Here it is:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 0.000000] Linux version 6.11.7-mnt-reform-arm64 (debian-kernel@lists.debian.org) (aarch64-linux-gnu-gcc-14 (Debian 14.2.0-8) 14.2.0, GNU ld (GNU Binutils for Debian) 2.43.1) #1 SMP Debian 6.11.7-1+reform20241116T090854Z (2024-11-16)
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: MNT Reform 2 with RCORE RK3588 Module
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x00000003fc000000..0x00000003fc4fffff (5120 KiB) nomap non-reusable gap1@3,fc000000
[ 0.000000] OF: reserved mem: 0x00000003fff00000..0x00000003ffffffff (1024 KiB) nomap non-reusable gap2@3,fff00000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000003ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x3fdeef8c0-0x3fdef2fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000003ffffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000200000-0x00000000efffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000003fbffffff]
[ 0.000000] node 0: [mem 0x00000003fc000000-0x00000003fc4fffff]
[ 0.000000] node 0: [mem 0x00000003fc500000-0x00000003ffefffff]
[ 0.000000] node 0: [mem 0x00000003fff00000-0x00000003ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000003ffffffff]
[ 0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[ 0.000000] cma: Reserved 256 MiB at 0x00000000daa00000 on node -1
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.5
[ 0.000000] percpu: Embedded 34 pages/cpu s99736 r8192 d31336 u139264
[ 0.000000] pcpu-alloc: s99736 r8192 d31336 u139264 alloc=34*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: ro no_console_suspend cryptomgr.notests loglevel=3 clk_ignore_unused cma=256M swiotlb=65535 console=tty1
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 4128256
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] software IO TLB: area num 8.
[ 0.000000] software IO TLB: mapped [mem 0x00000000d2a00000-0x00000000daa00000] (128MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] ftrace: allocating 51687 entries in 202 pages
[ 0.000000] ftrace: allocated 202 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 480 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: MBI range [424:479]
[ 0.000000] GICv3: Using MBI frame 0x00000000fe610000
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=0
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 0.000000] ITS [mem 0xfe640000-0xfe65ffff]
[ 0.000000] GIC: enabling workaround for ITS: Rockchip erratum RK3588001
[ 0.000000] ITS@0x00000000fe640000: allocated 8192 Devices @100200000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100210000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] ITS [mem 0xfe660000-0xfe67ffff]
[ 0.000000] ITS@0x00000000fe660000: allocated 8192 Devices @100230000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100240000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GICv3: using LPI property table @0x0000000100250000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000100260000
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@100[1] /cpus/cpu@200[2] /cpus/cpu@300[3] }
[ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@400[4] /cpus/cpu@500[5] /cpus/cpu@600[6] /cpus/cpu@700[7] }
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.003091] Console: colour dummy device 80x25
[ 0.003107] printk: legacy console [tty1] enabled
[ 0.005300] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.005318] pid_max: default: 32768 minimum: 301
[ 0.009526] LSM: initializing lsm=lockdown,capability,landlock,yama,apparmor,tomoyo,bpf,ima,evm
[ 0.010066] landlock: Up and running.
[ 0.010072] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.010187] AppArmor: AppArmor initialized
[ 0.010202] TOMOYO Linux initialized
[ 0.010244] LSM support for eBPF active
[ 0.011816] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.011870] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.017933] rcu: Hierarchical SRCU implementation.
[ 0.017944] rcu: Max phase no-delay instances is 1000.
[ 0.018300] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.019703] fsl-mc MSI: msi-controller@fe640000 domain created
[ 0.019730] fsl-mc MSI: msi-controller@fe660000 domain created
[ 0.022834] EFI services will not be available.
[ 0.023478] smp: Bringing up secondary CPUs ...
