Recently upgraded my reform classic to the rk3588 module since then I’ve had a problem with screen flickering. For the most part it works fine but occasionally the screen goes essentially black either by flickering or just being black. It’s not completely black but without lighting (sorta like an old gameboy screen). Moving the hinges seems to affect it but it’s not consistent and sometimes the screen starts acting up on its own. To me it seems like a hardware problem and I’m thinking maybe it’s related to the display cable which is very tight since the upgrade. Anyone had any similar problems and/or know a way to fix it?
I have seen thes here as well though the cable here is not tight
This sounds like a screen cable issue to me, have you tried unplugging the display cables from the display itself and the connector on the board and then plugging them back in? Maybe just a bad connection. You could also do the same with the DSI flex cable under the RCORE module.
Sorry for late reply. FInally got a chance to try this a couple of weeks ago and it works flawlessly now. Wanted to test it out first so I was sure it wasn’t a fluke but no flickering since I replugged the display cables. Thanks!
Very glad to hear that solved the issue!
