Has anyone been able to get a VPN working on the Reform. I am trying to use the ProtonVPN client, but can’t get the GUI or the CLI versions to work. They both hang at attempting to establish a connection.
Have you been able to get any VPNs to work?
OpenVPN to work office works fine. Yggdrasil network (uses tun interface) works fine too.
I usually use Wireguard for my VPN needs these days. I’ve used Mullvad’s Wireguard configs successfully, as well as my own hand-rolled configs for the servers I’ve been playing around with.
I guess some problem with kernel. I got Wireguard work by enabling and recompiling the kernel.
