Using RPi CM4 in MNT Pocket Reform
I have several Raspberry Pi CM (Compute Modules) from past projects I have been working on in the past. My question now: can I use these in the MNT Pocket Reform?
I have seen that there is an adapter for the MNT Reform - would I be able to use them there? I did not find any information, and I would really love to know if I could be using these CM4 on MNT hardware at all.
Yes, see here: Raspi-cm4 pocket reform
Very nice! Thank you! Follow up question: can we order the Pocket Reform without any module then? Or would we have to stick with the “minimal” version with the A311D?
While it will work with the the cm4, there are no official images at this time for either raspbian or mntre images. It will need a custom kernel build. afaik I’m the only one that has been messing with the cm4 in the pocket, so I’m sure there are bugs.
The only major issue that I’m aware of at the moment is that the cm4 will crash on shutdown (the lpc driver and cm4 disagree about a shutdown hook) and has to be manually powered off.
