A recent commit seems to indicate that HDMI output from U-Boot is now supported.
Is it feasible to get output on the internal screen? What would be required?
I was working on getting ArchLinux ARM running (Spoiler: Unless you have a kernel with I suspect at least the PCIe clock patch, USB and Wifi won’t work; the internal panel doesn’t work on ALARM 12.3 either.) and the U-Boot experience isn’t great.
The serial connector is on the bottom, but the only way to turn on the SOM I found is by using the keyboard (Circle, 1) on the other side. Restarting the SOM is possible with a button on the back.
Saving the U-Boot environment doesn’t seem to work (I saw comments around MMC/SD for env storage and crashes when trying to save on SD), so I had to copy commands during testing and then recompile U-Boot and add it to the SD to hardcode working commands.
I’m not sure on the preferred way to handle testing (typing commands on the internal keyboard without copy/paste would be tedious and error prone as well), but for general boot I’m considering changing U-Boot to read a script file from SD/MMC, writing U-Boot to MMC and changing the boot order on the SOM to set boot from MMC as default as hinted at in Advanced Chapter of the handbook.
The stripes patterns don’t work, but the other patterns do.
