Scanlines for ZZ9000 scandoubler
Hi there.
I want to ask about scanlines with the ZZ9000 scandoubler.
I have been waiting for this a long time more than any other feature.
The scandoubler of the ZZ9000 does an excellent job and does play nice in 50 Hz. It only lacks scanlines, which (forgive my ignorance) seems like a simple feature, implemented in every Indivision so far and even Pi-RGB stuff.
Is there finally an ETA about the scanlines for the native low res screens (games)?
Thanks.
Regards.
Hi! Thanks for the feedback. What are your minimum requirements for scanlines? Darken every 2nd line?
Hi.
Yes it is necessary to darken evey second line.
For instance, the Indivision AGA MK3 as an option to choose how much the user want to darken and a nice setup is generally around 13%. Some others have an option to opt for thin or thick scanlines. Those two parameters should be adjustable to the taste of the user.
Thanks.
Best regards.
Hi Mnt.
I would like to know if there is any progress about scanlines support for the zz9000 please.
Thanks.
Hello MNT.
Would like to have an update about those scanlines on the ZZ9000 scandoubler?
There has been no word of updates for a long time but actually i am only interested in the possibility for the user to set up scanlines according to his taste.
Thanks.
Hi MNT.
Will we ever have scanlines emulation with the ZZ9000?
As a customer, that is the last thing i need from this product.
