[SOLVED] Dosbox, Debian Stable, Pocket Reform
I mentioned all the things in the title because I feel they all are in play with the issue I am having. Dosbox used to run perfectly to include sound. Dosbox still runs perfectly but with zero sound. No PC speaker, no sound blaster or midi emulation.
I know that my Pocket on Debian stable is using pipewire. All videos and music play and sound works great everywhere else. Except in box64. Sound stopped working there as well!
I’m at a loss as to how I would fix this. I think some how the audio backend changed and everything is trying to interface with the wrong audio backend.
I just don’t know how to go about running that suspicion to ground, so to say.
Anybody else dealt with this kind of thing before?
Ok I got this working. Switched to the Dosbox-x flatpak and was able to verify a few settings. Ultimately opening the pulseaudio mixer and setting dosbox-x to use the correct audio output did the trick.