[ 0.024372] Detected VIPT I-cache on CPU1
[ 0.024449] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 0.024465] GICv3: CPU1: using allocated LPI pending table @0x0000000100270000
[ 0.024515] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.025503] Detected VIPT I-cache on CPU2
[ 0.025575] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 0.025590] GICv3: CPU2: using allocated LPI pending table @0x0000000100280000
[ 0.025636] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.026651] Detected VIPT I-cache on CPU3
[ 0.026722] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 0.026737] GICv3: CPU3: using allocated LPI pending table @0x0000000100290000
[ 0.026781] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.027771] CPU features: detected: Spectre-v4
[ 0.027778] CPU features: detected: Spectre-BHB
[ 0.027782] CPU features: detected: SSBS not fully self-synchronizing
[ 0.027785] Detected PIPT I-cache on CPU4
[ 0.027827] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 0.027838] GICv3: CPU4: using allocated LPI pending table @0x00000001002a0000
[ 0.027866] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 0.028734] Detected PIPT I-cache on CPU5
[ 0.028785] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 0.028795] GICv3: CPU5: using allocated LPI pending table @0x00000001002b0000
[ 0.028825] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 0.029706] Detected PIPT I-cache on CPU6
[ 0.029754] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 0.029764] GICv3: CPU6: using allocated LPI pending table @0x00000001002c0000
[ 0.029793] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 0.030666] Detected PIPT I-cache on CPU7
[ 0.030717] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 0.030727] GICv3: CPU7: using allocated LPI pending table @0x00000001002d0000
[ 0.030757] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 0.030873] smp: Brought up 1 node, 8 CPUs
[ 0.030911] SMP: Total of 8 processors activated.
[ 0.030918] CPU: All CPU(s) started at EL2
[ 0.030924] CPU features: detected: 32-bit EL0 Support
[ 0.030930] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.030937] CPU features: detected: Common not Private translations
[ 0.030944] CPU features: detected: CRC32 instructions
[ 0.030949] CPU features: detected: Data cache clean to Point of Persistence
[ 0.030961] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.030967] CPU features: detected: LSE atomic instructions
[ 0.030972] CPU features: detected: Privileged Access Never
[ 0.030978] CPU features: detected: RAS Extension Support
[ 0.030987] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.031064] alternatives: applying system-wide alternatives
[ 0.035553] CPU features: detected: Hardware dirty bit management on CPU4-7
[ 0.066504] node 0 deferred pages initialised in 28ms
[ 0.066567] Memory: 15723244K/16513024K available (15680K kernel code, 3672K rwdata, 6204K rodata, 2816K init, 863K bss, 519404K reserved, 262144K cma-reserved)
[ 0.069086] devtmpfs: initialized
[ 0.080978] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.081008] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.083258] 25408 pages in range for non-PLT usage
[ 0.083262] 516928 pages in range for PLT usage
[ 0.084396] pinctrl core: initialized pinctrl subsystem
[ 0.086175] DMI not present or invalid.
[ 0.088817] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.089748] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.090158] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.090587] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.090610] audit: initializing netlink subsys (disabled)
[ 0.090713] audit: type=2000 audit(0.084:1): state=initialized audit_enabled=0 res=1
[ 0.091409] thermal_sys: Registered thermal governor 'fair_share'
[ 0.091414] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.091417] thermal_sys: Registered thermal governor 'step_wise'
[ 0.091420] thermal_sys: Registered thermal governor 'user_space'
[ 0.091423] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.091457] cpuidle: using governor ladder
[ 0.091480] cpuidle: using governor menu
[ 0.091583] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.091715] ASID allocator initialised with 65536 entries
[ 0.092578] Serial: AMBA PL011 UART driver
[ 0.115865] rockchip_rk3588_pll_wait_lock: timeout waiting for pll to lock
[ 0.115870] rockchip_rk3588_pll_set_params: pll update unsuccessful, trying to restore old params
[ 0.121530] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fde80000
[ 0.121562] platform fde80000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000
[ 0.121848] platform fdd90000.vop: Fixed dependency cycle(s) with /hdmi@fdea0000
[ 0.121876] platform fdea0000.hdmi: Fixed dependency cycle(s) with /vop@fdd90000
[ 0.126482] platform a41000000.pcie: Fixed dependency cycle(s) with /pcie@fe190000/legacy-interrupt-controller
[ 0.135743] platform a40000000.pcie: Fixed dependency cycle(s) with /pcie@fe150000/legacy-interrupt-controller
[ 0.143625] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.143630] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.143636] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.143639] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.143643] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.143646] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.143649] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.143652] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.150934] ACPI: Interpreter disabled.
[ 0.151542] iommu: Default domain type: Translated
[ 0.151546] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.156038] pps_core: LinuxPPS API ver. 1 registered
[ 0.156043] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.156050] PTP clock support registered
[ 0.156078] EDAC MC: Ver: 3.0.0
[ 0.156237] scmi_core: SCMI protocol bus registered
[ 0.157436] NetLabel: Initializing
[ 0.157440] NetLabel: domain hash size = 128
[ 0.157443] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.157478] NetLabel: unlabeled traffic allowed by default
[ 0.157767] vgaarb: loaded
[ 0.157992] clocksource: Switched to clocksource arch_sys_counter
[ 0.159876] VFS: Disk quotas dquot_6.6.0
[ 0.160027] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.160507] AppArmor: AppArmor Filesystem Enabled
[ 0.160547] pnp: PnP ACPI: disabled
[ 0.167876] NET: Registered PF_INET protocol family
[ 0.168188] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.178019] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.178175] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.178319] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.179527] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.181410] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.181747] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.181963] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.182365] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.182883] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.182915] NET: Registered PF_XDP protocol family
[ 0.182923] PCI: CLS 0 bytes, default 64
[ 0.183109] Trying to unpack rootfs image as initramfs...
[ 0.185678] kvm [1]: nv: 529 coarse grained trap handlers
[ 0.185874] kvm [1]: IPA Size Limit: 40 bits
[ 0.185893] kvm [1]: GICv3: no GICV resource entry
[ 0.185896] kvm [1]: disabling GICv2 emulation
[ 0.185917] kvm [1]: GIC system register CPU interface enabled
[ 0.185933] kvm [1]: vgic interrupt IRQ18
[ 0.185963] kvm [1]: VHE mode initialized successfully
[ 0.187198] Initialise system trusted keyrings
[ 0.187224] Key type blacklist registered
[ 0.187420] workingset: timestamp_bits=42 max_order=22 bucket_order=0
[ 0.187443] zbud: loaded
[ 0.188593] fuse: init (API version 7.40)
[ 0.189271] integrity: Platform Keyring initialized
[ 0.189284] integrity: Machine keyring initialized
[ 0.189296] Key type asymmetric registered
[ 0.189299] Asymmetric key parser 'x509' registered
[ 1.089638] Freeing initrd memory: 34476K
[ 1.109875] alg: self-tests disabled
[ 1.110295] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.110444] io scheduler mq-deadline registered
[ 1.120015] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.132074] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.133708] feb50000.serial: ttyS2 at MMIO 0xfeb50000 (irq = 26, base_baud = 1500000) is a 16550A
[ 1.134702] Serial: AMBA driver
[ 1.135240] msm_serial: driver initialized
[ 1.135336] SuperH (H)SCI(F) driver initialized
[ 1.141931] mousedev: PS/2 mouse device common for all mice
[ 1.145151] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.145421] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[ 1.145573] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 1.145612] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[ 1.152612] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 1.155268] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[ 1.156590] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[ 1.160083] NET: Registered PF_INET6 protocol family
[ 1.181012] Segment Routing with IPv6
[ 1.181062] In-situ OAM (IOAM) with IPv6
[ 1.181118] mip6: Mobile IPv6
[ 1.181129] NET: Registered PF_PACKET protocol family
[ 1.181445] mpls_gso: MPLS GSO support
[ 1.186920] registered taskstats version 1
[ 1.187081] Loading compiled-in X.509 certificates
[ 1.190714] Loaded X.509 cert 'Build time autogenerated kernel key: 685dd22c310ba7da5a0e14d95318479abbb008bd'
[ 1.196685] Demotion targets for Node 0: null
[ 1.197214] Key type .fscrypt registered
[ 1.197218] Key type fscrypt-provisioning registered
[ 1.241983] Key type encrypted registered
[ 1.242019] AppArmor: AppArmor sha256 policy hashing enabled
[ 1.242042] ima: No TPM chip found, activating TPM-bypass!
