I attached a gitlab-runner to my fork of reform-system-image, but I am struggling to get past a “couldn’t allocate” error.
I added a df
to indicate the amount of available free space and also turned by inotify up significantly, but still errors. Any tricks I am not aware of which we use to get the job to complete in the upstream repo?
[opc@k3s01 ~]$ sudo sysctl fs.inotify.max_user_watches
fs.inotify.max_user_watches = 524288
[opc@k3s01 ~]$ sudo sysctl fs.inotify.max_user_instances
fs.inotify.max_user_instances = 8192
+ mmtarfilter '--path-exclude=*' --path-include=/boot '--path-include=/boot/*' --strip-components=2
copying from tar archive -
+ dd if=boot.img of=reform-rescue-system.img seek=1 bs=4194304
122+0 records in
122+0 records out
511705088 bytes (512 MB, 488 MiB) copied, 0.594908 s, 860 MB/s
+ df -h
Filesystem Size Used Avail Use% Mounted on
overlay 99G 3.5G 90G 4% /
tmpfs 64M 0 64M 0% /dev
shm 64M 0 64M 0% /dev/shm
/dev/sdb 99G 3.5G 90G 4% /cache
+ rm boot.img
+ mmtarfilter '--path-exclude=/boot/*'
+ genext2fs --block-size 1024 --size-in-blocks 2097152 --bytes-per-inode 16384 --tarball - root.img
genext2fs: couldn't allocate a block (no free space)
Traceback (most recent call last):
File "/usr/bin/mmtarfilter", line 244, in main
out_tar.addfile(member, file)
File "/usr/lib/python3.11/tarfile.py", line 2030, in addfile
copyfileobj(fileobj, self.fileobj, tarinfo.size, bufsize=bufsize)
File "/usr/lib/python3.11/tarfile.py", line 251, in copyfileobj
dst.write(buf)
File "/usr/lib/python3.11/tarfile.py", line 437, in write
self.__write(s)
File "/usr/lib/python3.11/tarfile.py", line 445, in __write
self.fileobj.write(self.buf[:self.bufsize])
BrokenPipeError: [Errno 32] Broken pipe
full job log build (#1653) · Jobs · Adam Chasen / reform-system-image · GitLab
