I have the same behavior, I can boot from the SD card, but when I try to create a new boot on device it will not boot.
reform-check looks like:
I: `uname -a` output: Linux arkilikos 7.1.7-mnt-reform-arm64 #1 SMP PREEMPT Debian 7.1.7-1+reform20260810T183147Z (2026-08-10 aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 7.1.7-1+reform20260810T183147Z
I: Version of reform-tools: 1.88-1+reform20260803T142427Z+1
I: Version of system image: System Image v5: 2026-06-05
I: Version of system controller firmware: 20260808
I: Version of keyboard firmware: 20260808
W: No known path for mnt_pocket_reform_panel_version for MNT Pocket Reform with i.MX8MP Module -- please consider contributing the output of: find /sys -name mnt_pocket_reform_panel_version
W: /sys/bus/spi/drivers/reform2_lpc/spi1.0/firmware does not exist -- is the reform2_lpc module loaded?
I: Version of upstream U-Boot: 2022.04
I: Version of MNT U-Boot: 2026-01-28
I: Mount source of /: /dev/disk/by-label/reformsdroot (n.a.)
I: Mount source of /boot: /dev/mmcblk0p1 (SD-card)
+ console=ttymxc1,115200
- console=ttymxc1
W: reform-setup-wizard failed to clean up /etc/profile.d/reform-setup.sh. It can be safely removed.
I: Install the package shellcheck for checking /boot/boot.scr for problems
I: eMMC contains the latest bootloader version 2026-01-28
One interesting symptom:
If I run:
lnsy@arkilikos:~$ sudo fwupdmgr update
WARNING: UEFI ESP partition not detected or configured
See https://github.com/fwupd/fwupd/wiki/PluginFlag:esp-not-found for more information.
Devices with the latest available firmware version:
• Pocket Reform Input 2.0
• Pocket Reform System Controller 2.0
Devices with no available firmware updates:
• WD BLACK SN750 SE 500GB
lsblk now says:
lnsy@arkilikos:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk2 179:0 0 116.6G 0 disk
├─mmcblk2p1 179:1 0 488M 0 part
└─mmcblk2p2 179:2 0 116.1G 0 part
nvme0n1 259:0 0 465.8G 0 disk
mmcblk2boot0 179:256 0 4M 1 disk
mmcblk0 179:512 0 119.4G 0 disk
├─mmcblk0p1 179:513 0 488M 0 part /boot
└─mmcblk0p2 179:514 0 118.9G 0 part /
mmcblk2boot1 179:768 0 4M 1 disk
lspci says:
lnsy@arkilikos:~$ lspci
00:00.0 PCI bridge: Synopsys, Inc. DWC_usb3 / PCIe bridge (rev 01)
01:00.0 Non-Volatile memory controller: Sandisk Corp PC SN735 / WD_BLACK SN750 SE NVMe SSD (DRAM-less)
and dmesg says:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 7.1.7-mnt-reform-arm64 (debian-kernel@lists.debian.org) (aarch64-linux-gnu-gcc-15 (Debian 15.3.0-2) 15.3.0, GNU ld (GNU Binutils for Debian) 2.47) #1 SMP PREEMPT Debian 7.1.7-1+reform20260810T183147Z (2026-08-10
[ 0.000000] KASLR disabled due to lack of seed
[ 0.000000] Machine model: MNT Pocket Reform with i.MX8MP Module
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: 0x0000000057e00000..0x0000000057ffffff (2048 KiB) nomap non-reusable optee_shm@57e00000
[ 0.000000] OF: reserved mem: 0x0000000056000000..0x0000000057dfffff (30720 KiB) nomap non-reusable optee_core@56000000
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000023fffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x23efc0280-0x23efc3a7f]
[ 0.000000] cma: Reserved 256 MiB at 0x00000000f0000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000055ffffff]
[ 0.000000] node 0: [mem 0x0000000058000000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000023fffffff]
[ 0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[ 0.000000] percpu: Embedded 36 pages/cpu s108056 r8192 d31208 u147456
[ 0.000000] pcpu-alloc: s108056 r8192 d31208 u147456 alloc=36*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GICv3 CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ro no_console_suspend pci=pcie_bus_perf nvme_core.default_ps_max_latency_us=0 console=ttymxc1,115200 console=tty1 fbcon=font:TER16x32 cma=256MB console=tty1
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] printk: log buffer data + meta data: 131072 + 557056 = 688128 bytes
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x00000000ec000000-0x00000000f0000000] (64MB)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2088960
[ 0.000000] Policy zone: Normal
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 55396 entries in 218 pages
[ 0.000000] ftrace: allocated 218 pages with 5 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 160 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: GICv3 features: 16 PPIs
[ 0.000000] GICv3: GICD_CTLR.DS=0, SCR_EL3.FIQ=1
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.000000] arch_timer: cp15 timer running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.001720] Console: colour dummy device 80x25
[ 0.001733] printk: legacy console [tty1] enabled
[ 0.003139] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.003168] pid_max: default: 32768 minimum: 301
[ 0.006306] landlock: Up and running.
[ 0.006320] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.006596] AppArmor: AppArmor initialized
[ 0.006663] TOMOYO Linux initialized
[ 0.007096] LSM support for eBPF active
[ 0.008739] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.008782] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.010140] VFS: Finished mounting rootfs on nullfs
[ 0.016091] rcu: Hierarchical SRCU implementation.
[ 0.016125] rcu: Max phase no-delay instances is 1000.
[ 0.016420] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.019974] EFI services will not be available.
[ 0.020481] smp: Bringing up secondary CPUs ...
[ 0.021243] Detected VIPT I-cache on CPU1
[ 0.021373] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.021417] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.022287] Detected VIPT I-cache on CPU2
[ 0.022397] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.022428] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.023288] Detected VIPT I-cache on CPU3
[ 0.023401] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.023431] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.023549] smp: Brought up 1 node, 4 CPUs
[ 0.023653] SMP: Total of 4 processors activated.
[ 0.023668] CPU: All CPU(s) started at EL2
[ 0.023705] CPU features: detected: 32-bit EL0 Support
[ 0.023722] CPU features: detected: 32-bit EL1 Support
[ 0.023737] CPU features: detected: CRC32 instructions
[ 0.023760] CPU features: detected: PMUv3
[ 0.023815] alternatives: applying system-wide alternatives
[ 0.072180] node 0 deferred pages initialised in 44ms
[ 0.072306] Memory: 7781868K/8355840K available (18816K kernel code, 5154K rwdata, 11428K rodata, 3776K init, 912K bss, 306584K reserved, 262144K cma-reserved)
[ 0.074322] devtmpfs: initialized
[ 0.093687] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.093789] futex hash table entries: 1024 (65536 bytes on 1 NUMA nodes, total 64 KiB, linear).
[ 0.098582] 22688 pages in range for non-PLT usage
[ 0.098601] 514208 pages in range for PLT usage
[ 0.104709] DMI: not present or invalid.
[ 0.107899] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.109445] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.109769] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.109832] audit: initializing netlink subsys (disabled)
[ 0.110018] audit: type=2000 audit(0.104:1): state=initialized audit_enabled=0 res=1
[ 0.113156] thermal_sys: Registered thermal governor 'fair_share'
[ 0.113171] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.113194] thermal_sys: Registered thermal governor 'step_wise'
[ 0.113207] thermal_sys: Registered thermal governor 'user_space'
[ 0.113221] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.113296] cpuidle: using governor ladder
[ 0.113342] cpuidle: using governor menu
[ 0.113771] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.113906] ASID allocator initialised with 65536 entries
[ 0.116149] Serial: AMBA PL011 UART driver
[ 0.125543] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000/unique-id@8
[ 0.125657] /soc@0/etm@28440000: Fixed dependency cycle(s) with /funnel
[ 0.125840] /soc@0/etm@28540000: Fixed dependency cycle(s) with /funnel
[ 0.125919] /soc@0/etm@28640000: Fixed dependency cycle(s) with /funnel
[ 0.125991] /soc@0/etm@28740000: Fixed dependency cycle(s) with /funnel
[ 0.126040] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[ 0.126097] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /funnel
[ 0.126145] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[ 0.126205] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[ 0.126286] /soc@0/etr@28c06000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[ 0.127255] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[ 0.127332] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[ 0.127486] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.127588] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.127921] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[ 0.128040] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[ 0.128278] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.128563] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.128988] /soc@0/interrupt-controller@38800000: Fixed dependency cycle(s) with /soc@0/interrupt-controller@38800000
[ 0.129732] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28440000
[ 0.129876] /soc@0/etm@28440000: Fixed dependency cycle(s) with /funnel
[ 0.130087] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28540000
[ 0.130207] /soc@0/etm@28540000: Fixed dependency cycle(s) with /funnel
[ 0.130405] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28640000
[ 0.130571] /soc@0/etm@28640000: Fixed dependency cycle(s) with /funnel
[ 0.130762] /funnel: Fixed dependency cycle(s) with /soc@0/etm@28740000
[ 0.130886] /soc@0/etm@28740000: Fixed dependency cycle(s) with /funnel
[ 0.131143] /funnel: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[ 0.131235] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[ 0.131294] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /funnel
[ 0.131522] /soc@0/funnel@28c03000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[ 0.131616] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[ 0.131683] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/funnel@28c03000
[ 0.131876] /soc@0/etf@28c04000: Fixed dependency cycle(s) with /soc@0/etr@28c06000
[ 0.131999] /soc@0/etr@28c06000: Fixed dependency cycle(s) with /soc@0/etf@28c04000
[ 0.137195] imx8mp-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.138023] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.139554] /soc@0/bus@30000000/efuse@30350000: Fixed dependency cycle(s) with /soc@0/bus@30000000/clock-controller@30380000
[ 0.140912] /soc@0/bus@30000000/clock-controller@30380000: Fixed dependency cycle(s) with /soc@0/interrupt-controller@38800000
[ 0.155781] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[ 0.155872] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[ 0.155980] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.156124] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.156465] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[ 0.156550] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[ 0.156730] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.156980] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.157857] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[ 0.157934] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[ 0.158140] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.158595] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32e80000
[ 0.158756] /soc@0/bus@32c00000/display-controller@32e80000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 0.162168] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[ 0.162274] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[ 0.162846] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-controller@32fc6000
[ 0.163031] /soc@0/bus@32c00000/display-controller@32fc6000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.163760] /soc@0/bus@32c00000/display-bridge@32fc4000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/hdmi@32fd8000
[ 0.164028] /soc@0/bus@32c00000/hdmi@32fd8000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/display-bridge@32fc4000
[ 0.183621] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.183656] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.183672] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.183689] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[ 0.183703] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.183719] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.183733] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.183746] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[ 0.193991] ACPI: Interpreter disabled.
