[SOLVED] Pocket Reform IX Industrial Ethernet port adapter
Has anyone found an adapter for the Pocket’s IX port? Basically, so you could plug a standard ethernet cable into it?
I have tried some searching on Amazon and Reichelt but have had no luck. Language issue might be the reason for Reichelt.
Have you found one? Could you please share what you got and from where? Thanks!
Yes.
It works perfectly
If you’re in the UK (not knowing where you are), I still have a few available.
