[solved] Turning on MNT Pocket Reform
I cannot seem to get it to turn on, I keep pressing Hyper + enter, for more than 2 seconds, but it won’t boot, am I missing something?
Do i need it to be fully charged first or press some other button first?
I just got it a few days ago.
Did you flip the hidden switch on the bottom left side of the screen?
Not sure, don’t think so… how do I do that?
You’ll need a small pointy thing (like a SIM ejector tool) - there’s a small slit in the left side of your lid. If you look carefully, you’ll see a small switch, which needs to be pushed upwards to switch power to your board, then you should be able to access the OLED menu.
Thanks, that helped enormously.
