi_write_raw: tx tag=v2-0x91 len=2 cmd=0x91 payload[2]=91 77 flags=0x2
[ 1647.753582] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1625 +1347752ms] dsi_write_raw: tx complete tag=v2-0x91 ret=6
[ 1647.753598] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1626 +1347752ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 06 flags=0x2
[ 1647.753614] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1627 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.753629] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1628 +1347752ms] dsi_write_raw: tx tag=v2-0x80 len=2 cmd=0x80 payload[2]=80 10 flags=0x2
[ 1647.753645] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1629 +1347752ms] dsi_write_raw: tx complete tag=v2-0x80 ret=6
[ 1647.753660] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1630 +1347752ms] dsi_write_raw: tx tag=v2-0x81 len=2 cmd=0x81 payload[2]=81 00 flags=0x2
[ 1647.753676] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1631 +1347752ms] dsi_write_raw: tx complete tag=v2-0x81 ret=6
[ 1647.753692] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1632 +1347752ms] dsi_write_raw: tx tag=v2-0x82 len=2 cmd=0x82 payload[2]=82 07 flags=0x2
[ 1647.753707] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1633 +1347752ms] dsi_write_raw: tx complete tag=v2-0x82 ret=6
[ 1647.753723] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1634 +1347752ms] dsi_write_raw: tx tag=v2-0x83 len=2 cmd=0x83 payload[2]=83 9f flags=0x2
[ 1647.753738] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1635 +1347752ms] dsi_write_raw: tx complete tag=v2-0x83 ret=6
[ 1647.753754] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1636 +1347752ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 07 flags=0x2
[ 1647.753769] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1637 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.753785] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1638 +1347752ms] dsi_write_raw: tx tag=v2-0x80 len=2 cmd=0x80 payload[2]=80 14 flags=0x2
[ 1647.753800] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1639 +1347752ms] dsi_write_raw: tx complete tag=v2-0x80 ret=6
[ 1647.753816] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1640 +1347752ms] dsi_write_raw: tx tag=v2-0x81 len=2 cmd=0x81 payload[2]=81 12 flags=0x2
[ 1647.753832] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1641 +1347752ms] dsi_write_raw: tx complete tag=v2-0x81 ret=6
[ 1647.753847] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1642 +1347752ms] dsi_write_raw: tx tag=v2-0x82 len=2 cmd=0x82 payload[2]=82 02 flags=0x2
[ 1647.753863] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1643 +1347752ms] dsi_write_raw: tx complete tag=v2-0x82 ret=6
[ 1647.753879] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1644 +1347752ms] dsi_write_raw: tx tag=v2-0x83 len=2 cmd=0x83 payload[2]=83 20 flags=0x2
[ 1647.753894] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1645 +1347752ms] dsi_write_raw: tx complete tag=v2-0x83 ret=6
[ 1647.753910] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1646 +1347752ms] dsi_write_raw: tx tag=v2-0x84 len=2 cmd=0x84 payload[2]=84 24 flags=0x2
[ 1647.753925] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1647 +1347752ms] dsi_write_raw: tx complete tag=v2-0x84 ret=6
[ 1647.753941] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1648 +1347752ms] dsi_write_raw: tx tag=v2-0x85 len=2 cmd=0x85 payload[2]=85 0c flags=0x2
[ 1647.753956] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1649 +1347752ms] dsi_write_raw: tx complete tag=v2-0x85 ret=6
[ 1647.753972] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1650 +1347752ms] dsi_write_raw: tx tag=v2-0x86 len=2 cmd=0x86 payload[2]=86 39 flags=0x2
[ 1647.753988] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1651 +1347752ms] dsi_write_raw: tx complete tag=v2-0x86 ret=6
[ 1647.754004] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1652 +1347752ms] dsi_write_raw: tx tag=v2-0x87 len=2 cmd=0x87 payload[2]=87 77 flags=0x2
[ 1647.754019] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1653 +1347752ms] dsi_write_raw: tx complete tag=v2-0x87 ret=6
[ 1647.754035] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1654 +1347752ms] dsi_write_raw: tx tag=v2-0x88 len=2 cmd=0x88 payload[2]=88 80 flags=0x2
[ 1647.754051] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1655 +1347752ms] dsi_write_raw: tx complete tag=v2-0x88 ret=6
[ 1647.754066] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1656 +1347752ms] dsi_write_raw: tx tag=v2-0x89 len=2 cmd=0x89 payload[2]=89 33 flags=0x2
[ 1647.754082] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1657 +1347752ms] dsi_write_raw: tx complete tag=v2-0x89 ret=6
[ 1647.754098] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1658 +1347752ms] dsi_write_raw: tx tag=v2-0x8A len=2 cmd=0x8a payload[2]=8a 00 flags=0x2
[ 1647.754114] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1659 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8A ret=6
[ 1647.754129] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1660 +1347752ms] dsi_write_raw: tx tag=v2-0x8B len=2 cmd=0x8b payload[2]=8b 04 flags=0x2
[ 1647.754144] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1661 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8B ret=6
[ 1647.754160] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1662 +1347752ms] dsi_write_raw: tx tag=v2-0x8C len=2 cmd=0x8c payload[2]=8c 09 flags=0x2
[ 1647.754176] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1663 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8C ret=6
[ 1647.754192] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1664 +1347752ms] dsi_write_raw: tx tag=v2-0x8D len=2 cmd=0x8d payload[2]=8d 40 flags=0x2
[ 1647.754207] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1665 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8D ret=6
[ 1647.754223] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1666 +1347752ms] dsi_write_raw: tx tag=v2-0x8E len=2 cmd=0x8e payload[2]=8e 40 flags=0x2
[ 1647.754238] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1667 +1347752ms] dsi_write_raw: tx complete tag=v2-0x8E ret=6
[ 1647.754254] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1668 +1347752ms] dsi_write_raw: tx tag=v2-0x91 len=2 cmd=0x91 payload[2]=91 11 flags=0x2
[ 1647.754269] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1669 +1347752ms] dsi_write_raw: tx complete tag=v2-0x91 ret=6
[ 1647.754285] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1670 +1347752ms] dsi_write_raw: tx tag=v2-0x92 len=2 cmd=0x92 payload[2]=92 2c flags=0x2
[ 1647.754301] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1671 +1347752ms] dsi_write_raw: tx complete tag=v2-0x92 ret=6
[ 1647.754316] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1672 +1347752ms] dsi_write_raw: tx tag=v2-0x93 len=2 cmd=0x93 payload[2]=93 2d flags=0x2
[ 1647.754332] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1673 +1347752ms] dsi_write_raw: tx complete tag=v2-0x93 ret=6
[ 1647.754348] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1674 +1347752ms] dsi_write_raw: tx tag=v2-0x94 len=2 cmd=0x94 payload[2]=94 03 flags=0x2
[ 1647.754363] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1675 +1347752ms] dsi_write_raw: tx complete tag=v2-0x94 ret=6
[ 1647.754379] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1676 +1347752ms] dsi_write_raw: tx tag=v2-0xA0 len=2 cmd=0xa0 payload[2]=a0 0a flags=0x2
[ 1647.754394] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1677 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA0 ret=6
[ 1647.754412] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1678 +1347752ms] dsi_write_raw: tx tag=v2-0xA2 len=2 cmd=0xa2 payload[2]=a2 13 flags=0x2
[ 1647.754427] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1679 +1347752ms] dsi_write_raw: tx complete tag=v2-0xA2 ret=6
[ 1647.754443] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1680 +1347752ms] dsi_write_raw: tx tag=v2-0xFF len=2 cmd=0xff payload[2]=ff 00 flags=0x2
[ 1647.754459] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1681 +1347752ms] dsi_write_raw: tx complete tag=v2-0xFF ret=6
[ 1647.754471] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] sent tables OK
[ 1647.754481] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1682 +1347752ms] pocket_display_v2_init: display_v2_init_count incremented to 4
[ 1647.754495] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1683 +1347752ms] jdi_dcs_exit_sleep_mode: issuing exit sleep mode
[ 1647.874642] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1684 +1347876ms] pocket_display_v2_init: post-exit-sleep delay complete
[ 1647.874667] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1685 +1347876ms] pocket_display_v2_init: probing panel runtime status registers
[ 1647.875706] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1647.876741] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1647.877770] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1647.878599] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1647.879625] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1647.879636] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1686 +1347880ms] jdi_dcs_set_display_on: issuing set display on
[ 1647.879648] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1687 +1347880ms] pocket_display_v2_init: probing panel runtime status registers
[ 1647.880674] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a = 0x00
[ 1647.881701] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x00
[ 1647.882603] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x00
[ 1647.883630] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x00
[ 1647.884660] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x00
[ 1647.884676] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1688 +1347884ms] pocket_display_v2_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=4 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.884689] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1689 +1347884ms] pocket_display_v2_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.884701] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1690 +1347884ms] pocket_display_v2_init: supplies: vddp=true iovcc=true