[ 0.197121] iommu: Default domain type: Translated
[ 0.197157] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.199166] pps_core: LinuxPPS API ver. 1 registered
[ 0.199195] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.199225] PTP clock support registered
[ 0.199299] EDAC MC: Ver: 3.0.0
[ 0.199701] scmi_core: SCMI protocol bus registered
[ 0.202146] NetLabel: Initializing
[ 0.202175] NetLabel: domain hash size = 128
[ 0.202188] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.202270] NetLabel: unlabeled traffic allowed by default
[ 0.202558] vgaarb: loaded
[ 0.203124] clocksource: Switched to clocksource arch_sys_counter
[ 0.205614] VFS: Disk quotas dquot_6.6.0
[ 0.205766] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.206836] AppArmor: AppArmor Filesystem Enabled
[ 0.207078] pnp: PnP ACPI: disabled
[ 0.217485] NET: Registered PF_INET protocol family
[ 0.217819] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.224987] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.225122] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.225220] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.225898] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.227889] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.228380] MPTCP token hash table entries: 8192 (order: 6, 196608 bytes, linear)
[ 0.228812] UDP hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.229370] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.229441] NET: Registered PF_XDP protocol family
[ 0.229469] PCI: CLS 0 bytes, default 64
[ 0.229912] Trying to unpack rootfs image as initramfs...
[ 0.248000] kvm [1]: nv: 570 coarse grained trap handlers
[ 0.248351] kvm [1]: nv: 710 fine grained trap handlers
[ 0.248874] kvm [1]: IPA Size Limit: 40 bits
[ 0.252028] kvm [1]: GICv3: no GICV resource entry
[ 0.252064] kvm [1]: disabling GICv2 emulation
[ 0.252090] kvm [1]: GICv3 sysreg trapping enabled ([C], reduced performance)
[ 0.252126] kvm [1]: GIC system register CPU interface enabled
[ 0.252219] kvm [1]: vgic interrupt IRQ9
[ 0.252256] kvm [1]: Hyp nVHE mode initialized successfully
[ 0.261387] Initialise system trusted keyrings
[ 0.261488] Key type blacklist registered
[ 0.263450] workingset: timestamp_bits=42 (anon: 38) max_order=21 bucket_order=0 (anon: 0)
[ 0.269603] fuse: init (API version 7.45)
[ 0.270728] integrity: Platform Keyring initialized
[ 0.270789] integrity: Machine keyring initialized
[ 0.270903] Key type asymmetric registered
[ 0.270919] Asymmetric key parser 'x509' registered
[ 0.271294] alg: self-tests disabled
[ 0.271648] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.271862] io scheduler mq-deadline registered
[ 0.291453] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.312670] SoC: i.MX8MP revision 1.1
[ 0.349861] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.354182] Serial: AMBA driver
[ 0.355985] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 15, base_baud = 5000000) is a IMX
[ 0.356487] serial serial0: tty port ttymxc0 registered
[ 0.357318] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 16, base_baud = 5000000) is a IMX
[ 0.358586] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 17, base_baud = 1500000) is a IMX
[ 0.358820] printk: console [ttymxc1] enabled
[ 0.366392] 30a60000.serial: ttymxc3 at MMIO 0x30a60000 (irq = 18, base_baud = 5000000) is a IMX
[ 0.368276] msm_serial: driver initialized
[ 0.369459] SuperH (H)SCI(F) driver initialized
[ 0.394534] mousedev: PS/2 mouse device common for all mice
[ 0.413624] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.429737] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[ 0.436469] NET: Registered PF_INET6 protocol family
[ 0.438573] Segment Routing with IPv6
[ 0.438615] RPL Segment Routing with IPv6
[ 0.438671] In-situ OAM (IOAM) with IPv6
[ 0.438740] mip6: Mobile IPv6
[ 0.438764] NET: Registered PF_PACKET protocol family
[ 0.439035] mpls_gso: MPLS GSO support
[ 0.455495] registered taskstats version 1
[ 0.455805] Loading compiled-in X.509 certificates
[ 1.214899] Freeing initrd memory: 39168K
[ 1.255750] Loaded X.509 cert 'Build time autogenerated kernel key: 716a4694ca92d3bc289b9085cb014cd669bb7811'
[ 1.279469] Demotion targets for Node 0: null
[ 1.280287] Key type .fscrypt registered
[ 1.280311] Key type fscrypt-provisioning registered
[ 1.347225] Key type encrypted registered
[ 1.347264] AppArmor: AppArmor sha256 policy hashing enabled
[ 1.347285] ima: No TPM chip found, activating TPM-bypass!
[ 1.347302] ima: Allocated hash algorithm: sha256
[ 1.347462] ima: No architecture policies found
[ 1.347618] evm: Initialising EVM extended attributes:
[ 1.347632] evm: security.selinux
[ 1.347644] evm: security.SMACK64 (disabled)
[ 1.347656] evm: security.SMACK64EXEC (disabled)
[ 1.347670] evm: security.SMACK64TRANSMUTE (disabled)
[ 1.347682] evm: security.SMACK64MMAP (disabled)
[ 1.347693] evm: security.apparmor
[ 1.347709] evm: security.ima
[ 1.347720] evm: security.capability
[ 1.347735] evm: HMAC attrs: 0x1
[ 1.368431] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.370907] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.373390] gpio gpiochip2: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.375968] gpio gpiochip3: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.378281] gpio gpiochip4: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 1.408172] clk: Disabling unused clocks
[ 1.413068] PM: genpd: Disabling unused power domains
[ 1.424246] Freeing unused kernel memory: 3776K
[ 1.589251] Checked W+X mappings: passed, no W+X pages found
[ 1.589307] Run /init as init process
[ 1.589322] with arguments:
[ 1.589329] /init
[ 1.589337] with environment:
[ 1.589346] HOME=/
[ 1.589353] TERM=linux
[ 3.523797] cs_system_cfg: CoreSight Configuration manager initialised
[ 3.527211] /soc@0: Fixed dependency cycle(s) with /soc@0/bus@30000000/efuse@30350000
[ 3.528751] imx8mq-usb-phy 381f0040.usb-phy: supply vbus not found, using dummy regulator
[ 3.529326] imx8mq-usb-phy 382f0040.usb-phy: supply vbus not found, using dummy regulator
[ 3.532969] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 5 mkt segment 0 supported-hw 0x20 0x1
[ 3.743968] i2c i2c-0: using pinctrl states for GPIO recovery
[ 3.744077] i2c i2c-0: using generic GPIOs for recovery
[ 3.744684] i2c i2c-0: IMX I2C adapter registered
[ 3.745191] i2c i2c-1: using pinctrl states for GPIO recovery
[ 3.745258] i2c i2c-1: using generic GPIOs for recovery
[ 3.745443] i2c i2c-1: IMX I2C adapter registered
[ 3.745857] i2c i2c-2: using pinctrl states for GPIO recovery
[ 3.745915] i2c i2c-2: using generic GPIOs for recovery
[ 3.746798] i2c i2c-2: IMX I2C adapter registered
[ 3.769670] imx6q-pcie 33800000.pcie: host bridge /soc@0/pcie@33800000 ranges:
[ 3.769740] imx6q-pcie 33800000.pcie: IO 0x001ff80000..0x001ff8ffff -> 0x0000000000
[ 3.769778] imx6q-pcie 33800000.pcie: MEM 0x0018000000..0x001fefffff -> 0x0018000000
[ 3.769877] imx6q-pcie 33800000.pcie: config reg[1] 0x1ff00000 == cpu 0x1ff00000
; no fixup was ever needed for this devicetree
[ 3.890041] imx-sdma 30bd0000.dma-controller: loaded firmware 4.6
[ 3.907356] imx-sdma 30e00000.dma-controller: loaded firmware 4.6
[ 3.916673] imx-sdma 30e10000.dma-controller: loaded firmware 4.6
[ 3.983352] imx6q-pcie 33800000.pcie: iATU: unroll T, 4 ob, 4 ib, align 64K, limit 16G
[ 4.183192] imx6q-pcie 33800000.pcie: PCIe Gen.3 x1 link up
[ 4.183693] imx6q-pcie 33800000.pcie: PCI host bridge to bus 0000:00
[ 4.183754] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.183779] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 4.183800] pci_bus 0000:00: root bus resource [mem 0x18000000-0x1fefffff]
[ 4.183853] pci 0000:00:00.0: [16c3:abcd] type 01 class 0x060400 PCIe Root Port
[ 4.183887] pci 0000:00:00.0: BAR 0 [mem 0x00000000-0x000fffff]
[ 4.183908] pci 0000:00:00.0: ROM [mem 0x00000000-0x0000ffff pref]
[ 4.183929] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.183950] pci 0000:00:00.0: bridge window [io 0x0000-0x0fff]
[ 4.183970] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff]
[ 4.183992] pci 0000:00:00.0: bridge window [mem 0x00000000-0x000fffff pref]
[ 4.184052] pci 0000:00:00.0: supports D1
[ 4.184071] pci 0000:00:00.0: PME# supported from D0 D1 D3hot D3cold
[ 4.187197] pci 0000:01:00.0: [15b7:501e] type 00 class 0x010802 PCIe Endpoint
[ 4.187345] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00003fff 64bit]
[ 4.187871] pci 0000:01:00.0: 7.876 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x1 link at 0000:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[ 4.188277] pci 0000:00:00.0: BAR 0 [mem 0x18000000-0x180fffff]: assigned
[ 4.188312] pci 0000:00:00.0: bridge window [mem 0x18100000-0x181fffff]: assigned
[ 4.188333] pci 0000:00:00.0: ROM [mem 0x18200000-0x1820ffff pref]: assigned
[ 4.188358] pci 0000:01:00.0: BAR 0 [mem 0x18100000-0x18103fff 64bit]: assigned
[ 4.188400] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.188419] pci 0000:00:00.0: bridge window [mem 0x18100000-0x181fffff]
[ 4.188440] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 4.188456] pci_bus 0000:00: resource 5 [mem 0x18000000-0x1fefffff]
[ 4.188473] pci_bus 0000:01: resource 1 [mem 0x18100000-0x181fffff]
[ 4.188498] pci 0000:00:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 4.188547] pci 0000:01:00.0: Max Payload Size set to 128/ 256 (was 128), Max Read Rq 128
[ 4.191714] pcieport 0000:00:00.0: PME: Signaling with IRQ 203
[ 4.199307] pcieport 0000:00:00.0: AER: enabled with IRQ 203
[ 4.231656] nxp-pca9450 0-0025: PWRON interrupt.
[ 4.244113] nxp-pca9450 0-0025: pca9450bc probed.
[ 4.414942] usbcore: registered new interface driver usbfs
[ 4.415039] usbcore: registered new interface driver hub
[ 4.415429] rtc-pcf8523 2-0068: registered as rtc0
[ 4.419201] rtc-pcf8523 2-0068: hctosys: unable to read the hardware clock
[ 4.441545] sdhci-esdhc-imx 30b40000.mmc: Got CD GPIO
[ 4.442819] sdhci-esdhc-imx 30b40000.mmc: drop HS400 support since no 8-bit bus
[ 4.446316] samsung-dsim 32e60000.dsi: supply vddcore not found, using dummy regulator
[ 4.447271] sdhci-esdhc-imx 30b50000.mmc: drop HS400 support since no 8-bit bus
[ 4.448871] usbcore: registered new device driver usb
[ 4.450712] samsung-dsim 32e60000.dsi: supply vddio not found, using dummy regulator
[ 4.459534] /soc@0/bus@32c00000/dsi@32e60000: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000/panel@0
[ 4.459666] /soc@0/bus@32c00000/dsi@32e60000/panel@0: Fixed dependency cycle(s) with /soc@0/bus@32c00000/dsi@32e60000
[ 4.475361] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 4.479553] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 4.524423] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 4.525296] mmcblk2: mmc2:0001 X29128 117 GiB
[ 4.526994] mmc0: host does not support reading read-only switch, assuming write-enable
[ 4.528055] mmcblk2: p1 p2
[ 4.528781] mmcblk2boot0: mmc2:0001 X29128 4.00 MiB
[ 4.529056] mmc0: new high speed SDXC card at address 59b4
[ 4.529999] mmcblk0: mmc0:59b4 GD2S5 119 GiB
[ 4.532059] mmcblk2boot1: mmc2:0001 X29128 4.00 MiB
[ 4.532821] mmcblk0: p1 p2
[ 4.540350] mmcblk2rpmb: mmc2:0001 X29128 4.00 MiB, chardev (238:0)
[ 4.551182] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 4.602360] Key type psk registered
[ 4.609975] imx-dwmac 30bf0000.ethernet: IRQ sfty not found
[ 4.610470] imx-dwmac 30bf0000.ethernet: User ID: 0x10, Synopsys ID: 0x51
[ 4.610518] imx-dwmac 30bf0000.ethernet: DWMAC4/5
[ 4.610532] imx-dwmac 30bf0000.ethernet: DMA HW capability register supported
[ 4.610544] imx-dwmac 30bf0000.ethernet: Active PHY interface: RGMII (1)
[ 4.610556] imx-dwmac 30bf0000.ethernet: RX Checksum Offload Engine supported
[ 4.610566] imx-dwmac 30bf0000.ethernet: TX Checksum insertion supported
[ 4.610577] imx-dwmac 30bf0000.ethernet: Wake-Up On Lan supported
[ 4.610686] imx-dwmac 30bf0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.610709] imx-dwmac 30bf0000.ethernet: device MAC address 5e:01:61:47:3c:e8
[ 4.610723] imx-dwmac 30bf0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[ 4.610736] imx-dwmac 30bf0000.ethernet: Enabled RFS Flow TC (entries=10)
[ 4.610752] imx-dwmac 30bf0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[ 4.610766] imx-dwmac 30bf0000.ethernet: Using 34/40 bits DMA host/device width
[ 4.610987] mmc1: queuing unknown CIS tuple 0x01 [d9 01 ff] (3 bytes)
[ 4.611358] mdio_bus stmmac-1: ethernet-phy has invalid PHY address
[ 4.611384] mdio_bus stmmac-1: scan phy ethernet-phy at address 0
[ 4.616871] mdio_bus stmmac-1: scan phy ethernet-phy at address 1
[ 4.617757] mdio_bus stmmac-1: scan phy ethernet-phy at address 2
[ 4.619179] mdio_bus stmmac-1: scan phy ethernet-phy at address 3
[ 4.619319] mmc1: queuing unknown CIS tuple 0x1a [01 01 00 02 07] (5 bytes)
[ 4.619721] mdio_bus stmmac-1: scan phy ethernet-phy at address 4
[ 4.620079] mdio_bus stmmac-1: scan phy ethernet-phy at address 5
[ 4.620908] mdio_bus stmmac-1: scan phy ethernet-phy at address 6
[ 4.623501] mdio_bus stmmac-1: scan phy ethernet-phy at address 7
[ 4.632014] mmc1: queuing unknown CIS tuple 0x1b [c1 41 30 30 ff ff 32 00] (8 bytes)
[ 4.635694] mmc1: queuing unknown CIS tuple 0x14 [] (0 bytes)
[ 4.645668] mmc1: new UHS-I speed DDR50 SDIO card at address 0001
[ 4.663554] imx8mp-dw-hdmi-tx 32fd8000.hdmi: Detected HDMI TX controller v2.13a with HDCP (SAMSUNG HDMI TX PHY)
[ 4.664092] imx8mp-dw-hdmi-tx 32fd8000.hdmi: registered DesignWare HDMI I2C bus driver
[ 4.739173] random: crng init done
[ 4.802942] Registered IR keymap rc-cec
[ 4.803160] rc rc0: dw_hdmi as /devices/platform/soc@0/32c00000.bus/32fd8000.hdmi/rc/rc0
[ 4.803330] input: dw_hdmi as /devices/platform/soc@0/32c00000.bus/32fd8000.hdmi/rc/rc0/input0
[ 4.839444] nvme nvme0: pci function 0000:01:00.0
[ 4.839517] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.858678] imx-dwmac 30bf0000.ethernet end1: renamed from eth0
[ 5.026586] hwmon hwmon2: temp1_input not attached to any thermal zone
[ 5.026635] hwmon hwmon2: temp2_input not attached to any thermal zone
[ 5.026677] hwmon hwmon2: temp3_input not attached to any thermal zone
[ 5.026691] nvme nvme0: passthrough uses implicit buffer lengths
[ 5.065054] nvme nvme0: allocated 64 MiB host memory buffer (16 segments).
[ 5.125938] nvme nvme0: 4/0/0 default/read/poll queues
[ 5.148294] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.148355] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 5.148774] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x000080a001000010
[ 5.148857] xhci-hcd xhci-hcd.0.auto: irq 211, io mem 0x38200000
[ 5.149010] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.149032] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.149059] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 5.149347] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[ 5.149370] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.149382] usb usb1: Product: xHCI Host Controller
[ 5.149392] usb usb1: Manufacturer: Linux 7.1.7-mnt-reform-arm64 xhci-hcd
[ 5.149403] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 5.150111] hub 1-0:1.0: USB hub found
[ 5.150214] hub 1-0:1.0: 1 port detected
[ 5.150758] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.150941] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[ 5.150971] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.150984] usb usb2: Product: xHCI Host Controller
[ 5.150994] usb usb2: Manufacturer: Linux 7.1.7-mnt-reform-arm64 xhci-hcd
[ 5.151005] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 5.153538] hub 2-0:1.0: USB hub found
[ 5.153628] hub 2-0:1.0: 1 port detected
[ 5.155919] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.155965] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 5.156332] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x000080a001000010
[ 5.156387] xhci-hcd xhci-hcd.1.auto: irq 212, io mem 0x38100000
[ 5.156533] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 5.156552] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 5.156572] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 5.156825] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 7.01
[ 5.156845] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.156857] usb usb3: Product: xHCI Host Controller
[ 5.156866] usb usb3: Manufacturer: Linux 7.1.7-mnt-reform-arm64 xhci-hcd
[ 5.156876] usb usb3: SerialNumber: xhci-hcd.1.auto
[ 5.157498] hub 3-0:1.0: USB hub found
[ 5.157600] hub 3-0:1.0: 1 port detected
[ 5.158256] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 5.158416] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 7.01
[ 5.158436] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.158452] usb usb4: Product: xHCI Host Controller
[ 5.158461] usb usb4: Manufacturer: Linux 7.1.7-mnt-reform-arm64 xhci-hcd
[ 5.158477] usb usb4: SerialNumber: xhci-hcd.1.auto
[ 5.159619] hub 4-0:1.0: USB hub found
[ 5.159687] hub 4-0:1.0: 1 port detected
[ 5.419154] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 5.419302] usb 1-1: new full-speed USB device number 2 using xhci-hcd
[ 5.555467] usb 3-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 5.555519] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 5.555546] usb 3-1: SerialNumber: 3C010061A4CD
[ 5.557183] usb 1-1: New USB device found, idVendor=1209, idProduct=6d07, bcdDevice= 0.01
[ 5.557222] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.557233] usb 1-1: Product: Pocket Reform System Controller 2.0
[ 5.557242] usb 1-1: Manufacturer: MNT
[ 5.557257] usb 1-1: SerialNumber: DE63544193237A34
[ 5.598645] hid: raw HID events driver (C) Jiri Kosina
[ 5.604962] hub 3-1:1.0: USB hub found
[ 5.605133] hub 3-1:1.0: 4 ports detected
[ 5.624130] usbcore: registered new interface driver usbhid
[ 5.624168] usbhid: USB HID core driver
[ 5.678804] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 5.694811] usb 4-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 5.694858] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.710975] usbcore: registered new device driver onboard-usb-dev
[ 5.717919] hub 4-1:1.0: USB hub found
[ 5.721959] hub 4-1:1.0: 4 ports detected
[ 5.826774] mc: Linux media interface: v0.10
[ 5.893616] videodev: Linux video capture interface: v2.00
[ 5.955202] usb 3-1.1: new high-speed USB device number 3 using xhci-hcd
[ 5.973074] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.058201] usb 3-1.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.56
[ 6.058247] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.058259] usb 3-1.1: Product: USB2.1 Hub
[ 6.058268] usb 3-1.1: Manufacturer: GenesysLogic
[ 6.117086] hub 3-1.1:1.0: USB hub found
[ 6.117474] hub 3-1.1:1.0: 4 ports detected
[ 6.127561] usb 4-1.1: new SuperSpeed USB device number 3 using xhci-hcd
[ 6.161870] usb 4-1.1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.56
[ 6.161910] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.161923] usb 4-1.1: Product: USB3.1 Hub
[ 6.161931] usb 4-1.1: Manufacturer: GenesysLogic
[ 6.181479] hub 4-1.1:1.0: USB hub found
[ 6.181830] hub 4-1.1:1.0: 4 ports detected
[ 6.239147] usb 3-1.3: new full-speed USB device number 4 using xhci-hcd
[ 6.436656] usb 3-1.3: New USB device found, idVendor=1209, idProduct=6d06, bcdDevice= 0.01
[ 6.436696] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.436708] usb 3-1.3: Product: Pocket Reform Input 2.0
[ 6.436719] usb 3-1.3: Manufacturer: MNT
[ 6.436728] usb 3-1.3: SerialNumber: DE625492030D5A2B
[ 6.455165] usb 3-1.1.3: new high-speed USB device number 5 using xhci-hcd
[ 6.610487] SPI driver mnt_sc has no spi_device_id for mntre,system-controller
[ 6.610619] mnt_sc spi1.0: MNT System Controller v4
[ 6.611847] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] start...
