- Amiga model: A2000
- 680x0 CPU: 68030/60
- RAM Configuration: 128MB
- Kickstart, AmigaOS Versions: 3.2.2.1
- ZZ9000 Firmware version: 1.13
- ZZ9000 Driver version: 1.13
- Monitor model: LG LCD
- Other Zorro cards: Dicke Fat Olga
I am trying to get the USB to work on my A2000. I plug in a thumb drive, the smallest I have is a 8GB. Set HDTools to use zzusb.device. Start HDTools, select the unknown drive, change drive type, defined new drive type, read configuration / continue, comes up with MNT as the manufacture, zz9000 usb disk as the driver, and 1.9 as the driver version. When I click OK I get “cannot read from drive definitions!”.
And then I am stuck, would appreciate anyone who knows the magical answer to give me a hand!
Thanks,
