Switching between HDMI and internal display on A311D
As it is known, noone has yet figured out how to make A311D output to the internal display and HDMI on MNT Reform / MNT Pocket Reform at the same time, and switching from one to the other is not automatic. We might integrate buttons for this in a future wayland desktop panel, but in the meantime here are two commands I use (you could also bind these to keyboard shortcuts in .config/sway/config).
To use these, you need to sudo apt install wlr-randr once.
MNT Pocket Reform with A311D
Switching to HDMI (and a resolution of choice)
wlr-randr --output DSI-1 --off --output HDMI-A-1 --on --custom-mode "1920x1080@60Hz"
Switching back to Internal Display
wlr-randr --output DSI-1 --on --output HDMI-A-1 --off
MNT Reform with A311D
wlr-randr --output eDP-1 --off --output HDMI-A-1 --on --custom-mode "1920x1080@60Hz"
wlr-randr --output eDP-1 --on --output HDMI-A-1 --off
Interesting… on MNT Reform Classic with A311D I used to have:
swaymsg output eDP-1 disable; swaymsg output HDMI-A-1 enable
swaymsg output HDMI-A-1 modeline 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
swaymsg output eDP-1 enable
swaymsg output HDMI-A-1 disable
Especially when switching back, enabling and disabling the display twice used to be necessary. This restriction is gone with wlr-randr? That’s nice! :smiley:
I’ve just tried Kanshi on my A311D Reform and it seems to work wonderfully! I added this to my Kanshi config:
profile "Reform - Home" {
        output "Philips Consumer Electronics Company PHL 246V5 AU01438007831" enable mode 1920x1080 position 0,0
profile "Reform Undocked" {
        output eDP-1 enable
…and my Reform now outputs to my HDMI monitor if it’s plugged in and switches back to the internal display automatically when I unplug it.
Uuuh kanshi is for wayland what autorandr is for xorg. I used to be a autorandr user. This is perfect! If only one display can be used at a time, why would one not automatically switch to hdmi right as it is plugged in? Thank you!
No problem! :slight_smile:
I used to use autorandr too, and the one thing I miss about it when using Kanshi is that you have to manage the config file manually; there’s no equivalent of autorandr --save. But the upside to that is that I have my Kanshi config in my dotfiles so it applies to all my machines as well.
For now I only have it configured to switch if I plug into specific monitors, but if you find a way to have it switch to any connected HDMI device when plugged in I’d be interested in seeing what that config looks like.
Unfortunately, I don’t seem to be having much success with kanshi. It works “sometimes” but after a few unplugs and replugs I start getting messages like:
failed to apply configuration for profile 'Reform Undocked'
So my internal screen stays black. Re-plugging HDMI brings at least that one back but at some point, turning on HDMI will fail as well with:
no profile matched
And then I have literally no output anymore. :frowning:
Hello! Bumping this thread because I wonder if anyone is currently able to switch to HDMI on a311d and back to the internal display on Pocket Reform.
This works for me to switch to an external HDMI display (on Pocket Reform):
swaymsg output DSI-1 disable
swaymsg output HDMI-A-1 modeline 148.50 1920 2448 2492\
                                 2640 1080 1084 1089\
                                 1125 +hsync +vsync
However, none of the following allow me to switch back:
swaymsg output DSI-1 enable
(These turn off the external display, but otherwise fail silently)
(That gets me failed to apply configuration).
I messed with kanshi a little as well, which fails in a couple of different ways, but I figure it’s all the same root cause?
On my Reform 2 the wlr-randr command works fine for switching back.
However, the display of the Pocket has a different resolution iirc.
Random information that probably won’t help. But the 4.9 Amlogic BSP kernel has support for the dual display pipeline. I used it for another A311D device and dsi/HDMI both worked together in mirror mode or separate output. :unamused_face:
Reporting back — I tried this today on a different monitor and it worked fine :woman_shrugging: without even switching back and forth multiple times
And now on a311d, after a system upgrade (mesa 25.0.4-1 to 25.0.5-1, linux 4.11 to 4.11+reform20250503T130928Z1, among other packages) I can no longer switch back to the internal display. Annoying.
I think you typo-ed some of the versions?
In any case, you do have the internal display after a fresh boot, right?
Yes, HDMI on a311d is very annoying. :frowning:
