I just received my Pocket Reform and installed an SSD. I understand I have to run reform-setup-encrypted-nvme to set it up which should be located in /sbin - but I didn’t find it and whereis could not find it, either. So where is it? I did update all packages with apt-get ans I think the signature for the MNT Debian Tools repository might be missing - but I am not sure wether that is an error.
Yes, running that script is one of the options you have.
No, it should be located in /usr/sbin
but since /sbin
is a symlink to /usr/sbin
that should make a difference in practice.
Can you paste the output of this command, please:
ls -lha /usr/sbin/reform-setup-encrypted-nvme
Did you run whereis as the superuser? If not, /usr/sbin
will not be in your $PATH
because your normal user does not have the required privileges to run that script.
Can you try running this:
sudo which reform-setup-encrypted-nvme
To find out which package contains the script you can run this:
dpkg-query --search /usr/sbin/reform-setup-encrypted-nvme
This should tell you that the script is part of the package reform-tools
. If it does, then this also means that you have reform-tools
installed as is required.
It is not. It is intentional.
Thank you. I reinstalled reform-tools
and that made the script reappear.