[ 6.611893] panel-mnt-pocket-reform 32e60000.dsi.0: DSI burst mode enabled via device tree
[ 6.612012] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 1)
[ 6.615745] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 8 0)
[ 6.617935] input: MNT Pocket Reform Input 2.0 Keyboard as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input1
[ 6.619545] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] jdi_panel_add done.
[ 6.619610] samsung-dsim 32e60000.dsi: [drm:samsung_dsim_host_attach [samsung_dsim]] Attached lt070me05000 device (lanes:4 bpp:24 mode-flags:0x13)
[ 6.619924] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_probe] done.
[ 6.755786] input: MNT Pocket Reform Input 2.0 Mouse as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input2
[ 6.756314] input: MNT Pocket Reform Input 2.0 as /devices/platform/soc@0/32f10100.usb/38100000.usb/xhci-hcd.1.auto/usb3/3-1/3-1.3/3-1.3:1.0/0003:1209:6D06.0001/input/input3
[ 6.756629] hid-generic 0003:1209:6D06.0001: input,hidraw0: USB HID v1.11 Keyboard [MNT Pocket Reform Input 2.0] on usb-xhci-hcd.1.auto-1.3/input0
[ 6.831182] reform2_lpc: loading out-of-tree module taints kernel.
[ 6.831227] reform2_lpc: module verification failed: signature and/or required key missing - tainting kernel
[ 6.843160] usb 3-1.1.3: New USB device found, idVendor=0b95, idProduct=1790, bcdDevice= 2.00
[ 6.843178] usb 3-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.843191] usb 3-1.1.3: Product: AX88179A
[ 6.843201] usb 3-1.1.3: Manufacturer: ASIX
[ 6.843210] usb 3-1.1.3: SerialNumber: 00000000002F61
[ 7.008350] usbcore: registered new interface driver cdc_ether
[ 7.220993] cdc_ncm 3-1.1.3:2.0: MAC-Address: 6c:6e:07:13:a4:37
[ 7.221041] cdc_ncm 3-1.1.3:2.0: setting rx_max = 16384
[ 7.234296] cdc_ncm 3-1.1.3:2.0: setting tx_max = 16384
[ 7.245222] cdc_ncm 3-1.1.3:2.0 eth0: register 'cdc_ncm' at usb-xhci-hcd.1.auto-1.1.3, CDC NCM (NO ZLP), 6c:6e:07:13:a4:37
[ 7.245451] usbcore: registered new interface driver cdc_ncm
[ 7.275668] cdc_ncm 3-1.1.3:2.0 enx6c6e0713a437: renamed from eth0
[ 8.866934] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 8.867208] EXT4-fs (mmcblk0p2): mounted filesystem b3c9a26e-a7a1-553c-b470-a3d1af3c31aa ro with ordered data mode. Quota mode: none.
[ 9.147758] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 9.695882] systemd[1]: System time advanced to built-in epoch: Thu 2026-07-23 11:31:52 PDT
[ 9.963679] systemd[1]: Inserted module 'autofs4'
[ 10.485049] systemd[1]: systemd 261.2-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +LIBARCHIVE)
[ 10.485170] systemd[1]: Detected architecture arm64.
[ 10.523624] systemd[1]: Hostname set to <arkilikos>.
[ 10.849772] systemd[1]: bpf-restrict-fs: Failed to load BPF object: No such process
[ 13.005574] systemd[1]: Queued start job for default target graphical.target.
[ 13.028774] systemd[1]: Created slice system-cups.slice - CUPS Slice.
[ 13.030859] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 13.032870] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 13.034791] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[ 13.036899] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 13.038175] systemd[1]: Created slice user.slice - User and Session Slice.
[ 13.038658] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 13.038985] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 13.039847] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 13.040196] systemd[1]: Expecting device dev-disk-by\x2dlabel-reformsdboot.device - /dev/disk/by-label/reformsdboot...
[ 13.040355] systemd[1]: Expecting device dev-ttymxc1.device - /dev/ttymxc1...
[ 13.040527] systemd[1]: Reached target imports.target - Image Downloads.
[ 13.040722] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[ 13.040956] systemd[1]: Reached target slices.target - Slice Units.
[ 13.041132] systemd[1]: Reached target swap.target - Swaps.
[ 13.041617] systemd[1]: Listening on dm-event.socket - Device-mapper event daemon FIFOs.
[ 13.042080] systemd[1]: Listening on lvm2-lvmpolld.socket - LVM2 poll daemon socket.
[ 13.064151] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[ 13.076101] systemd[1]: Listening on systemd-ask-password.socket - Query the User Interactively for a Password.
[ 13.080022] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[ 13.085168] systemd[1]: Listening on systemd-factory-reset.socket - Factory Reset Management.
[ 13.085809] systemd[1]: Listening on systemd-hostnamed.socket - Hostname Service Socket.
[ 13.086414] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 13.087059] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[ 13.093151] systemd[1]: Listening on systemd-mute-console.socket - Console Output Muting Service Socket.
[ 13.093642] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-os
[ 13.093727] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
[ 13.094132] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 13.094595] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 13.095101] systemd[1]: Listening on systemd-udevd-varlink.socket - udev Varlink Socket.
[ 13.099939] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[ 13.103062] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 13.106380] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 13.109572] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 13.111376] systemd[1]: tmp.mount: x-systemd.graceful-option=usrquota specified, but option is not available, suppressing.
[ 13.115376] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[ 13.119579] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS skipped, unmet condition check ConditionPathExists=/etc/krb5.keytab
[ 13.124057] systemd[1]: Starting blk-availability.service - Availability of block devices...
[ 13.152061] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 13.162741] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 13.171506] systemd[1]: Starting lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 13.172161] systemd[1]: modprobe@configfs.service - Load Kernel Module configfs skipped, unmet condition check ConditionKernelModuleLoaded=!configfs
[ 13.175924] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 13.179541] systemd[1]: modprobe@drm.service - Load Kernel Module drm skipped, unmet condition check ConditionKernelModuleLoaded=!drm
[ 13.191508] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 13.194612] systemd[1]: modprobe@fuse.service - Load Kernel Module fuse skipped, unmet condition check ConditionKernelModuleLoaded=!fuse
[ 13.201463] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 13.207005] systemd[1]: Starting modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics...
[ 13.208583] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
[ 13.208804] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
[ 13.333610] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 13.404777] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 13.405300] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-os
[ 13.405454] systemd[1]: systemd-pcrosseparator.service - TPM PCR OS Separator skipped, unmet condition check ConditionSecurity=measured-os
[ 13.410946] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[ 13.411500] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-os
[ 13.411613] systemd[1]: systemd-pcrnvdone.service - TPM PCR NvPCR Initialization Separator skipped, unmet condition check ConditionPathExists=/etc/initrd-release
[ 13.411692] systemd[1]: systemd-pcrproduct.service - TPM NvPCR Product ID Measurement skipped, unmet condition check ConditionSecurity=measured-os
[ 13.434398] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[ 13.603160] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 13.626794] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[ 13.632173] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 13.633603] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 13.634880] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 13.640325] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
[ 13.642393] systemd[1]: Finished blk-availability.service - Availability of block devices.
[ 13.661673] systemd-journald[401]: Collecting audit messages is disabled.
[ 13.685701] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[ 13.686225] device-mapper: uevent: version 1.0.3
[ 13.686831] device-mapper: ioctl: 4.50.0-ioctl (2025-04-28) initialised: dm-devel@lists.linux.dev
[ 13.697990] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[ 13.700304] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 13.701637] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 13.703445] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 13.704426] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 13.706581] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 13.710736] systemd[1]: modprobe@nvme_fabrics.service: Deactivated successfully.
[ 13.713313] systemd[1]: Finished modprobe@nvme_fabrics.service - Load Kernel Module nvme_fabrics.
[ 13.724160] EXT4-fs (mmcblk0p2): re-mounted b3c9a26e-a7a1-553c-b470-a3d1af3c31aa r/w.
[ 13.729140] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[ 13.744620] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[ 13.753394] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[ 13.763919] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
[ 13.764196] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/fs/pstore
[ 13.807918] i2c_dev: i2c /dev entries driver
[ 13.815431] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[ 13.815855] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-os
[ 13.831696] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[ 13.855540] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[ 13.902961] systemd[1]: Finished lvm2-monitor.service - Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 13.935739] systemd[1]: Started systemd-journald.service - Journal Service.
[ 14.032473] systemd-journald[401]: Received client request to flush runtime journal.
[ 14.049740] systemd-journald[401]: File /var/log/journal/62e2b57d24a8445eb93203f20fa84def/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 16.064011] usbcore: registered new interface driver cdc_wdm
[ 16.092955] usbcore: registered new interface driver cdc_mbim
[ 16.590996] CSCFG registered etm0
[ 16.591219] coresight etm0: CPU0: etm v4.0 initialized
[ 16.592693] EXT4-fs (mmcblk0p1): mounted filesystem 034c4a92-ebda-5acf-8460-7f90a7f6e353 r/w with ordered data mode. Quota mode: none.
