[SOLVED] Sound not working
Hello everyone!
I’m not exactly sure when this started happening because I don’t usually use my Pocket Reform for this kind of thing, but I just realized that the sound isn’t working.
I’m quite lost, but I understand that my configuration to listen through the speaker is correct:
Default Server: Pocket
Default Sink: Built-in Audio Mono 96%
Default Source: Built-in Audio Mono 100%
If I change these options to:
Default Sink: Built-in Audio Stereo 100% [muted]
Default Source: Built-in Audio Stereo 100%
I can play videos in Firefox, but I still can’t hear anything. The speaker icon on the Sway bar shows as muted, and I can’t change it. Do you know how I could fix this?
Thank you!
Can you open volume control and go to the output tab? There you should see a mute button that is active. If you click it, this should undo the mute. How you muted it is kind of a mystery at this point but hopefully this does the trick.
Problem solved with an amazing key combination: Super + Hyper + 5.
I must have pressed this combination by mistake at some point :person_facepalming:
