Hello All,
I am a super noob and I was trying to install VS Code on MNT reform and have been failing since the past 2 days. Did anyone try to install VS Code on their MNT’s or is it generally a bad idea?
Thanks,
Shreek
Hello All,
Thanks,
Shreek
Generally it’s a bad idea due to VS Code nature – it’s in fact a tab of Chromium browser. I prefer to use more lightweight editors.
But in my case VS Codium works flawlessly installed from .deb package:
Thanks I didn’t even know about that Codium!!!
But for the OP I have Code installed and running on my Reform. I don’t think I did anything special to get it. I downloaded it via the Microsoft site, and it is added a microsoft repo in my sources folder.
I’m going to check out Codium though and see if it is any good.
Thank you so much, I had completed forgotten about VSCodium, will give it a spin.
@2disbetter Somehow, I am getting errors installing Code on MNT. I tried direct download as well as installing via curl.
Well on my Reform, Codium crashes like crazy and doesn’t even start.
Very weird. Meanwhile Code is working without a problem.
Latest Debian Unstable, works flawlessly. Strange…
I hope you use arm64 package, not amd64! Easy to confuse!
armhf was what I used. For some reason I though that was the architecture the reform used. Would be embarrassing if I got that wrong.
You got that wrong
Reform has arm64!
and poof, just like that Codium is working just fine!
and MS VS Code is now also uninstalled.
