Sway: changing wallpaper?
Is there some trick to changing the wallpaper in Sway?
I added an exec swaybg -i ~/Pictures/something.png and the PNG file is 1920x1200 but I still get the default image after logging out and back in.
Did you make sure to remove any other existing lines that set the background in ~/.config/sway/config? I don’t use swaybg to set mine but:
output * bg /home/chartreuse/.wallpaper fill
Where the file .wallpaper is a symlink to my desired wallpaper so I can change it without changing the sway config
Oh, the symlink is smart. I’ll try your setup. Thanks
Edit: that did the trick
Hi! Beginner here with the linux command line, trying to repeat your setup as well. I have an image file named x.wallpaper in my home dir. Where do I put:
Or is this a command typed on the prompt?
where do I put the symbolic link that points to the .wallpaper file?
Thanks for the help!
That line is in the sway config file.
The file path in the line is a symlink to the desired wallpaper.
