What is the best way to recalibrate the batteries on the reform
my reform seems to have issues with knowing what its battery levels are.
It is always reporting 100% and on the lcd it shows ???%
Any insights
thanks
Usually, the ???% in the OLED go away after you had your Reform plugged in for a longer while until the battery cells are all fully calibrated. How long have you had your reform plugged in?
this has been that way for months and power monitoring at the OS reports 100% all the time
You might want to contact support@mntre.com about this.
That’s normal, it’s some bug in driver/monitor in the OS.
The display should show something more reasonable.
