I just installed the AX and it is recognized properly by ZZTOP, the sound is coming from the card with no problem.
I tried to play mp3 using AmigaAMP and when selecting hardware decoding and zz9000 MHI driver in settings the system just freezes the moment I try to play any mp3. It needs hard reset.
Just to add to it I spoke to somebody on MNT FB group and he has exactly the same issue and is also using INT2. Another symptom we both have is axmp3 not playing musing but messing the screen with random pixels.
Hi everyone. For me the latest firmware/drivers have worked flawless to accelerate my internet radiostations playing in AmigaAMP. Thank you so much for this release! Now to my question, what is the use of changing Jumper Int6 to Int2? According to the manual the Ethernet is then disabled and why would someone need to disable that?
/Silver
