I have noticed that screen starts flickering after it wakes up from blanking and/or locking in GNOME. Sometimes flickering is so severe that it is unworkable, sometimes flickering is not as obvious. It requires power cycling in order to stop the flickering.
Also noticed that system does not power down all the way on “Power off,” I need to go keyboard OLED menu and power off after the OS shutdown.
Here is current reform-check result:
shigeru@mntpr-0:~$ sudo reform-check
I: `uname -a` output: Linux mntpr-0 6.15.3-mnt-reform-arm64 #1 SMP Debian 6.15.3-1~exp1+reform20250624T140900Z (2025-06-24) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.15.3-1~exp1+reform20250624T140900Z
I: Version of reform-tools: 1.74-1+reform20250622T103710Z+1
E: Your /etc/skel/.profile contains an outdated line that attempts to print /etc/reform-help or run reform-help.
E: Consider simply deleting that offending last line of your /etc/skel/.profile.
Just an update: Kind of hoped some improvement with flickering with new kernel version update, but behavior has not changed so far…
I: `uname -a` output: Linux mntpr-0 6.15.6-mnt-reform-arm64 #1 SMP Debian 6.15.6-1~exp1+reform20250713T202422Z (2025-07-13) aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.15.6-1~exp1+reform20250713T202422Z
I: Version of reform-tools: 1.75-2+reform20250622T103710Z+1
