It is installed in the reform-tools package.
Got it running. Thank you very much for your help.
I have a charger v2 and have yet to have this issue anymore!
I feel it’s in order for an update.
I’ve installed all the new parts I ordered (new WiFi module + daughter board) and the new charger board v2 as well as a newer carrier board for the rk3588. So far, after days of uptime, a couple of restarts and shutdown start-up cycles I have not experienced any problems. (Also the WiFi is super good and stable now!) It’s probably not only thanks to the new hardware as the software is kept up to date as well, and reform-power-deamon is doing it’s thing. But by all intends and purposes I find this problem practically solved for now.
Though I still have virtual power drops from time to time as I get pop-ups from KDE saying there’s only 6 % battery left. Which then after a second or two reverts to the actual %. So I guess the root cause still isn’t fully gone. (Need to record if this is only on battery or not)
But I feel I’m slowly starting to trust the machine to not fail on me which is very welcome.