[ 1.242046] ima: Allocated hash algorithm: sha256
[ 1.242070] ima: No architecture policies found
[ 1.242102] evm: Initialising EVM extended attributes:
[ 1.242105] evm: security.selinux
[ 1.242108] evm: security.SMACK64 (disabled)
[ 1.242111] evm: security.SMACK64EXEC (disabled)
[ 1.242113] evm: security.SMACK64TRANSMUTE (disabled)
[ 1.242116] evm: security.SMACK64MMAP (disabled)
[ 1.242118] evm: security.apparmor
[ 1.242121] evm: security.ima
[ 1.242124] evm: security.capability
[ 1.242126] evm: HMAC attrs: 0x1
[ 1.277416] clk: Not disabling unused clocks
[ 1.277426] PM: genpd: Disabling unused power domains
[ 1.280791] Freeing unused kernel memory: 2816K
[ 1.393859] Checked W+X mappings: passed, no W+X pages found
[ 1.393878] Run /init as init process
[ 1.393881] with arguments:
[ 1.393886] /init
[ 1.393889] with environment:
[ 1.393892] HOME=/
[ 1.393895] TERM=linux
[ 2.492987] usbcore: registered new interface driver usbfs
[ 2.493014] usbcore: registered new interface driver hub
[ 2.493042] usbcore: registered new device driver usb
[ 2.503553] platform fe470000.i2s: Fixed dependency cycle(s) with /i2c@fec80000/codec@1a
[ 2.503691] i2c 6-001a: Fixed dependency cycle(s) with /i2s@fe470000
[ 2.514751] rockchip-vop2 fdd90000.vop: Adding to iommu group 0
[ 2.635188] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.635201] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.636632] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.636638] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.639028] sdhci: Secure Digital Host Controller Interface driver
[ 2.639035] sdhci: Copyright(c) Pierre Ossman
[ 2.656799] rockchip-hdptx-phy fed60000.phy: [DEBUG rk_hdptx_phy_probe] phy_set_drvdata done, about to devm_pm_runtime_enable
[ 2.656866] rockchip-hdptx-phy fed60000.phy: [DEBUG rk_hdptx_phy_runtime_resume] called
[ 2.657881] rockchip-spi feb10000.spi: Runtime PM usage count underflow!
[ 2.659967] Synopsys Designware Multimedia Card Interface Driver
[ 2.662767] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 2.662779] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 2.663561] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.663953] rockchip-spi feb20000.spi: Runtime PM usage count underflow!
[ 2.665516] rockchip-hdptx-phy fed70000.phy: [DEBUG rk_hdptx_phy_probe] phy_set_drvdata done, about to devm_pm_runtime_enable
[ 2.665536] rockchip-hdptx-phy fed70000.phy: [DEBUG rk_hdptx_phy_runtime_resume] called
[ 2.666534] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/regulators/dcdc-reg7
[ 2.666649] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs1_pwrdn
[ 2.666668] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs3_null
[ 2.666684] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/rk806_dvs2_null
[ 2.666699] spi spi2.0: Fixed dependency cycle(s) with /spi@feb20000/pmic@0/dvs1-null-pins
[ 2.668118] rockchip-hdptx-phy fed60000.phy: [DEBUG rk_hdptx_phy_runtime_resume] called
[ 2.668795] rockchip-hdptx-phy fed70000.phy: [DEBUG rk_hdptx_phy_runtime_resume] called
[ 2.671509] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.672693] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 2.672908] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.673568] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 2.673759] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.674064] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 2.674175] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.674475] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 2.674608] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.674802] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 2.729594] rockchip-dw-pcie a41000000.pcie: host bridge /pcie@fe190000 ranges:
[ 2.729616] rockchip-dw-pcie a41000000.pcie: IO 0x00f4100000..0x00f41fffff -> 0x00f4100000
[ 2.729628] rockchip-dw-pcie a41000000.pcie: MEM 0x00f4200000..0x00f4ffffff -> 0x00f4200000
[ 2.729636] rockchip-dw-pcie a41000000.pcie: MEM 0x0a00000000..0x0a3fffffff -> 0x0040000000
[ 2.729749] rockchip-dw-pcie a41000000.pcie: iATU: unroll T, 8 ob, 8 ib, align 64K, limit 8G
[ 2.730038] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 2.745289] fan53555-regulator 1-0042: FAN53555 Option[10] Rev[1] Detected!
