I’ve just freshened up the Reform’s operating system with a quick sudo apt update && sudo apt full-upgrade
, as I have to admit I haven’t used it in a while, and now the Sway title bar is… gone. Missing in action. Absent without leave. Deserted. Scarpered.
I’ve got the terminal’s menu bar, that’s where it should be, and I can bring up the program list with Super+D and open additional programs which split the screen as expected… but the title bar - system bar, whatever you call the bar at the top with the NET menu and the time and all that stuff in it - is nowhere to be found.
I’m not a Sway user myself, so I’m not sure how to go about figuring out what the problem is and fixing it. Help?
