Hello! I’ve been unable to suspend/resume on Pocket Reform on A311D – suspend appears to work but it’s impossible to resume, due to a kernel error during the process of suspending. I’ve attached a log (with loglevel=7) from over serial below, taken during sudo systemctl suspend. There’s no further output if I try to wake the device using the menu on the system controller. I’m curious:
- Is this what people are seeing on A311D on other devices, either Pocket Reform or Reform?
- Does anyone recognize this trace, before I dive deeper into it?
[ 50.465859] wlx000a5205ed22: authenticate with 0c:80:63:cd:0f:f6 (local
address=00:0a:52:05:ed:22)
[ 50.469429] wlx000a5205ed22: send auth to 0c:80:63:cd:0f:f6 (try 1/3)
[ 50.880015] wlx000a5205ed22: send auth to 0c:80:63:cd:0f:f6 (try 2/3)
[ 50.881489] wlx000a5205ed22: send auth to 0c:80:63:cd:0f:f6 (try 3/3)
[ 51.296033] wlx000a5205ed22: authentication with 0c:80:63:cd:0f:f6 timed out
[ 57.776632] panel-jdi-lt070me05000 ffd07000.dsi.0: vsync-shift from device tree: 1
[ 78.654120] PM: suspend entry (deep)
[ 78.662892] Filesystems sync: 0.008 seconds
[ 79.004547] Freezing user space processes
[ 79.006234] Freezing user space processes completed (elapsed 0.001 seconds)
[ 79.009998] OOM killer disabled.
[ 79.013194] Freezing remaining freezable tasks
[ 79.018974] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[ 79.925031] meson-pcie fc000000.pcie: error: wait linkup timeout
[ 79.925834] Disabling non-boot CPUs ...
[ 79.930499] IRQ22: set affinity failed(-22).
[ 79.931615] psci: CPU1 killed (polled 0 ms)
[ 79.939232] IRQ22: set affinity failed(-22).
[ 79.940314] psci: CPU2 killed (polled 4 ms)
[ 79.948029] IRQ22: set affinity failed(-22).
[ 79.949102] psci: CPU3 killed (polled 0 ms)
[ 79.956013] IRQ22: set affinity failed(-22).
[ 79.957087] psci: CPU4 killed (polled 0 ms)
[ 79.964808] IRQ22: set affinity failed(-22).
[ 79.965880] psci: CPU5 killed (polled 0 ms)
bl30 get wakeup sources!
process command 00000006
bl30 enter suspend!
Little core clk suspend rate 1000000000
Big core clk suspend rate 24000000
store restore gp0 pll
suspend_counter: 1
Enter ddr suspend
ddr suspend time: 15us
alarm=0S
process command 00000001
cec ver:2018/04/29
CEC cfg:0x0000
use vddee new table!
exit_reason:0x06
Enter ddr resume
ddr resume time: 123us
cfg15 3b00000
cfg15 63b00000
Lit[ 79.972457] Enabling non-boot CPUs ...
[ 79.972945] Detected VIPT I-cache on CPU1
[ 79.973025] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 79.973873] CPU1 is up
[ 79.984530] Detected VIPT I-cache on CPU2
[ 79.984595] arch_timer: CPU2: Trapping CNTVCT access
[ 79.984609] CPU2: Booted secondary processor 0x0000000100 [0x410fd092]
[ 79.985091] cpufreq: cpufreq_online: CPU2: Running at unlisted initial frequency: 999999 KHz,
changing to: 1000000 KHz
[ 80.009931] CPU2 is up
[ 80.012300] Detected VIPT I-cache on CPU3
[ 80.012335] arch_timer: CPU3: Trapping CNTVCT access
[ 80.012343] CPU3: Booted secondary processor 0x0000000101 [0x410fd092]
[ 80.012885] CPU3 is up
[ 80.030041] Detected VIPT I-cache on CPU4
[ 80.030076] arch_timer: CPU4: Trapping CNTVCT access
[ 80.030085] CPU4: Booted secondary processor 0x0000000102 [0x410fd092]
