At reform2-3d-printed-parts · master · Reform / reform · GitLab I can find the STL files for the trackball, trackpad, and speaker mounts. But there does not appear to be any of the source files for any of these models, be they openSCAD or Autodesk or whatnot.
I was hoping to modify the trackball mount to include space for mounting chrome steel ball bearings, and while I could attempt to modify the STL it’d be much cleaner to change the source files. I was wondering if these sources were available?
As an aside is there also a reference to what heat fit brass inserts are used for the trackball assembly?
