Signal Messenger and the Reform Laptop
Thanks to Lukas’ help on the IRC channel I was made aware of this Mobian build for the Signal Desktop client. It works very well on the Reform.
https://wiki.mobian-project.org/doku.php?id=signaldesktop
and if you would like to compile it yourself:
Hope that helps!
Out of desperation, I will definitely be trying this myself, so thanks!
Until now my preferred solution has been running a signal-matrix bridge, but it’s really not ideal.
I hope in the future running Signal on arm can somehow become more sustainable.
Indeed it’s a shame they don’t offer a build. Telegram for example works really well.
Well yeah, but Telegram also has a web client, which makes using it a piece of cake. I don’t particularly care for Telegram though, so I don’t use it much.
I agree. BUT… I’ve recently been using this build:
http://elagost.com/flatpak/
As It recently started using gitlab CI for compiling.
And I finally realize… Signal (or probably any other electron-based thing?) is just way too bloated to run on Reform. It’s ridiculous. I really want this, but I might be going back to a bridge solution. When the chats get large- especially if there are lots of images- it will chew through your RAM.
Hmm I have Signal open with Dino and a host of other applications running. I am sure I am using the swap, but I haven’t seen any slow downs with it. It runs very smoothly and is completely functional. I agree though, electron apps suck.
I use GitHub - boxdot/gurk-rs: Signal Messenger client for terminal
There is a small set of people working it. It has a nice set of features now which make it usable for 90%. The navigation is a bit different, but quick to learn.
NOTE: The one major issue is that I run into “silent” failures (message not received or not send) occasionally which pulls be back to upstream signal client. It doesn’t handle some “states” very well yet which usually requires a “reset” which in the Signal ecosystem means no history (or in the case of gurk, no address book sync yet). I believe this is partially the upstream library catching up and partially the developers haven’t personally run into the state yet. They are pretty responsive though.
This may sound crazy, but I wonder if Anbox/Waydroid and the Android Signal client would be resource efficient enough? One snag I can think of is I do believe only one mobile client per account is allowed (so it would steal it from the app on a mobile if you use one).
Aside: I am considering switching to XMPP or Matrix with a gateway to “unify”
Yeah I use XMPP myself with the Dino client. It works great. on mobile Conversations IM is the defacto Android client setting the standards for all other clients.
That is cool that there is a Signal terminal client, thanks for sharing!
I’ve personally been using scli. It was a bit of a hassle to get compiled, though. I’ll have to try gurk.
Edit: For the curious, the key to getting scli working was compiling and providing a native libsignal for signal-cli using the instructions on this wiki page: Provide native lib for libsignal · AsamK/signal-cli Wiki · GitHub
Edit: Immediately getting this error when trying to compile gurk:
error: failed to compile `gurk v0.2.5-dev (https://github.com/boxdot/gurk-rs#3f200fc5)`, intermediate artifacts can be found at `/tmp/cargo-installWYGigm`
Caused by:
  failed to select a version for the requirement `curve25519-dalek = "^2.0.0"`
  candidate versions found which didn't match: 3.2.1
  location searched: Git repository https://github.com/signalapp/curve25519-dalek.git?branch=lizard2
  required by package `zkgroup v0.7.3 (https://github.com/signalapp/zkgroup?tag=v0.7.3#197c382e)`
      ... which satisfies git dependency `zkgroup` of package `libsignal-service v0.1.0 (https://github.com/whisperfish/libsignal-service-rs?rev=efd4ea86f57520d99141bb9c1c4b38a2ac646d6a#efd4ea86)`
      ... which satisfies git dependency `libsignal-service` of package `presage v0.2.0 (https://github.com/whisperfish/presage.git?rev=8fcfb65#8fcfb651)`
      ... which satisfies git dependency `presage` of package `gurk v0.2.5-dev (/home/hex/.cargo/git/checkouts/gurk-rs-7cf8dc9d9ee78b42/3f200fc)`
What was the command you used to build. I am successful with:
crgo install --locked --git https://github.com/boxdot/gurk-rs gurk
NB: the --locked is necessary due to library dependencies moving quickly upstream which break some compatibility
FWIW I searched for this thread today to look for the “unofficial signal desktop build” link but couldn’t find it. But I found there’s a flatpak build that also includes arm64 which I’m trying today: Signal aarch64 Flatpak
I tried this build which seems to work fine: GitHub - dennisameling/Signal-Desktop: Signal — Private Messenger for Windows, Mac, and Linux
Sorry, but the linked flatpak is unofficial right? Or did I miss something?
@uninosho The flatpak build https://flathub.org/en/apps/org.signal.Signal is not built by Signal (or at least, they haven’t bothered to verify it comes from Signal).
I have been helping to build it from scratch: undef / signal-desktop-builder · GitLab and it’s actually pretty fast to do it on an rk3588 processor. I include the builds here: Package registry · undef / signal-desktop-builder · GitLab
For anyone interested: I just installed the Nix package manager on Debian. They also ship an ARM build of signal-desktop which seems to work perfectly :slight_smile:
It’s also available via apk add signal-desktop on Alpine linux. Been using it for some time. It’s in the testing repo
I got it installed but the linking to my phone isn’t working.
signal-desktop --trace-deprecation
NODE_ENV production
NODE_CONFIG_DIR /opt/Signal/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData:
(node:14186) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
at asarStatsToFsStats (node:electron/js2c/node_init:2:1791)
at t.lstat (node:electron/js2c/node_init:2:5304)
at LOOP (node:fs:2927:15)
at process.processTicksAndRejections (node:internal/process/task_queues:85:11)
[14277:0624/174302.900983:ERROR:media/gpu/vaapi/vaapi_wrapper.cc:1658] vaInitialize failed: unknown libva error
It’s progress though. I managed to link my other debian laptop, although thats amd64.
This is just on a standard reform setup.
I’ve managed to successfully build the official Signal Desktop client (version 8.18.0-alpha.1) for arm64 on Debian and so far it works great on my MNT Reform.
Here are the steps:
  1. sudo apt install gcc g++ make
  2. Install nvm: GitHub - nvm-sh/nvm: Node Version Manager - POSIX-compliant bash script to manage multiple active node.js versions · GitHub
    1. wget https://raw.githubusercontent.com/nvm-sh/nvm/v0.40.5/install.sh
    2. bash install.sh
  3. git clone https://github.com/signalapp/Signal-Desktop.git
  4. cd Signal-Desktop
  5. nvm install
  6. Install pnpm: Installation | pnpm
    1. npm install --global corepack@latest
    2. corepack enable pnpm
  7. pnpm install
  8. pnpm prepare-linux-build
  9. Patch package.json to switch from x64 to arm64 build for Debian Linux .deb (you can also just manually edit the file):
patch <<EOF
diff --git a/package.json b/package.json
index ea951f09e..8a7118b87 100644
--- a/package.json
+++ b/package.json
@@ -493,7 +493,7 @@
       "target": [
           "target": "deb",
-          "arch": "x64"
+          "arch": "arm64"
       "icon": "build/icons/png",
EOF
  1. pnpm build-linux
  2. sudo apt install ./release/signal-desktop_8.18.0-alpha.1_arm64.deb (adjust the filename as needed)
Out of curiosity what is the current status on getting Signal on Pocket Reform?
Do either of the official downloads methods work?
I’m using nix and homeManager to install Signal, and that works.
I’ve been meaning to write a blog post about it for the longest time. I’ll see if I can get around to it.