[ 80.030654] CPU4 is up
[ 80.047800] Detected VIPT I-cache on CPU5
[ 80.047836] arch_timer: CPU5: Trapping CNTVCT access
[ 80.047844] CPU5: Booted secondary processor 0x0000000103 [0x410fd092]
[ 80.048675] CPU5 is up
tle core clk resume rate 1000000000
Big core clk resume rate 50000000
[ 80.115334] meson-pcie fc000000.pcie: error: wait linkup timeout
[ 80.116296] nvme 0000:01:00.0: Unable to change power state from D3hot to D0, device inaccess
ible
[ 80.176107] meson-pcie fc000000.pcie: error: wait linkup timeout
[... 189 of these meson-pcie fc000000.pcie: error: wait linkup timeout messages]
[ 89.918170] meson-pcie fc000000.pcie: error: wait linkup timeout
[ 89.918957] nvme nvme0: Disabling device after reset failure: -19
[ 91.023683] ------------[ cut here ]------------
[ 91.024010] [CRTC:43:meson_crtc] vblank wait timed out
[ 91.028751] WARNING: CPU: 4 PID: 1530 at drivers/gpu/drm/drm_atomic_helper.c:1682 drm_atomic_
helper_wait_for_vblanks.part.0+0x248/0x278
[ 91.040138] Modules linked in: realtek snd_seq_dummy snd_hrtimer snd_seq snd_seq_device dwmac
_meson8b stmmac_platform stmmac mdio_mux_meson_g12a mdio_mux of_mdio rfcomm algif_hash algif_skc
ipher af_alg bnep mt76x2u mt76x2_common mt76x02_usb mt76_usb rtw88_8822cs binfmt_misc rtw88_8822
c rtw88_sdio mt76x02_lib rtw88_core mt76 hci_uart mac80211 btqca btrtl btintel btbcm bluetooth l
ibarc4 ecdh_generic ecc cfg80211 cdc_acm rfkill snd_soc_tlv320aic31xx reform2_lpc(OE) snd_soc_me
son_axg_sound_card snd_soc_meson_card_utils meson_gxbb_wdt snd_soc_meson_axg_tdmin meson_rng mes
on_saradc snd_soc_meson_axg_frddr snd_soc_meson_g12a_tohdmitx snd_soc_meson_axg_tdmout industria
lio snd_soc_meson_axg_tdm_interface leds_gpio nvmem_meson_efuse snd_soc_meson_axg_tdm_formatter
joydev evdev efi_pstore configfs nfnetlink ip_tables x_tables autofs4 ext4 mbcache jbd2 crc32c_g
eneric dm_crypt hid_generic dm_mod dax mali_dp snd_soc_meson_codec_glue usbhid hid mxsfb mux_mmi
o panel_edp imx_dcss ti_sn65dsi86 drm_dp_aux_bus nwl_dsi mux_core pwm_imx27
[ 91.044321] onboard_usb_dev snd_soc_hdmi_codec dw_hdmi_i2s_audio nvme nvme_core t10_pi xhci_
plat_hcd meson_gxl xhci_hcd smsc crc16 crc64_rocksoft_generic snd_soc_meson_axg_toddr snd_soc_me
son_axg_fifo dwc2 dwc3 meson_vdec(C) crc64_rocksoft snd_soc_core udc_core videobuf2_dma_contig c
rc_t10dif snd_compress videobuf2_memops crct10dif_generic polyval_ce v4l2_mem2mem snd_pcm_dmaeng
ine videobuf2_v4l2 polyval_generic usbcore ghash_ce crct10dif_ce ulpi gf128mul spi_gpio snd_pcm
videodev sha2_ce panfrost axg_audio pcs_xpcs videobuf2_common crc64 phylink dwc3_meson_g12a meso
n_dw_mipi_dsi snd_timer crct10dif_common sha256_arm64 drm_shmem_helper sclk_div spi_bitbang clk_
pwm gpu_sched reset_meson_audio_arb usb_common rtc_pcf8523 sha1_ce snd clk_phase meson_dw_hdmi s
oundcore fixed_phy dw_mipi_dsi meson_drm mc fwnode_mdio libphy rtc_meson_vrtc ao_cec_g12a meson_
canvas gpio_regulator pwm_regulator fixed cpufreq_dt aes_neon_bs aes_neon_blk aes_ce_blk aes_ce_
cipher [last unloaded: of_mdio]
[ 91.216080] CPU: 4 PID: 1530 Comm: systemd-sleep Tainted: G C OE 6.10.9-mnt-refo
rm-arm64 #1 Debian 6.10.9-1+reform20240916T143123Z
