Every couple of weeks or so I hear a screw rolling around in my Reform’s chassis and have to open it up to put back whichever screw (usually off the motherboard or the power board) has come loose. I’ve just put Loctite Blue on all the motherboard, power board, and trackball screws on the underside of the machine, as well as all the keyboard screws under the frame, and some of the monitor screws I noticed were loose. (My original plan was just to coat the motherboard and power board screws, since those were what kept coming totally unscrewed, but I went over every screw in my machine and found quite a few others were working themselves loose as well.)
If this turns out to have been a bad idea, I’ll report back. Otherwise, consider this a reminder to check all the screws on your machine to make sure none of them are coming loose. Having a loose screw short out some some part of your battery board is sure to be a bad time. I was surprised to find that even the screws on my monitor’s frame had come loose enough to wear off the coating on the metal opposite when the laptop is closed.
Hmmm, can I ask for how long you’ve had your reform? I have had mine since near the middle of December last year, and I have not noticed anything similar. I’m trying to gauge how often I should be checking.
I really do love the way the Reform is assembled. Very easy to get to everything.
It didn’t come down to the screws rolling free in the chassis for me, but I did notice the bottom cover screws are constantly becoming tactile - they should be hidden in countersinks normally (and they are initially) but then I start feeling them with a time, till i tighten them again. I didn’t check other screws though last time I opened the chassis, maybe other screws are about to fall out.
I’ve had mine since the beginning of September last year.
Yes, the build is nice. I’ve certainly appreciated the ease with which I can access everything. Much less of a hassle to take apart than the old Thinkpad T500 I had before. I imagine there’s some variance with regard to manufacturing, and I might have just gotten one with slightly looser screws or something. Also, patterns of use differ, and I may be subjecting it to more vibration than average for all I know. But if you’re like me and find yourself opening the bottom to clean things up whenever you notice crumbs and hairs accumulating there, it might not hurt to also check up on your screws while you’re in there.
Not sure. I do know that you are not supposed to over torque the screws going into the acrylic bottom cover. Excessive pressure from the screws will cause it to crack.
Everything else I’m not sure. After reading this I went to and retighten all the mainboard screws I could reach easily. I too have a DIY version.
