I think I’m having a recurrence of this: Systemctl: error starting reform-hw-setup.service or maybe several problems are happening at once.
Some suspicious messages during boot:
Device 0: unknown device
Card did not respond to voltage select!
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
The “device tree” part repeats for all 6 uboot entries. Then it asks me to unlock my disk. Afterwards:
[FAILED] Failed to start reform-hw-setup.service - MNT Reform Hardware Defaults setup
You are in rescue mode...
Maybe these are relevant:
uname -a
Linux reform 6.19.14-mnt-reform-arm64 #1 SMP PREEMPT Debian 6.19.14-1+reform20260409T045900Z (2026-04- aarch64 GNU/Linux
$ cat /proc/device-tree/model
MNT Reform 2
May 02 12:00:07 reform systemd[1]: Starting reform-hw-setup.service - MNT Reform Hardware Defaults Setup...
May 02 12:00:07 reform reform-hw-setup[740]: /usr/bin/reform-hw-setup: 128: cannot create /sys/bus/i2c/drivers/wm8960/bind: Directory nonexistent
May 02 12:00:07 reform systemd[1]: reform-hw-setup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
May 02 12:00:07 reform systemd[1]: reform-hw-setup.service: Failed with result 'exit-code'.
May 02 12:00:07 reform systemd[1]: Failed to start reform-hw-setup.service - MNT Reform Hardware Defaults Setup.
May 02 12:04:06 reform systemd[1]: Starting reform-hw-setup.service - MNT Reform Hardware Defaults Setup...
May 02 12:04:06 reform reform-hw-setup[965]: Simple mixer control 'Playback',0
May 02 12:04:06 reform reform-hw-setup[965]: Capabilities: volume
May 02 12:04:06 reform reform-hw-setup[965]: Playback channels: Front Left - Front Right
May 02 12:04:06 reform reform-hw-setup[965]: Capture channels: Front Left - Front Right
May 02 12:04:06 reform reform-hw-setup[965]: Limits: 0 - 255
May 02 12:04:06 reform reform-hw-setup[965]: Front Left: 255 [100%] [0.00dB]
May 02 12:04:06 reform reform-hw-setup[965]: Front Right: 255 [100%] [0.00dB]
May 02 12:04:06 reform reform-hw-setup[969]: Simple mixer control 'Left Output Mixer PCM',0
May 02 12:04:06 reform reform-hw-setup[969]: Capabilities: pswitch pswitch-joined
May 02 12:04:06 reform reform-hw-setup[969]: Playback channels: Mono
May 02 12:04:06 reform reform-hw-setup[969]: Mono: Playback [on]
May 02 12:04:06 reform reform-hw-setup[974]: Simple mixer control 'Right Output Mixer PCM',0
May 02 12:04:06 reform reform-hw-setup[974]: Capabilities: pswitch pswitch-joined
May 02 12:04:06 reform reform-hw-setup[974]: Playback channels: Mono
May 02 12:04:06 reform reform-hw-setup[974]: Mono: Playback [on]
May 02 12:04:06 reform reform-hw-setup[975]: Simple mixer control 'Left Input Mixer Boost',0
May 02 12:04:06 reform reform-hw-setup[975]: Capabilities: pswitch pswitch-joined
May 02 12:04:06 reform reform-hw-setup[975]: Playback channels: Mono
May 02 12:04:06 reform reform-hw-setup[975]: Mono: Playback [on]
May 02 12:04:06 reform systemd[1]: reform-hw-setup.service: Deactivated successfully.
May 02 12:04:06 reform systemd[1]: Finished reform-hw-setup.service - MNT Reform Hardware Defaults Setup.
$ find /sys/devices/platform/soc*/ -wholename '*/tty/ttymxc*/power/wakeup'
/sys/devices/platform/soc@0/30800000.bus/30860000.serial/30860000.serial:0/30860000.serial:0.0/tty/ttymxc0/power/wakeup
/sys/devices/platform/soc@0/30800000.bus/30890000.serial/30890000.serial:0/30890000.serial:0.0/tty/ttymxc1/power/wakeup
/sys/devices/platform/soc@0/30800000.bus/30880000.serial/30880000.serial:0/30880000.serial:0.0/tty/ttymxc2/power/wakeup
$ sudo reform-check
I: Contents of /proc/device-tree/model: MNT Reform 2
I: `uname -a` output: Linux reform 6.19.14-mnt-reform-arm64 #1 SMP PREEMPT Debian 6.19.14-1+reform20260409T045900Z (2026-04- aarch64 GNU/Linux
I: Version of linux-image-mnt-reform-arm64: 6.19.14-1+reform20260409T045900Z
I: Version of reform-tools: 1.86-1+reform20260417T215359Z+1
I: Version of system image: System Image v5: 2026-01-27
I: Version of LPC firmware: MREF2LPC 30_R1 20250701
I: Version of upstream U-Boot: 2018.07
I: Version of MNT U-Boot: 2026-01-11
I: Mount source of /boot: /dev/mmcblk0p1 (eMMC)
I: Recommends of reform-desktop-minimal is not installed: reform-qcacld2
??5?????? /var/lib/alsa/asound.state I: kernel boot parameters your system does use but which are not the default:
+ single
+ single
+ single
W: Your kernel cmdline has 'single' in it and will boot into rescue mode on each boot. Maybe booting via extlinux.conf failed?
I: eMMC contains the latest bootloader version 2026-01-11
$ cat /boot/extlinux/extlinux.conf
## /boot/extlinux/extlinux.conf
## IMPORTANT WARNING
## The configuration of this file is generated automatically.
## Do not edit this file manually, use: u-boot-update
default l0
menu title U-Boot menu
prompt 1
timeout 1
label l0
menu label Debian GNU/Linux forky/sid 6.19.14-mnt-reform-arm64
linux /vmlinuz-6.19.14-mnt-reform-arm64
initrd /initrd.img-6.19.14-mnt-reform-arm64
append ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ${bootargs} console=tty1
label l0r
menu label Debian GNU/Linux forky/sid 6.19.14-mnt-reform-arm64 (rescue target)
append ro no_console_suspend cryptomgr.notests plymouth.ignore-serial-consoles pcie_aspm=off ${bootargs} console=tty1 single
label l1
menu label Debian GNU/Linux forky/sid 6.19.13-mnt-reform-arm64
linux /vmlinuz-6.19.13-mnt-reform-arm64
initrd /initrd.img-6.19.13-mnt-reform-arm64
label l1r
menu label Debian GNU/Linux forky/sid 6.19.13-mnt-reform-arm64 (rescue target)
label l2
menu label Debian GNU/Linux forky/sid 6.19.11-mnt-reform-arm64
linux /vmlinuz-6.19.11-mnt-reform-arm64
initrd /initrd.img-6.19.11-mnt-reform-arm64
label l2r
menu label Debian GNU/Linux forky/sid 6.19.11-mnt-reform-arm64 (rescue target)
I would appreciate any help!