[ 16.644326] optee: probing for conduit method.
[ 16.644411] optee: revision 3.17 (0000000098499642)
[ 16.650093] optee: dynamic shared memory is enabled
[ 16.650589] optee: initialized driver
[ 16.747051] CSCFG registered etm1
[ 16.747086] coresight etm1: CPU1: etm v4.0 initialized
[ 16.763478] CSCFG registered etm2
[ 16.763512] coresight etm2: CPU2: etm v4.0 initialized
[ 16.772109] caam 30900000.crypto: device ID = 0x0a16040100000100 (Era 9)
[ 16.772147] caam 30900000.crypto: job rings = 1, qi = 0
[ 16.779325] CSCFG registered etm3
[ 16.779353] coresight etm3: CPU3: etm v4.0 initialized
[ 17.032234] mnt_sc spi1.0: mntsc: couldn't parse response: err maxp
[ 17.173857] audit: type=1400 audit(1784831519.504:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=502 comm="apparmor_parser"
[ 17.173936] audit: type=1400 audit(1784831519.504:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=501 comm="apparmor_parser"
[ 17.173974] audit: type=1400 audit(1784831519.504:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=500 comm="apparmor_parser"
[ 17.173994] audit: type=1400 audit(1784831519.504:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=503 comm="apparmor_parser"
[ 17.215003] audit: type=1400 audit(1784831519.548:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="balena-etcher" pid=510 comm="apparmor_parser"
[ 17.217737] audit: type=1400 audit(1784831519.552:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=512 comm="apparmor_parser"
[ 17.237665] audit: type=1400 audit(1784831519.572:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=513 comm="apparmor_parser"
[ 17.276237] audit: type=1400 audit(1784831519.612:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=511 comm="apparmor_parser"
[ 17.302615] audit: type=1400 audit(1784831519.636:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=516 comm="apparmor_parser"
[ 17.306787] audit: type=1400 audit(1784831519.640:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=514 comm="apparmor_parser"
[ 17.346254] dw100 32e30000.dwe: dw100 v4l2 m2m registered as /dev/video0
[ 17.365318] [drm] Initialized imx-lcdif 1.0.0 for 32e80000.display-controller on minor 0
[ 17.365474] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 0
[ 17.431524] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_prepare] prepared: 0
[ 17.431578] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_power_on] panel version: 0
[ 17.559177] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_enable] enabled: 0 prepared: 1
[ 17.559215] panel-mnt-pocket-reform 32e60000.dsi.0: [display] init in enable...
[ 17.559234] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_init] enabled: 0 prepared: 1
[ 17.559278] samsung-dsim 32e60000.dsi: response too long (1 > 15 bytes), stripping
[ 17.566902] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_detect_version] read register 12a: 0x0
[ 17.566927] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_detect_version] detected panel_version: 2
[ 17.566931] panel-mnt-pocket-reform 32e60000.dsi.0: [mnt_panel_power_on] panel version: 2
[ 17.567690] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 0)
[ 17.659336] RPC: Registered named UNIX socket transport module.
[ 17.659368] RPC: Registered udp transport module.
[ 17.659376] RPC: Registered tcp transport module.
[ 17.659379] RPC: Registered tcp-with-tls transport module.
[ 17.659382] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.686963] Bluetooth: Core ver 2.22
[ 17.688569] NET: Registered PF_BLUETOOTH protocol family
[ 17.688591] Bluetooth: HCI device and connection manager initialized
[ 17.688611] Bluetooth: HCI socket layer initialized
[ 17.688618] Bluetooth: L2CAP socket layer initialized
[ 17.688658] Bluetooth: SCO socket layer initialized
[ 17.732497] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 0 1)
[ 17.789231] clk: failed to reparent clk_ext2 to audio_pll2_out: -22
[ 18.071191] Bluetooth: HCI UART driver ver 2.3
[ 18.071249] Bluetooth: HCI UART protocol H4 registered
[ 18.071377] Bluetooth: HCI UART protocol LL registered
[ 18.071383] Bluetooth: HCI UART protocol ATH3K registered
[ 18.071414] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.071854] Bluetooth: HCI UART protocol Intel registered
[ 18.072567] Bluetooth: HCI UART protocol Broadcom registered
[ 18.072691] Bluetooth: HCI UART protocol QCA registered
[ 18.072699] Bluetooth: HCI UART protocol AG6XX registered
[ 18.072730] Bluetooth: HCI UART protocol Marvell registered
[ 18.235962] etnaviv etnaviv: bound 38000000.gpu (ops gpu_ops [etnaviv])
[ 18.275240] Bluetooth: hci0: setting up ROME/QCA6390
[ 18.288930] etnaviv etnaviv: bound 38008000.gpu (ops gpu_ops [etnaviv])
[ 18.319175] etnaviv etnaviv: bound 38500000.npu (ops gpu_ops [etnaviv])
[ 18.320206] etnaviv-gpu 38000000.gpu: model: GC7000, revision: 6204
[ 18.321424] etnaviv-gpu 38008000.gpu: model: GC520, revision: 5341
[ 18.321611] etnaviv-gpu 38500000.npu: model: GC8000, revision: 8002
[ 18.321619] etnaviv-gpu 38500000.npu: etnaviv has been instantiated on a NPU, for which the UAPI is still experimental
[ 18.333422] [drm] Initialized etnaviv 1.4.0 for etnaviv on minor 1
[ 18.452337] hantro-vpu 38300000.video-codec: registered nxp,imx8mm-vpu-g1-dec as /dev/video1
[ 18.486497] Bluetooth: Received HCI_IBS_WAKE_ACK in tx state 0
[ 18.504579] OF: /sound-wwan: Read of boolean property 'simple-audio-card,bitclock-inversion' with a value.
[ 18.518345] hantro-vpu 38310000.video-codec: registered nxp,imx8mq-vpu-g2-dec as /dev/video2
[ 18.759010] Bluetooth: hci0: QCA Product ID :0x00000008
[ 18.759046] Bluetooth: hci0: QCA SOC Version :0x00000023
[ 18.759064] Bluetooth: hci0: QCA ROM Version :0x00000302
[ 18.759069] Bluetooth: hci0: QCA Patch Version:0x00000111
[ 18.759077] Bluetooth: hci0: QCA controller version 0x00230302
[ 18.759084] Bluetooth: hci0: QCA Downloading qca/rampatch_00230302.bin
[ 18.932548] Bluetooth: hci0: Frame reassembly failed (-84)
[ 19.019027] trusted_key: caam algorithms registered in /proc/crypto
[ 19.020332] caam 30900000.crypto: caam pkc algorithms registered in /proc/crypto
[ 19.020358] caam 30900000.crypto: registering rng-caam
[ 19.020586] caam 30900000.crypto: rng crypto API alg registered prng-caam
[ 19.039391] Bluetooth: hci0: QCA Downloading qca/nvm_00230302.bin
[ 19.239824] Bluetooth: hci0: QCA setup on UART is completed
[ 23.627323] panel-mnt-pocket-reform 32e60000.dsi.0: [display v2] sent tables OK
[ 23.727660] panel-mnt-pocket-reform 32e60000.dsi.0: [display v2] OK
[ 23.727680] mnt_sc spi1.0: [mntsc_gpio_set] (set-gpio 8 1)
[ 23.731001] mnt_sc spi1.0: enabling PWM display backlight control by MNT System Controller.
[ 23.740858] Console: switching to colour frame buffer device 120x37
[ 23.858623] imx-lcdif 32e80000.display-controller: [drm] fb0: imx-lcdifdrmfb frame buffer device
[ 23.859013] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[ 23.860338] [drm] Initialized imx-lcdif 1.0.0 for 32fc6000.display-controller on minor 2
[ 23.865760] imx-lcdif 32fc6000.display-controller: [drm] Cannot find any crtc or sizes
[ 23.871337] cdc_acm 1-1:1.0: ttyACM0: USB ACM device
[ 23.873837] usbcore: registered new interface driver cdc_acm
[ 23.873849] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 25.212215] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 25.221389] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 25.229813] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 25.238920] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 25.244862] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 25.655596] qcacld2: bad vermagic: kernel tainted.
