"T" showing up frequently on system controller OLED
I’m new to the Pocket Reform (had mine for about a week) and still figuring out where the source code for different components sits.
I’ve been seeing an intermittent “T” on the system controller OLED display and would like to dig into what is causing that to show up? I initially looked at the pocket-reform-sysctl-fw. I’m still forming a mental picture of what code is in which repositories.
Lukas’ reply from: 2024-12-16.log
T means timeout. i.e. system controller did not respond to a command
it can be ignored
To get rid of the T, just activate the menu and then escape it. It will go away then.
Thanks @2disbetter and @josch !
