I’m pretty new to the space, and as I was reading throuh some of the specs, I had this question - Can you have a wifi card and m.2 storage at the same time with the RK3588 configuration of the Reform? (I’m fairly certain you can, just making sure so I don’t make the mistake of buying an expensive device that won’t be able to meet my basic computer needs)
Thanks for any help!
Hey there
It should be possible to use a m.2 storage and a WiFi card at the same time.
According to the specs and the user manual there are two slots on the board. But be aware that the keying of the slots is different.
Since MNT offers some great documentation I recommend some research here:
https://mntre.com/docs-reform.html#laptop
I hope that helps.
Cheers,
Triss
Awesome! Definitely have some fun projects in mind for the Reform, can’t wait to start!