[ 1647.884716] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1691 +1347884ms] pocket_display_v2_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.884726] panel-mnt-pocket-reform ffd07000.dsi.0: [display v2] OK
[ 1647.884737] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1692 +1347884ms] jdi_panel_init: state: prepared=false enabled=false panel_version=2 v1_init_count=0 v2_init_count=4 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.884749] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1693 +1347884ms] jdi_panel_init: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.884760] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1694 +1347884ms] jdi_panel_init: supplies: vddp=true iovcc=true
[ 1647.884770] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1695 +1347884ms] jdi_panel_init: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.884783] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1696 +1347884ms] jdi_panel_prepare: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=4 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.884795] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1697 +1347884ms] jdi_panel_prepare: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.884806] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1698 +1347884ms] jdi_panel_prepare: supplies: vddp=true iovcc=true
[ 1647.884816] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1699 +1347884ms] jdi_panel_prepare: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.885027] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1700 +1347884ms] jdi_panel_enable: enter
[ 1647.885040] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1701 +1347884ms] jdi_panel_enable: state: prepared=true enabled=false panel_version=2 v1_init_count=0 v2_init_count=4 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.885052] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1702 +1347884ms] jdi_panel_enable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.885063] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1703 +1347884ms] jdi_panel_enable: supplies: vddp=true iovcc=true
[ 1647.885074] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1704 +1347884ms] jdi_panel_enable: gpios: enable=1 reset=-2 dcdc_en=-2
[ 1647.885085] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1705 +1347884ms] jdi_panel_enable: forcing LPM for enable-time display on
[ 1647.885096] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1706 +1347884ms] jdi_panel_enable: probing panel runtime status registers
[ 1647.905632] meson-dw-mipi-dsi ffd07000.dsi: Timeout during read operation
[ 1647.905651] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0a failed: -110
[ 1647.921640] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0c = 0x94
[ 1647.940626] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0d = 0x94
[ 1647.958593] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0e = 0x94
[ 1647.976646] panel-mnt-pocket-reform ffd07000.dsi.0: [display dcs] read 0x0f = 0x94
[ 1647.976681] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1707 +1347976ms] jdi_panel_enable: state: prepared=true enabled=true panel_version=2 v1_init_count=0 v2_init_count=4 lanes=4 format=0 mode_flags=0x801 VIDEO LPM
[ 1647.976698] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1708 +1347976ms] jdi_panel_enable: knobs: pre_init_settle_delay_ms=0 force_v2_tables_first_init=false post_gpio_settle_delay_ms=0 force_panel_version=0
[ 1647.976712] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1709 +1347976ms] jdi_panel_enable: supplies: vddp=true iovcc=true
[ 1647.976729] panel-mnt-pocket-reform ffd07000.dsi.0: [display trace #1710 +1347976ms] jdi_panel_enable: gpios: enable=1 reset=-2 dcdc_en=-2
it does still kinda “flicker”, but it works well otherwise.
it’s a bit novel, but i know vsync is kinda standardized, and might be a great way to measure timings; using something for more than its intended purpose is always nice too.
also off topic a bit but arch has been fun, gotta say pacman’s kinda neat (and now i get to say “I use arch btw” lmfao). even if i’ll be happy to get back to debian, when i get around to building a survival/emergency OS on a spare micro SD card to keep in my backpack for emergencies, i think i’m gonna use arch and underclock the daylights outta the CPU on it, and keep it to having no “real”/“normal” graphical desktop, just a terminal multiplexer and/or TWM, with the whole OS designed to be insanely lightweight, so i can squeeze every last MaH out of the batteries, with scripts to turn communications (wifi, bluetooth) on only in emergencies
anyways, i hope dmesg helps, as well as the info i gave, and if there’s any further debugging you want me to do, let me know. also let me know if any fixes can be upstreamed, since if so i’m more than happy to stay on arch and help debug till it’s merged, if not i’m gonna get a new screen and move back to my debian install then.
that said since it seems to be a broader issue across multiple versions of this device, as seen by
getting here with i.MX8MP, it’s not just an A311D issue. also since those models are older, Michals may have a V1 panel while we may have a V2, do you know how to find out which panels are V1 and which ones are V2? since i did see there being versions of the panel mentioned before but couldn’t figure out from documentation which was V1 and which was V1. if it’s an issue across not only CPUs, but panels too, clearly it’s extremely unlikely to be just a handful of bad panels, and thus it has to be a driver issue, which can narrow down the suspect list massively; all the more reason to see if a vsync-based timings error correction mechanism of sorts can be used.
though this suggests it might be something other than drivers, and is another place to go looking for suspects, which i know this is late to mention, but that’s a good call Michals. if you can also run Stephano’s arch image off an SD card, that might be a great way to test this issue, that’s if Stephano can build it for your CPU?
You can look at this file to know which panel you have (took from a @josch message on another forum topic).
/sys/devices/platform/fde30000.dsi/fde30000.dsi.0/mnt_pocket_reform_panel_version
Sorry, I’ve only become aware of this thread now for some reason.
There are several different issues at play. As I have to jump into a meeting in 10 minutes, I’m just dropping some pointers here quickly:
  • There are two different “flicker” issues.
    • The one that @stephano mentioned is related to AFBC (ARM framebuffer compression) and happens in the GPU/Display pipeline and doesn’t concern the display panel itself. Lets name this the “AFBC flicker” issue. This only affects Mali systems, but i.MX8MP has a Vivante (etnaviv) GPU, so not affected.
    • There’s another flicker that I though happens only on Display V1, which looks like a faint “oscillation” in the image that stays around for like 30 minutes and slowly disappears. This happens when the panel is driven in a wrong mode, or doesn’t get a proper signal while it’s still turned on. I’ve made a fix for this in October 2025 but it never got merged because IIRC it caused some panels to not wake up at all: Draft: pocket panel: merge the two patches, attempt 1 to fix dispv1 flicker after disable/enable cycle (!140) · Merge requests · Reform / reform-debian-packages · GitLab · MNT Source
      • It’s very possible that a fix like this (about the proper sleep/power off/power on etc ordering) can help with Display V2 as well.
There’s another known issue about Display V2 that causes a grey background on half of the display and strange vignette-like effects. This happens on warm reboots or re-init of the display without a proper hardware reset. We’ve fixed this during a big System Controller rewrite that will be rolled out hopefully very soon now. The complicated part about this was that the SC needs to toggle this line, and the panel driver needs to depend on this line in device tree, so the SC driver also had to become a GPIO provider.
trying cat on this gives me no such file or directory, investigating i found the /sys/devices/platform/fde30000.dsi folders and subfolders don’t exist. now that may be because of Stephano’s arch image, but maybe not?
i get it, y’all got a lot going on with the Next and the Vector, and for a small company you’re doing incredibly awesome stuff.
yeah this sounds like the flicker issue Stephano and i are seeing from behaviour alone, but the screen locking off doesn’t seem like it would be affected by that, and with Michals on i.MX8MP i don’t think it could be that for them too
this seems more like the issue that’s causing my screen to crash since it gets locked to all grey and vignette-like effects, but on the whole screen so i’m not sure.
perhaps we’re all seeing a mix bag of issues? whenever the update for the SC comes out, i’ll update my system and see if the issue goes away on the debian one, since @stephano i am happy to report that your changes with your arch image have indeed fixed my screen getting locked to greyscale and not coming on again when locking with Gnome that i was running into, since it would, without fail, get locked up after letting it sit overnight on the debian image. so if these changes can be upstreamed, and the SC update doesn’t already fix them for the debian install, make a PR for it.
seems we’re finally getting the rhythm of bug whack a mole here now since we have a solid list of suspects for these issues finally, and pending fixes for all, which is great progress.
Ah okay. One more thing to try.
There’s an issue with the reform2_lpc module on Arch. I haven’t documented it yet as I haven’t been able to find even a guess at the cause, and I have a simple work around.
sudo rmmod reform2_lpc
sudo modprobe reform2_lpc
If you’re seeing a very faint “flicker” even after getting Arch running with gnome, this should fix that. The issue is that the reform2_lpc module never loads properly. You should notice that you cannot change the brightness in gnome, though I cannot say for sure, as I use sway, and that’s the main symptom, along with the flicker. Once the module is reloaded you should see a clean display without any flicker and the display brightness controls should be back.
