Close. You can remove the “<” and “>” symbols.
sudo virsh dumpxml win10 > windows.xml
Apologies on the slow reply, and thanks for uploading those xml files.
Looking at the diff, this is the first thing that jumps out:
On windows.xml:
<disk type='file' device='cdrom' model='usb-bot'>
<driver name='qemu' type='raw'/>
<source file='...ISO'/>
<target dev='sdb' bus='usb'/>
<readonly/>
<address type='usb' bus='0' port='2'/>
</disk>
On debian.xml:
<disk type='file' device='cdrom'>
<target dev='sda' bus='scsi'/>
<readonly/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<controller type='scsi' model='virtio-scsi'/>
So my question would be, did you explicitly choose “USB Disk” or “USB CD-ROM” when attaching the ISO or did virt-manager automatically decide to use USB because of the Windows OS profile? I’m guessing this was virt-manager’s default choice.
I’m going to play around with virt-manager soon on my pocket running the rs3588s, so I’ll try windows out and let you know if I find anything here.
I didn’t change any settings at all; I just let virt-manager handle it, trusting that it would do it right.