[ 91.228977] Hardware name: MNT Pocket Reform with BPI-CM4 Module (DT)
[ 91.235397] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 91.242323] pc : drm_atomic_helper_wait_for_vblanks.part.0+0x248/0x278
[ 91.248822] lr : drm_atomic_helper_wait_for_vblanks.part.0+0x248/0x278
[ 91.255322] sp : ffff800085deb470
[ 91.258615] x29: ffff800085deb4a0 x28: 000000000000080e x27: 0000000000000000
[ 91.265721] x26: 0000000000000001 x25: 0000000000000000 x24: ffff000002f97800
[ 91.272828] x23: 0000000000000001 x22: 0000000000000000 x21: 0000000000000000
[ 91.279934] x20: ffff00003f9b0f80 x19: ffff000003e30080 x18: 0000000000000006
[ 91.287041] x17: 0000000000005048 x16: 000000000000506c x15: ffff800085deae80
[ 91.294148] x14: 0000000000000000 x13: 74756f2064656d69 x12: ffff8000818502b0
[ 91.301255] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff800080250abc
[ 91.308361] x8 : c0000000ffffefff x7 : ffff8000817f80e0 x6 : 0000000000000001
[ 91.315468] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[ 91.322574] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff00001389b780
[ 91.329685] Call trace:
[ 91.332117] drm_atomic_helper_wait_for_vblanks.part.0+0x248/0x278
[ 91.338265] drm_atomic_helper_commit_tail_rpm+0x8c/0xb0
[ 91.343548] commit_tail+0xac/0x1a0
[ 91.347015] drm_atomic_helper_commit+0x184/0x1a8
[ 91.351696] drm_atomic_commit+0xbc/0x100
[ 91.355682] drm_atomic_helper_commit_duplicated_state+0xfc/0x118
[ 91.361748] drm_atomic_helper_resume+0xb4/0x1a8
[ 91.366341] drm_mode_config_helper_resume+0x2c/0xd8
[ 91.371282] meson_drv_pm_resume+0x9c/0xb8 [meson_drm]
[ 91.376396] dpm_run_callback+0x98/0x1f8
[ 91.380296] device_resume+0x90/0x240
[ 91.383935] dpm_resume+0x170/0x240
[ 91.387401] dpm_resume_end+0x20/0x40
[ 91.391041] suspend_devices_and_enter+0x2bc/0x850
[ 91.395808] pm_suspend+0x21c/0x4f8
[ 91.399275] state_store+0x88/0x100
[ 91.402742] kobj_attr_store+0x18/0x30
[ 91.406470] sysfs_kf_write+0x4c/0x68
[ 91.410108] kernfs_fop_write_iter+0x13c/0x1d8
[ 91.414528] vfs_write+0x248/0x3b8
[ 91.417909] ksys_write+0x7c/0x120
[ 91.421288] __arm64_sys_write+0x24/0x38
[ 91.425188] invoke_syscall+0x78/0x108
[ 91.428915] el0_svc_common.constprop.0+0x48/0xf0
[ 91.433595] do_el0_svc+0x24/0x38
[ 91.436888] el0_svc+0x3c/0x128
[ 91.440009] el0t_64_sync_handler+0x120/0x130
[ 91.444341] el0t_64_sync+0x190/0x198
[ 91.447988] ---[ end trace 0000000000000000 ]---
[ 91.716757] xhci-hcd xhci-hcd.2.auto: xHC error in resume, USBSTS 0x411, Reinit
[ 91.779635] usb usb1: root hub lost power or was reset
[ 91.841867] usb usb2: root hub lost power or was reset
[ 92.213361] usb 1-2: reset high-speed USB device number 2 using xhci-hcd
[ 92.717080] usb 1-2.1: reset high-speed USB device number 3 using xhci-hcd
[ 92.908961] usb 1-2.2: reset full-speed USB device number 4 using xhci-hcd
[ 93.194563] usb 1-2.1.3: reset full-speed USB device number 5 using xhci-hcd
[ 93.441161] usb 1-2.1.4: reset high-speed USB device number 6 using xhci-hcd
[ 93.606532] mt76x2u 1-2.1.4:1.0: ROM patch build: 20141115060606a
[ 93.844260] mt76x2u 1-2.1.4:1.0: Firmware Version: 0.0.00
[ 93.905479] mt76x2u 1-2.1.4:1.0: Build: 1
[ 93.965940] mt76x2u 1-2.1.4:1.0: Build Time: 201507311614____