[ 2.745663] fan53555-regulator 0-0043: FAN53555 Option[10] Rev[1] Detected!
[ 2.746244] fan53555-regulator 0-0042: FAN53555 Option[10] Rev[1] Detected!
[ 2.763494] rtc-pcf8523 6-0068: registered as rtc0
[ 2.764991] rtc-pcf8523 6-0068: setting system clock to 2024-11-16T10:43:39 UTC (1731753819)
[ 2.766382] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 2.766391] rk_gmac-dwmac fe1b0000.ethernet: IRQ sfty not found
[ 2.766598] rk_gmac-dwmac fe1b0000.ethernet: supply phy not found, using dummy regulator
[ 2.766772] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 2.766778] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: tx_delay.
[ 2.766782] rk_gmac-dwmac fe1b0000.ethernet: set tx_delay to 0x30
[ 2.766787] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 2.766791] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0x10
[ 2.766800] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 2.771835] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_ID
[ 2.772114] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 2.772130] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 2.772135] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 2.772139] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 2.772142] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 2.772146] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 2.772190] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 2.772194] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 2.772234] rk_gmac-dwmac fe1b0000.ethernet: device MAC address 8a:a1:ea:30:9d:cd
[ 2.772239] rk_gmac-dwmac fe1b0000.ethernet: Enabled L3L4 Flow TC (entries=2)
[ 2.772244] rk_gmac-dwmac fe1b0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 2.772249] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 2.772252] rk_gmac-dwmac fe1b0000.ethernet: SPH feature enabled
[ 2.772256] rk_gmac-dwmac fe1b0000.ethernet: Using 32/32 bits DMA host/device width
[ 2.774273] mdio_bus stmmac-0: MDIO device at address 0 is missing.
[ 2.803002] rk_gmac-dwmac fe1b0000.ethernet end0: renamed from eth0
[ 2.812057] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.812092] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 2.812222] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[ 2.812255] xhci-hcd xhci-hcd.0.auto: irq 57, io mem 0xfc000000
[ 2.812348] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 2.812356] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 2.812362] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 2.812443] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.11
[ 2.812451] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.812456] usb usb1: Product: xHCI Host Controller
[ 2.812461] usb usb1: Manufacturer: Linux 6.11.7-mnt-reform-arm64 xhci-hcd
[ 2.812465] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 2.812900] hub 1-0:1.0: USB hub found
[ 2.812918] hub 1-0:1.0: 1 port detected
[ 2.813109] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.813154] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.11
[ 2.813161] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.813166] usb usb2: Product: xHCI Host Controller
[ 2.813169] usb usb2: Manufacturer: Linux 6.11.7-mnt-reform-arm64 xhci-hcd
[ 2.813173] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 2.813470] hub 2-0:1.0: USB hub found
[ 2.813485] hub 2-0:1.0: 1 port detected
[ 2.813949] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.813960] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 2.814062] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000808002000010
[ 2.814088] xhci-hcd xhci-hcd.1.auto: irq 58, io mem 0xfc400000
[ 2.814198] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 2.814205] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 2.814212] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 2.814306] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.11