[ 25.659763] Disabling lock debugging due to kernel taint
[ 25.713534] qcacld2: loading driver v4.5.25.57
[ 25.718367] hifDeviceInserted: Dumping clocks (50000000,200000000)
[ 25.718919] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.723363] Bluetooth: BNEP filters: protocol multicast
[ 25.725781] Bluetooth: BNEP socket layer initialized
[ 25.772891] Bluetooth: MGMT ver 1.23
[ 25.846733] NET: Registered PF_ALG protocol family
[ 25.992811] ol_download_firmware: chip_id:0x5020001 board_id:0x0
[ 25.995727] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[ 25.998371] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[ 26.001477] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/bdwlan30.b00 (-2)
[ 26.003933] ar6k_wlan mmc1:0001:1: Direct firmware load for qcacld2/bdwlan30.b00 failed with error -2
[ 26.006230] __ol_transfer_bin_file: Failed to get qcacld2/bdwlan30.b00:-2
[ 26.008648] __ol_transfer_bin_file: Trying to load default qcacld2/bdwlan30.bin
[ 26.023880] Board extended Data download address: 0x0
[ 26.035421] Bluetooth: hci0: setting up ROME/QCA6390
[ 26.048186] __ol_transfer_bin_file: Loading setup file qcacld2/qsetup30.bin
[ 26.050558] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[ 26.052990] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[ 26.058887] ar6k_wlan mmc1:0001:1: firmware: failed to load qcacld2/qsetup30.bin (-2)
[ 26.061288] ar6k_wlan mmc1:0001:1: Direct firmware load for qcacld2/qsetup30.bin failed with error -2
[ 26.066168] __ol_transfer_bin_file: Failed to get qcacld2/qsetup30.bin:-2
[ 26.246366] Bluetooth: hci0: Frame reassembly failed (-84)
[ 26.520543] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[ 26.522786] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[ 26.526845] ar6k_wlan mmc1:0001:1: firmware: failed to load wlan/qcacld2/wlan_mac.bin (-2)
[ 26.528857] ar6k_wlan mmc1:0001:1: Direct firmware load for wlan/qcacld2/wlan_mac.bin failed with error -2
[ 26.531023] ------------[ cut here ]------------
[ 26.532964] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:627:33
[ 26.534942] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.536962] CPU: 1 UID: 0 PID: 795 Comm: insmod Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.536978] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.536981] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.536985] Call trace:
[ 26.536988] show_stack+0x20/0x40 (C)
[ 26.537000] dump_stack_lvl+0x60/0x80
[ 26.537007] dump_stack+0x18/0x24
[ 26.537012] ubsan_epilogue+0x10/0x48
[ 26.537020] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.537028] csrUpdateChannelList+0x578/0x828 [qcacld2]
[ 26.537619] csrStart+0x154/0x198 [qcacld2]
[ 26.538167] sme_Start+0x20/0x90 [qcacld2]
[ 26.538683] vos_start+0x90/0x198 [qcacld2]
[ 26.539221] hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[ 26.539686] ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[ 26.540092] hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[ 26.540490] hifDeviceInserted+0x210/0x828 [qcacld2]
[ 26.540891] sdio_bus_probe+0x134/0x1f0
[ 26.540902] really_probe+0xc8/0x3f0
[ 26.540909] __driver_probe_device+0x90/0x1b0
[ 26.540915] driver_probe_device+0x44/0x128
[ 26.540921] __driver_attach+0xd0/0x208
[ 26.540926] bus_for_each_dev+0x84/0xf0
[ 26.540931] driver_attach+0x2c/0x40
[ 26.540936] bus_add_driver+0x124/0x250
[ 26.540941] driver_register+0x70/0x138
[ 26.540946] __sdio_register_driver+0x38/0x78
[ 26.540952] HIFInit+0x80/0xc0 [qcacld2]
[ 26.541346] hif_register_driver+0x74/0xe0 [qcacld2]
[ 26.541742] hdd_hif_register_driver+0x44/0x90 [qcacld2]
[ 26.542230] hdd_module_init+0x104/0xf20 [qcacld2]
[ 26.542813] do_one_initcall+0x5c/0x478
[ 26.542824] do_init_module+0x5c/0x278
[ 26.542832] load_module+0x1d40/0x2698
[ 26.542837] init_module_from_file+0xe8/0x158
[ 26.542843] __arm64_sys_finit_module+0x1f8/0x388
[ 26.542849] invoke_syscall.constprop.0+0xac/0x110
[ 26.542856] el0_svc_common.constprop.0+0x40/0xf0
[ 26.542861] do_el0_svc+0x24/0x40
[ 26.542866] el0_svc+0x40/0x1b0
[ 26.542873] el0t_64_sync_handler+0xa0/0xe8
[ 26.542879] el0t_64_sync+0x198/0x1a0
[ 26.614475] block nvme0n1: No UUID available providing old NGUID
[ 26.615908] ---[ end trace ]---
[ 26.619462] Bluetooth: hci0: QCA Product ID :0x00000008
[ 26.619565] ------------[ cut here ]------------
[ 26.620816] Bluetooth: hci0: QCA SOC Version :0x00000023
[ 26.622128] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:631:55
[ 26.624015] Bluetooth: hci0: QCA ROM Version :0x00000302
[ 26.624786] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.626177] Bluetooth: hci0: QCA Patch Version:0x00000111
[ 26.627609] CPU: 1 UID: 0 PID: 795 Comm: insmod Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.627620] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.627623] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.627628] Call trace:
[ 26.627631] show_stack+0x20/0x40 (C)
[ 26.627643] dump_stack_lvl+0x60/0x80
[ 26.627650] dump_stack+0x18/0x24
[ 26.627654] ubsan_epilogue+0x10/0x48
[ 26.627662] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.627669] csrUpdateChannelList+0x550/0x828 [qcacld2]
[ 26.628338] csrStart+0x154/0x198 [qcacld2]
[ 26.628911] sme_Start+0x20/0x90 [qcacld2]
[ 26.629389] vos_start+0x90/0x198 [qcacld2]
[ 26.629820] hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[ 26.630240] ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[ 26.630661] hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[ 26.631089] hifDeviceInserted+0x210/0x828 [qcacld2]
[ 26.631531] sdio_bus_probe+0x134/0x1f0
[ 26.631543] really_probe+0xc8/0x3f0
[ 26.631550] __driver_probe_device+0x90/0x1b0
[ 26.631557] driver_probe_device+0x44/0x128
[ 26.631562] __driver_attach+0xd0/0x208
[ 26.631568] bus_for_each_dev+0x84/0xf0
[ 26.631574] driver_attach+0x2c/0x40
[ 26.631579] bus_add_driver+0x124/0x250
[ 26.631584] driver_register+0x70/0x138
[ 26.631589] __sdio_register_driver+0x38/0x78
[ 26.631595] HIFInit+0x80/0xc0 [qcacld2]
[ 26.632110] hif_register_driver+0x74/0xe0 [qcacld2]
[ 26.632573] hdd_hif_register_driver+0x44/0x90 [qcacld2]
[ 26.633003] hdd_module_init+0x104/0xf20 [qcacld2]
[ 26.633422] do_one_initcall+0x5c/0x478
[ 26.633432] do_init_module+0x5c/0x278
[ 26.633440] load_module+0x1d40/0x2698
[ 26.633446] init_module_from_file+0xe8/0x158
[ 26.633452] __arm64_sys_finit_module+0x1f8/0x388
[ 26.633458] invoke_syscall.constprop.0+0xac/0x110
[ 26.633466] el0_svc_common.constprop.0+0x40/0xf0
[ 26.633471] do_el0_svc+0x24/0x40
[ 26.633476] el0_svc+0x40/0x1b0
[ 26.633484] el0t_64_sync_handler+0xa0/0xe8
[ 26.633490] el0t_64_sync+0x198/0x1a0
[ 26.633566] ---[ end trace ]---
[ 26.634086] Bluetooth: hci0: QCA controller version 0x00230302
[ 26.635438] ------------[ cut here ]------------
[ 26.635443] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:629:33
[ 26.635449] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.635457] CPU: 1 UID: 0 PID: 795 Comm: insmod Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.635466] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.635469] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.635473] Call trace:
[ 26.635475] show_stack+0x20/0x40 (C)
[ 26.635488] dump_stack_lvl+0x60/0x80
[ 26.635496] dump_stack+0x18/0x24
[ 26.635501] ubsan_epilogue+0x10/0x48
[ 26.635509] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.635517] csrUpdateChannelList+0x5a0/0x828 [qcacld2]
[ 26.636260] csrStart+0x154/0x198 [qcacld2]
[ 26.636898] sme_Start+0x20/0x90 [qcacld2]
[ 26.637561] vos_start+0x90/0x198 [qcacld2]
[ 26.638182] hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[ 26.638827] ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[ 26.639469] hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[ 26.640063] hifDeviceInserted+0x210/0x828 [qcacld2]
[ 26.640643] sdio_bus_probe+0x134/0x1f0
[ 26.640655] really_probe+0xc8/0x3f0
[ 26.640664] __driver_probe_device+0x90/0x1b0
[ 26.640670] driver_probe_device+0x44/0x128
[ 26.640675] __driver_attach+0xd0/0x208
[ 26.640681] bus_for_each_dev+0x84/0xf0
[ 26.640686] driver_attach+0x2c/0x40
[ 26.640691] bus_add_driver+0x124/0x250
[ 26.640696] driver_register+0x70/0x138
[ 26.640702] __sdio_register_driver+0x38/0x78
[ 26.640709] HIFInit+0x80/0xc0 [qcacld2]
[ 26.641308] hif_register_driver+0x74/0xe0 [qcacld2]
[ 26.641875] hdd_hif_register_driver+0x44/0x90 [qcacld2]
[ 26.642475] hdd_module_init+0x104/0xf20 [qcacld2]
[ 26.643085] do_one_initcall+0x5c/0x478
[ 26.643099] do_init_module+0x5c/0x278
[ 26.643107] load_module+0x1d40/0x2698
[ 26.643113] init_module_from_file+0xe8/0x158
[ 26.643119] __arm64_sys_finit_module+0x1f8/0x388
[ 26.643125] invoke_syscall.constprop.0+0xac/0x110
[ 26.643132] el0_svc_common.constprop.0+0x40/0xf0
[ 26.643138] do_el0_svc+0x24/0x40
[ 26.643143] el0_svc+0x40/0x1b0
[ 26.643150] el0t_64_sync_handler+0xa0/0xe8
[ 26.643156] el0t_64_sync+0x198/0x1a0
[ 26.643223] ---[ end trace ]---
[ 26.644165] Bluetooth: hci0: QCA Downloading qca/rampatch_00230302.bin
[ 26.645570] ------------[ cut here ]------------
[ 26.775367] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:649:37
[ 26.775381] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.775389] CPU: 1 UID: 0 PID: 795 Comm: insmod Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.775398] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.775401] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.775404] Call trace:
[ 26.775407] show_stack+0x20/0x40 (C)
[ 26.775420] dump_stack_lvl+0x60/0x80
[ 26.775426] dump_stack+0x18/0x24
[ 26.775431] ubsan_epilogue+0x10/0x48
[ 26.775438] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.775446] csrUpdateChannelList+0x764/0x828 [qcacld2]
[ 26.776046] csrStart+0x154/0x198 [qcacld2]
[ 26.776539] sme_Start+0x20/0x90 [qcacld2]
[ 26.776962] vos_start+0x90/0x198 [qcacld2]
[ 26.777388] hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[ 26.777810] ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[ 26.778231] hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[ 26.778661] hifDeviceInserted+0x210/0x828 [qcacld2]
[ 26.779082] sdio_bus_probe+0x134/0x1f0
[ 26.779094] really_probe+0xc8/0x3f0
[ 26.779102] __driver_probe_device+0x90/0x1b0
[ 26.779108] driver_probe_device+0x44/0x128
[ 26.779114] __driver_attach+0xd0/0x208
[ 26.779119] bus_for_each_dev+0x84/0xf0
[ 26.779125] driver_attach+0x2c/0x40
[ 26.779130] bus_add_driver+0x124/0x250
[ 26.779135] driver_register+0x70/0x138
[ 26.779140] __sdio_register_driver+0x38/0x78
[ 26.779146] HIFInit+0x80/0xc0 [qcacld2]
[ 26.779610] hif_register_driver+0x74/0xe0 [qcacld2]
[ 26.780160] hdd_hif_register_driver+0x44/0x90 [qcacld2]
[ 26.780749] hdd_module_init+0x104/0xf20 [qcacld2]
[ 26.781214] do_one_initcall+0x5c/0x478
[ 26.781226] do_init_module+0x5c/0x278
[ 26.781234] load_module+0x1d40/0x2698
[ 26.781240] init_module_from_file+0xe8/0x158
[ 26.781246] __arm64_sys_finit_module+0x1f8/0x388
[ 26.781252] invoke_syscall.constprop.0+0xac/0x110
[ 26.781259] el0_svc_common.constprop.0+0x40/0xf0
[ 26.781264] do_el0_svc+0x24/0x40
[ 26.781269] el0_svc+0x40/0x1b0
[ 26.781277] el0t_64_sync_handler+0xa0/0xe8
[ 26.781283] el0t_64_sync+0x198/0x1a0
[ 26.781392] ---[ end trace ]---
[ 26.845384] ------------[ cut here ]------------
[ 26.846658] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiRoam.c:651:37
[ 26.846665] index 15 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.846674] CPU: 1 UID: 0 PID: 795 Comm: insmod Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.846683] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.846686] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.846690] Call trace:
[ 26.846694] show_stack+0x20/0x40 (C)
[ 26.846706] dump_stack_lvl+0x60/0x80
[ 26.846712] dump_stack+0x18/0x24
[ 26.846717] ubsan_epilogue+0x10/0x48
[ 26.846725] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.846733] csrUpdateChannelList+0x724/0x828 [qcacld2]
[ 26.847369] csrStart+0x154/0x198 [qcacld2]
[ 26.847872] sme_Start+0x20/0x90 [qcacld2]
[ 26.848317] vos_start+0x90/0x198 [qcacld2]
[ 26.848808] hdd_wlan_startup+0xe5c/0x1948 [qcacld2]
[ 26.849251] ath_hif_sdio_probe+0x368/0x390 [qcacld2]
[ 26.849676] hifEnableFunc.isra.0+0x1c4/0x4b0 [qcacld2]
[ 26.850106] hifDeviceInserted+0x210/0x828 [qcacld2]
[ 26.850528] sdio_bus_probe+0x134/0x1f0
[ 26.850540] really_probe+0xc8/0x3f0
[ 26.850547] __driver_probe_device+0x90/0x1b0
[ 26.850553] driver_probe_device+0x44/0x128
[ 26.850558] __driver_attach+0xd0/0x208
[ 26.850564] bus_for_each_dev+0x84/0xf0
[ 26.850569] driver_attach+0x2c/0x40
[ 26.850574] bus_add_driver+0x124/0x250
[ 26.850579] driver_register+0x70/0x138
[ 26.850584] __sdio_register_driver+0x38/0x78
[ 26.850590] HIFInit+0x80/0xc0 [qcacld2]
[ 26.851017] hif_register_driver+0x74/0xe0 [qcacld2]
[ 26.851482] hdd_hif_register_driver+0x44/0x90 [qcacld2]
[ 26.851911] hdd_module_init+0x104/0xf20 [qcacld2]
[ 26.852333] do_one_initcall+0x5c/0x478
[ 26.852346] do_init_module+0x5c/0x278
[ 26.852354] load_module+0x1d40/0x2698
[ 26.852360] init_module_from_file+0xe8/0x158
[ 26.852366] __arm64_sys_finit_module+0x1f8/0x388
[ 26.852372] invoke_syscall.constprop.0+0xac/0x110
[ 26.852379] el0_svc_common.constprop.0+0x40/0xf0
[ 26.852384] do_el0_svc+0x24/0x40
[ 26.852389] el0_svc+0x40/0x1b0
[ 26.852396] el0t_64_sync_handler+0xa0/0xe8
[ 26.852402] el0t_64_sync+0x198/0x1a0
[ 26.852507] ---[ end trace ]---
[ 26.862216] Bluetooth: hci0: Frame reassembly failed (-84)
[ 26.863739] ------------[ cut here ]------------
[ 26.892169] target uses HTT version 3.60; host uses 3.28
[ 26.893450] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12543:41
[ 26.894854] *** Warning: host/target HTT versions are different, though compatible!
[ 26.896452] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.924451] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.924471] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.924473] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.924477] Call trace:
[ 26.924481] show_stack+0x20/0x40 (C)
[ 26.924494] dump_stack_lvl+0x60/0x80
[ 26.924501] dump_stack+0x18/0x24
[ 26.924506] ubsan_epilogue+0x10/0x48
[ 26.924514] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.924521] wma_update_channel_list+0x254/0x300 [qcacld2]
[ 26.925228] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 26.925761] VosMCThread+0x210/0x4c8 [qcacld2]
[ 26.926213] kthread+0x134/0x150
[ 26.926225] ret_from_fork+0x10/0x20
[ 26.926235] ---[ end trace ]---
[ 26.951384] ------------[ cut here ]------------
[ 26.951393] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12546:27
[ 26.951399] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.951406] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.951415] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.951418] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.951422] Call trace:
[ 26.951424] show_stack+0x20/0x40 (C)
[ 26.951436] dump_stack_lvl+0x60/0x80
[ 26.951442] dump_stack+0x18/0x24
[ 26.951448] ubsan_epilogue+0x10/0x48
[ 26.951455] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.951462] wma_update_channel_list+0x2d0/0x300 [qcacld2]
[ 26.952031] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 26.952518] VosMCThread+0x210/0x4c8 [qcacld2]
[ 26.953092] kthread+0x134/0x150
[ 26.953102] ret_from_fork+0x10/0x20
[ 26.953113] ---[ end trace ]---
[ 26.971163] Bluetooth: hci0: QCA Downloading qca/nvm_00230302.bin
[ 26.972215] ------------[ cut here ]------------
[ 26.991047] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12550:27
[ 26.991061] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 26.991070] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 26.991079] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 26.991081] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 26.991085] Call trace:
[ 26.991088] show_stack+0x20/0x40 (C)
[ 26.991101] dump_stack_lvl+0x60/0x80
[ 26.991108] dump_stack+0x18/0x24
[ 26.991112] ubsan_epilogue+0x10/0x48
[ 26.991121] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 26.991129] wma_update_channel_list+0x270/0x300 [qcacld2]
[ 26.991724] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 26.992176] VosMCThread+0x210/0x4c8 [qcacld2]
[ 26.992602] kthread+0x134/0x150
[ 26.992613] ret_from_fork+0x10/0x20
[ 26.992712] ---[ end trace ]---
[ 27.024746] ------------[ cut here ]------------
[ 27.024757] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12552:34
[ 27.024766] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 27.030305] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.030322] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.030325] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.030329] Call trace:
[ 27.030332] show_stack+0x20/0x40 (C)
[ 27.030344] dump_stack_lvl+0x60/0x80
[ 27.030351] dump_stack+0x18/0x24
[ 27.030356] ubsan_epilogue+0x10/0x48
[ 27.030363] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.030371] wma_update_channel_list+0x2f0/0x300 [qcacld2]
[ 27.031012] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 27.031568] VosMCThread+0x210/0x4c8 [qcacld2]
[ 27.032038] kthread+0x134/0x150
[ 27.032047] ret_from_fork+0x10/0x20
[ 27.061124] ---[ end trace ]---
[ 27.062982] ------------[ cut here ]------------
[ 27.064927] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12572:3
[ 27.066804] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 27.068650] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.068671] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.068673] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.068678] Call trace:
[ 27.068682] show_stack+0x20/0x40 (C)
[ 27.068699] dump_stack_lvl+0x60/0x80
[ 27.068706] dump_stack+0x18/0x24
[ 27.068711] ubsan_epilogue+0x10/0x48
[ 27.068719] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.068728] wma_update_channel_list+0x2b0/0x300 [qcacld2]
[ 27.069366] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 27.070028] VosMCThread+0x210/0x4c8 [qcacld2]
[ 27.070573] kthread+0x134/0x150
[ 27.070585] ret_from_fork+0x10/0x20
[ 27.070595] ---[ end trace ]---
[ 27.101729] ------------[ cut here ]------------
[ 27.103726] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:12575:3
[ 27.105626] index 1 is out of range for type 'tSirUpdateChanParam [1]'
[ 27.108242] CPU: 1 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.108261] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.108265] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.108269] Call trace:
[ 27.108272] show_stack+0x20/0x40 (C)
[ 27.108285] dump_stack_lvl+0x60/0x80
[ 27.108292] dump_stack+0x18/0x24
[ 27.108297] ubsan_epilogue+0x10/0x48
[ 27.108304] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.108311] wma_update_channel_list+0x290/0x300 [qcacld2]
