SD card slot weirdness
I’m asking this for informational purposes more than anything else – this is absolutely not a high priority, just a mysterious thing.
I can only assume this is a configuration issue on my part, but for some reason, I can’t see my sd slot when I boot via an eMMC boot partition and an encrypted nvme drive.
I can boot off an sd card in the slot with no trouble, and when I do that, I can (obviously) see the sd card, the emmc module, and the nvme drive. I can use a USB SD card dongle, and that works just fine, so I know the card itself (and the adapter, ‘cause it’s a micro SD card) work okay — I can boot with it and I can read/write to it via the dongle.
But when I boot normally, the sd card is just invisible. I noticed that I also don’t have /dev/mmcblk1 entries on my nvme deployment. Is this expected? I’ve had enough weirdness, so maybe it’s time I backup my homedir and do a reinstall?
I’ve got a v2.5 motherboard, I think, and it’s quite possible I don’t have up to date firmware – I haven’t reflashed anything.
reform-check:
I: Contents of /proc/device-tree/model: MNT Reform 2 with RCORE-DSI RK3588 Module
I: uname -a output: Linux reform 6.16.12-mnt-reform-arm64 #1 SMP PREEMPT Debian 6.16.12-2+reform20250910T145641Z (2025-09- aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.16.12-2+reform20250910T145641Z
I: Version of reform-tools: 1.79-2+reform20251023T130442Z+1
I: Version of system image: System Image v4: 2025-05-02
I: Version of LPC firmware: MREF2LPC 25_R2 20230703
I: Version of U-Boot: 2024.10-g424c714eb247-dirty
I: Latest version of U-Boot: 2025-05-06
I: probably booting via /boot/boot.scr (/boot/extlinux/extlinux.conf does not exist)
I: Mount source of /: /dev/reformvg/root (LVM vg ‘reformvg’ on LUKS device ‘reform_crypt’ on SSD)
I: Mount source of /boot: /dev/mmcblk0p1 (eMMC)
??5??? /var/lib/alsa/asound.state
I: /boot/initrd.img-6.15.4-mnt-reform-arm64 does not belong to any installed kernel package
I: /boot/vmlinuz-6.15.4-mnt-reform-arm64 does not belong to any installed kernel package
I: the reform-qcacld2 package package is only required for wifi on the Pocket Reform with i.MX8MP, you can safely remove it unless you plan to go back to the imx8m+
I: eMMC contains the latest u-boot version 2025-05-06
One of the differences is this:
I: Version of system image: System Image v4: 2025-05-02 – pretty sure when I boot off the SD card, this shows as System Image v5.
lsblk from the emmc+nvme boot, with the SD card in the SD slot:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 233G 0 disk
├─mmcblk0p1 179:1 0 488M 0 part /boot
└─mmcblk0p2 179:2 0 232.5G 0 part
nvme0n1 259:0 0 953.9G 0 disk
└─reform_crypt 254:0 0 953.9G 0 crypt
├─reformvg-swap 254:1 0 4G 0 lvm [SWAP]
└─reformvg-root 254:2 0 949.9G 0 lvm /
mmcblk0boot0 179:256 0 4M 1 disk
mmcblk0boot1 179:512 0 4M 1 disk
lsblk when booted from the SD card:
mmcblk1 179:0 0 59.5G 0 disk
├─mmcblk1p1 179:1 0 488M 0 part /boot
└─mmcblk1p2 179:2 0 59G 0 part /
mmcblk0 179:256 0 233G 0 disk
├─mmcblk0p1 179:257 0 488M 0 part
└─mmcblk0p2 179:258 0 232.5G 0 part
mmcblk0boot0 179:512 0 4M 1 disk
mmcblk0boot1 179:768 0 4M 1 disk
Like I said, this is probably a me problem.
I have been seeing that here as.well
That’s okay. This line is just supposed to show how old the system image was from which you installed your current system. That information is “stored” in /etc/motd.
Maybe not. I had it happen to my motherboard 2.5 that the sd-card slot became unreliable. It turns out that one of the metal pins which was involved in detecting whether an sd-card was inserted or removed got bent over time such that it didn’t work properly anymore. Bending all the metal pins back a tiny bit through the metal case with a thin stick fixed the problem for me.
Classic Reform with motherboard 2.5 and RCORE-DSI upgrade?
thats the one
I was thinking that it might be a kernel issue but not sure
I’ll give that a try – it’s interesting that it seems to have very consistent behavior:
  • Boot off the SD card, the SD card is visible
  • Boot off the eMMC + nvme, SD card is not visible.
That said, I could easily see uboot ignoring the “sense” pin and just assuming (correctly) that something is there and using it, resulting in a working system that of course “knows” the SD card is there.
Possibly related, I did discover, very accidentally, that I can insert an SD card into the slot backward and it goes in and engages the soft-click mechanism. I could easily have bent the pins when I did that.
