How old is your Reform? The trackball design was modified in later builds to lower the height and fix the problem, to the best of my knowledge, so unless you have one from the original run you won’t see the problem.
I can tell you that on mine, from the first batch, it’s definitely not a user error: mine has never spent any time inverted, beyond when I was first assembling it, and has never been in a backpack.