[ 27.108906] wma_mc_process_msg+0x158/0x2e98 [qcacld2]
[ 27.109539] VosMCThread+0x210/0x4c8 [qcacld2]
[ 27.110123] kthread+0x134/0x150
[ 27.110136] ret_from_fork+0x10/0x20
[ 27.110147] ---[ end trace ]---
[ 27.175676] Host SW:4.5.25.57, FW:0.0.0.136, HW:QCA93x7_REV1_1
[ 27.178186] ENTER sme_set_btc_coex_dutycycle = 30
[ 27.178209] ENTER sme_set_btc_coex_dutycycle =30
[ 27.182996] ath_hif_sdio: HIF (Atheros/multi-bss)
[ 27.188534] qcacld2: driver loaded in 1476000
[ 27.193782] imx-dwmac 30bf0000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
[ 27.266132] imx-dwmac 30bf0000.ethernet end1: PHY [stmmac-1:07] driver [Micrel KSZ9031 Gigabit PHY] (irq=105)
[ 27.279337] imx-dwmac 30bf0000.ethernet end1: No Safety Features support found
[ 27.291191] imx-dwmac 30bf0000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
[ 27.302466] Bluetooth: hci0: QCA setup on UART is completed
[ 27.305238] imx-dwmac 30bf0000.ethernet end1: registered PTP clock
[ 27.309985] imx-dwmac 30bf0000.ethernet end1: configuring for phy/rgmii-id link mode
[ 27.814214] ------------[ cut here ]------------
[ 27.818133] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiScan.c:5923:95
[ 27.820388] index 8 is out of range for type 'tANI_U8 [8]'
[ 27.822487] CPU: 2 UID: 0 PID: 803 Comm: wpa_supplicant Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.822503] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.822506] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.822510] Call trace:
[ 27.822513] show_stack+0x20/0x40 (C)
[ 27.822527] dump_stack_lvl+0x60/0x80
[ 27.822534] dump_stack+0x18/0x24
[ 27.822540] ubsan_epilogue+0x10/0x48
[ 27.822547] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.822555] csrSendMBScanReq+0x764/0x790 [qcacld2]
[ 27.823367] csrScanChannels+0x138/0x190 [qcacld2]
[ 27.824198] csrProcessScanCommand+0x1ec/0x3e0 [qcacld2]
[ 27.824968] smeProcessScanQueue+0x1c8/0x210 [qcacld2]
[ 27.825773] smeProcessCommand+0x1c4/0xbd0 [qcacld2]
[ 27.826605] smeProcessPendingQueue+0x30/0x50 [qcacld2]
[ 27.827399] csrQueueSmeCommand+0x244/0x2e0 [qcacld2]
[ 27.828099] csrScanRequest+0x4c0/0x938 [qcacld2]
[ 27.828574] sme_ScanRequest+0xb8/0x118 [qcacld2]
[ 27.829011] __wlan_hdd_cfg80211_scan+0x490/0x928 [qcacld2]
[ 27.829505] wlan_hdd_cfg80211_scan+0x3c/0x68 [qcacld2]
[ 27.830102] rdev_scan+0x44/0x290 [cfg80211]
[ 27.830509] cfg80211_scan+0x110/0x188 [cfg80211]
[ 27.830833] nl80211_trigger_scan+0x494/0x908 [cfg80211]
[ 27.831076] genl_family_rcv_msg_doit+0xec/0x160
[ 27.831089] genl_rcv_msg+0x214/0x298
[ 27.831095] netlink_rcv_skb+0x70/0x158
[ 27.831102] genl_rcv+0x3c/0x60
[ 27.831108] netlink_unicast+0x1ec/0x300
[ 27.831113] netlink_sendmsg+0x1ac/0x428
[ 27.831119] __sock_sendmsg+0x5c/0xc0
[ 27.831127] ____sys_sendmsg+0x250/0x2c0
[ 27.831132] ___sys_sendmsg+0xb0/0x110
[ 27.831137] __sys_sendmsg+0xa4/0x120
[ 27.831144] __arm64_sys_sendmsg+0x28/0x40
[ 27.831150] invoke_syscall.constprop.0+0xac/0x110
[ 27.831158] el0_svc_common.constprop.0+0x40/0xf0
[ 27.831163] do_el0_svc+0x24/0x40
[ 27.831168] el0_svc+0x40/0x1b0
[ 27.831177] el0t_64_sync_handler+0xa0/0xe8
[ 27.831183] el0t_64_sync+0x198/0x1a0
[ 27.845315] ---[ end trace ]---
[ 27.845477] ------------[ cut here ]------------
[ 27.845482] UBSAN: array-index-out-of-bounds in CORE/MAC/src/pe/lim/limProcessSmeReqMessages.c:1349:51
[ 27.845489] index 8 is out of range for type 'tANI_U8 [8]'
[ 27.845499] CPU: 2 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.845508] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.845511] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.845516] Call trace:
[ 27.845520] show_stack+0x20/0x40 (C)
[ 27.845536] dump_stack_lvl+0x60/0x80
[ 27.845544] dump_stack+0x18/0x24
[ 27.845548] ubsan_epilogue+0x10/0x48
[ 27.845558] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.845567] __limProcessSmeScanReq+0xf34/0x1030 [qcacld2]
[ 27.846385] limProcessSmeReqMessages+0x12ec/0x31d8 [qcacld2]
[ 27.847176] limProcessNormalHddMsg+0xc4/0x138 [qcacld2]
[ 27.847941] limProcessMessages+0xaa8/0x2170 [qcacld2]
[ 27.848474] limMessageProcessor+0x120/0x1e8 [qcacld2]
[ 27.848919] peProcessMessages+0x4c/0x88 [qcacld2]
[ 27.849426] VosMCThread+0xf0/0x4c8 [qcacld2]
[ 27.850152] kthread+0x134/0x150
[ 27.850166] ret_from_fork+0x10/0x20
[ 27.850432] ---[ end trace ]---
[ 27.850487] ------------[ cut here ]------------
[ 27.850490] UBSAN: array-index-out-of-bounds in CORE/SERVICES/WMA/wma.c:11908:41
[ 27.850500] index 8 is out of range for type 'tANI_U8 [8]'
[ 27.850509] CPU: 2 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 27.850519] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 27.850522] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 27.850527] Call trace:
[ 27.850529] show_stack+0x20/0x40 (C)
[ 27.850541] dump_stack_lvl+0x60/0x80
[ 27.850548] dump_stack+0x18/0x24
[ 27.850553] ubsan_epilogue+0x10/0x48
[ 27.850561] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 27.850569] wma_get_buf_start_scan_cmd+0x944/0x9c0 [qcacld2]
[ 27.851359] wma_start_scan+0x88/0x2f8 [qcacld2]
[ 27.852122] wma_mc_process_msg+0x140/0x2e98 [qcacld2]
[ 27.852913] VosMCThread+0x210/0x4c8 [qcacld2]
[ 27.853747] kthread+0x134/0x150
[ 27.853762] ret_from_fork+0x10/0x20
[ 27.855798] ---[ end trace ]---
[ 28.191165] NET: Registered PF_QIPCRTR protocol family
[ 30.795449] ------------[ cut here ]------------
[ 30.795485] UBSAN: array-index-out-of-bounds in CORE/SME/src/csr/csrApiScan.c:5665:42
[ 30.795523] index 2 is out of range for type 'tLimScanChn [1]'
[ 30.795543] CPU: 0 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 30.795565] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 30.795571] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 30.795575] Call trace:
[ 30.795578] show_stack+0x20/0x40 (C)
[ 30.795591] dump_stack_lvl+0x60/0x80
[ 30.795598] dump_stack+0x18/0x24
[ 30.795603] ubsan_epilogue+0x10/0x48
[ 30.795611] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 30.795619] csrScanAgeResults+0x190/0x1a0 [qcacld2]
[ 30.796373] csrScanSmeScanResponse+0x214/0x300 [qcacld2]
[ 30.797133] csrScanningStateMsgProcessor+0x44/0x3f0 [qcacld2]
[ 30.797877] csrMsgProcessor+0x1cc/0x4d0 [qcacld2]
[ 30.798603] sme_ProcessMsg+0xbbc/0xd38 [qcacld2]
[ 30.799355] VosMCThread+0x1e4/0x4c8 [qcacld2]
[ 30.800138] kthread+0x134/0x150
[ 30.800150] ret_from_fork+0x10/0x20
[ 30.800830] ---[ end trace ]---
[ 31.007378] ------------[ cut here ]------------
[ 31.007436] UBSAN: array-index-out-of-bounds in CORE/SME/src/ccm/ccmApi.c:421:40
[ 31.007445] index 1 is out of range for type 'tANI_U32 [1]'
[ 31.007456] CPU: 0 UID: 0 PID: 823 Comm: VosMCThread Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 31.007466] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 31.007469] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 31.007473] Call trace:
[ 31.007477] show_stack+0x20/0x40 (C)
[ 31.007493] dump_stack_lvl+0x60/0x80
[ 31.007500] dump_stack+0x18/0x24
[ 31.007505] ubsan_epilogue+0x10/0x48
[ 31.007513] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 31.007522] ccmCfgCnfMsgHandler+0x64/0x330 [qcacld2]
[ 31.008339] sme_ProcessMsg+0xa88/0xd38 [qcacld2]
[ 31.009128] VosMCThread+0x1e4/0x4c8 [qcacld2]
[ 31.009898] kthread+0x134/0x150
[ 31.009912] ret_from_fork+0x10/0x20
[ 31.010112] ---[ end trace ]---
[ 31.110021] ------------[ cut here ]------------
[ 31.110051] UBSAN: array-index-out-of-bounds in CORE/CLD_TXRX/HTT/htt_t2h.c:885:35
[ 31.110060] index 1 is out of range for type 'A_UINT16 [1]'
[ 31.110071] CPU: 1 UID: 0 PID: 842 Comm: AR6K RxCompleti Tainted: GF C OE 7.1.7-mnt-reform-arm64 #1 PREEMPTLAZY Debian 7.1.7-1+reform20260810T183147Z
[ 31.110080] Tainted: [F]=FORCED_MODULE, [C]=CRAP, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[ 31.110083] Hardware name: MNT Pocket Reform with i.MX8MP Module (DT)
[ 31.110087] Call trace:
[ 31.110090] show_stack+0x20/0x40 (C)
[ 31.110102] dump_stack_lvl+0x60/0x80
[ 31.110109] dump_stack+0x18/0x24
[ 31.110114] ubsan_epilogue+0x10/0x48
[ 31.110122] __ubsan_handle_out_of_bounds+0x90/0xc0
[ 31.110129] htt_t2h_msg_handler+0x698/0x7c0 [qcacld2]
[ 31.110760] DoRecvCompletion.part.0+0x88/0x140 [qcacld2]
[ 31.111366] HTCRxCompletionHandler+0x62c/0x848 [qcacld2]
[ 31.111949] processHdrAndRxComp.part.0.isra.0+0x9c/0xd0 [qcacld2]
[ 31.112537] processHdrAndRxComp.constprop.0+0x5c/0x110 [qcacld2]
[ 31.113145] rx_completion_task+0x474/0x520 [qcacld2]
[ 31.113739] kthread+0x134/0x150
[ 31.113751] ret_from_fork+0x10/0x20
[ 31.113760] ---[ end trace ]---
[ 33.251507] Bluetooth: RFCOMM TTY layer initialized
[ 33.251559] Bluetooth: RFCOMM socket layer initialized
[ 33.251600] Bluetooth: RFCOMM ver 1.11
[ 39.834416] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[ 46.610092] rfkill: input handler disabled
[ 100.948238] systemd-journald[401]: File /var/log/journal/62e2b57d24a8445eb93203f20fa84def/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 101.912622] SCSI subsystem initialized
[ 101.996524] rfkill: input handler enabled
[ 105.594806] panel-mnt-pocket-reform 32e60000.dsi.0: [jdi_panel_get_modes] panel_version: 2
[ 336.898146] warning: `Socket Thread' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Now the emmc is not showing up in disks, but the NVME is showing up, though I can’t seem to boot still.
Thanks for your help with this!
